Question about Pramac Electrical Supplies
Taking apart I need to split theengine on my generator but first need to remove the generator components. i have a 1999 5.5 kw on a yanmar diesel model number s5500myedi-rb00z
    Sergeant:
  • 192 Answers
The internals of the generator have to be removed and you'll need a gear puller to seperate the engine from the generator housing because they're pressed together. It can be a pain in the neck. There's videos on you tube on how to do it
Posted on Nov 27, 2013
3 Suggested Answers
ROMOAS
  • 97 Answers
SOURCE: Ihave a single cylender 178 china yanmar diesel
these engines have a mechanical injector and when water gets in them the best way to say this has larger particals then the diesel the best way is to remove the injector and the fuel lines and spray a carb cleaner in then this will dissipate the water place the injector in a pan and heat up on a stove not to get to hot this will dry out the injector then when this is done spray wd-40 in where the fuel tube supplies the fuel do not touch the tip or bump or drop striking the tip that goes in the engine you will have to replace it then reinstall all the removed parts keep the line lose at the injector crank the engine till fuel starts flowing do not hole the ling with a finger you can blow a hole and inject fuel in to your blood these pumps build a massive pressure when lines held .
when the fuel flows start to tighten the line what your doing is purging the air out as well as any water. when you get the lines to where their is a dropping of fuel the engine should start to run it will be ruff and smoke with a wrench loosen then tighten line a couple times wile it is running then snug the line the fuel in the injector will push what rest of the air out and it will smooth out . DO NOT USE STARTING FLUID ON THESE ENGINES you can crack the case they cant take the stress. i hope this helps
Posted on Aug 31, 2010
  • 7 Answers
SOURCE: Need a manual for honeywell generator model 6054 lpg
Can you please identify the problem you have with the 6054 generator. I may be able to assist.
Posted on Nov 23, 2011
WHERE CAN I GET A MANUAL FOR A 1966 30KW WESTINGHOUSE GENERATOR? MODEL #: 653JO54G01
Finding a manual for a 50-year old diesel generator will be difficult. However, if it needs service I would look online for a commercial service provider who has been in business for many years and is experienced in diesel generators. Look online for generator repair companies. While it's still unlikely they'll have a manual for it, most likely they will still be able to provide service for it. A Google search came up with this site: http://www.dieselenginemotor.com/diesel/engine/Detroit%203-53n%20Diesel%20Engine/3008. Good luck
Mar 13, 2016 | Electrical Supplies
Where do I find a manual for Yanmar Generator MD550
Contact Continental Engines Greenville SC
Google them they are a Yanmar dealer
Feb 19, 2015 | Yanmar Electrical Supplies
How to float the neutral on a YDG 3800E and YDG 5500E?"
Why would you isolate the N and G? If you are using it to supply a home then they should be, if tied in permanently. But only on a 2 pole ATS. The gen ground and building ground must be common, or you will loose the fault path. I would NOT recommend you use this generator in that way.
Sep 22, 2013 | Yanmar Generators Yanmar YDG 5500 Diesel...
How do you set the fue pump timing on a hercules d 2300 dt3.7 engine
take the tiny little plate of the pump and watch for timing marks to align to case
Dec 28, 2012 | Kohler 30 Kw Generator Hercules Diesel 25...
Kubota generator a45 3 120 manuals
Not a very good model number. 45KW generaters don't come in 3 phase and 120 volts.
Try one of these places and see if they can get what you need:
http://www.kubotaengine.com/products/ge_lineup.html
http://www.dieselgeneratorsmiami.com/powergeneral/2/45-kw-to-95-kw-diesel-generators.html
Sep 30, 2012 | Electrical Supplies
Hello i need to find a capacitor for my sumec diesel generator (ccbb61 30uf 300vac) cant find one anywhere please help
Capacitors are normally in the end of the alternator, remove the end cover. Most generators it is there
Sep 11, 2011 | Yanmar Diesel 5500 Watt Pramac Generator
Electrical Supplies Logo
Top Pramac Electrical Supplies Experts
RSole
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
