Question about ASUS S56ca 15.6-Inch Laptop Black - Intel Core I5 3317U 1.7Ghz Processor, 4Gb Ram, 750Gb Hdd, Dvdsm Dl, Lan, Wlan, Webcam, Integrated Graphics, Windows 8
Asus s56ca showed boot failure/check media cable and does not boot. Then I changed bot sequence to pxe rom first.Then it stops showing the initial asus bios screen, just black and the power switch glo
Power switch cannot be off after on but no display.Does my boot sequence change to pxe rom did the thing.I cannot even go for bios-setup as display black.
    New Friend:
  • 5 Answers
Bad hard drive
Posted on Nov 22, 2013
  • 124 Answers
SOURCE: PXE-E61 Media test failure
That message is when you have your computer set to network boot. You can disable it in the bios or change the boot order to put network after hard drive. Press probably Delete when booting to get into your bios and look for Boot Order.
Posted on Jan 05, 2009
camille zar
  • 95 Answers
SOURCE: I have the identical problem as chrisdangelo
hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Posted on Aug 05, 2009
SOURCE: Asus Eee pc 900 can't boot (blank screen)
Just had the same thing happen, and I thought it was the motherboard. Then a tech friend removed the battery and held the power button down. Then he replaced the battery, and it booted up fine! Good luck...
Posted on Oct 29, 2009
  • 11800 Answers
SOURCE: Asus Eee PC 2G Surf netbook fails to boot into OS
 Unfortunately Xandros is a paid (yes, you have read correctly , PAID) Linux distro. You will have to pay to get a Live-USB to reinstall.
Instead you should go here
http://www.pclinuxos.com/forum/index.php/topic,46097.0.html
  and follow the instructions to create your own PCLinuxOS (the one i use) Live-USB. You will need another pc for that. After booting from it all you're gonna have to do is to click on the Install icon on the desktop.
Posted on Dec 01, 2009
  • 164 Answers
SOURCE: BIOS POST message cannot be displayed and Setup does not run
As soon as your computer turns on, start pressing F2 simultaneously until it enter the CMOS setup.
Posted on Jun 06, 2010
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
Problem with acer laptop. My laptop stopped booting after restart. I just moved my laptop from bed to floor . while in power on the program just crash not responding, then came a blue screen and said...
Click the power button and watch the screen to see which key it says to press to get into the Bios or System Setup. Change the boot order or boot sequence. It looks like it is set to boot from a Network or LAN first. You want to boot from the hard drive 1st or the cd drive 1st and the hard drive 2nd. This will change it permanently. Then reboot.
There might also be an option to change it temporarily when you boot the system. Just watch the screen and see if it shows you which key to press to change the boot order or boot sequence. It is only effective for this one boot.
Apr 28, 2012 | Acer Computers & Internet
My Toshiba says PXE-E61:Media Test Failure, check cable PXE-MOF: Exiting PXE ROM. No bootable device--insert boot disk and press any key. How do I fix it?
check the boot sequence in bios
make sure that the first boot device is your HDD and disable the network boot
Sep 03, 2010 | Computers & Internet
Running XP/SP3. Upon booting, get DOS screen showing: PXE-E61 Media Test Failure, Check Cable PXE-MDC Exiting PXE ROM All cables are connected; checked both the hard drive and CD Rom,by...
its a problem setting in your bios its looking to boot from a pxe device,go into the bios and change it from pxe to hard drive,or turn it off.
Sep 01, 2010 | Computers & Internet
When I try to boot up my Compaq Presario 2500 laptop I get the following error message: PXE-E61: Media test failure, check cable Operating System not Found. I have tried changing the boot sequence in the...
Boot sequence isn't enough. You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
Jun 06, 2009 | Compaq Computers & Internet
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
Oct 10, 2006 | Compaq Evo Notebook N200 Notebook
ASUS S56ca 15.6-Inch Laptop Black - Intel Core I5 3317U 1.7Ghz Processor, 4Gb Ram, 750Gb Hdd, Dvdsm Dl, Lan, Wlan, Webcam, Integrated Graphics, Windows 8 Logo
113 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
