Dell e153fp So this isn't hardware related, but I hope it still gets answered. Maybe this isn't the place to ask? So I turned it on and it needs a Jolicloud 1.1 username and password... so i signed up for jolicloud but my info won't work. Please help. Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
Support@jolicloud.com
Posted on Nov 24, 2013
4 Suggested Answers
SOURCE: Dell E153FP monitor
I have a Dell E173FP LCD, my monitor don't want to stop showing his Main menu , I had the problem since 3 months and didn't get a solution for it , some time it keeps showing the main Menu without stoping ,sometime not...crazy monitor.... But i have a friend that faced same prob and toldme to open the it and see inside it if there is a detached cable or anything...just don't know how to..please tell us a soultion.
Posted on Sep 06, 2008
SOURCE: to dismantle the dell e153 15 inch monitor
The front and rear of the case is held together with latch and hook type fasteners, this is how I cracked mine apart.Remove the 4 screws holding the stand on the back of monitor, start with either bottom corners and insert a flat head screwdriver or similar soft object such as a wooden popcicle stick into the crack and work your way up the side to the top, then across the bottom, and up other side to top, I then ease the case apart at the top with no effort.
Posted on Feb 21, 2009
budmrtn
  • 11361 Answers
SOURCE: The screen on my computer (Dell E153FP 15" LCD) ke...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd. www.lcdrepair.us
Posted on May 23, 2010
How do I change the screen resolution on Dell E153FP?
Hello Paul, hi, to change the resolution, simply right click the desktop wall paper, properties settings then screen resolution you want. Hope this is what your are looking for. If this is not it, you may need the VGA driver CD. this CD will install the CORRECT resolution of your monitor.
Sep 29, 2010 | Dell E153FP 15" LCD Monitor
The screen on my computer (dell E153FP 15" lcd) keeps going black everytime I turn it on. I can still see a very dark picture and the green light is still on but I can't see much. Usually I just turn it...
May 20, 2010 | Dell E153FP 15" LCD Monitor
I have just reinstalled windows on my pc and the resolution isn't the same. The image is too large. I have been told I need to download something from dell so my cpu will recognise my monitor, what do I...
Since you have reinstalled your Operating system you will need to reinstall the Drivers for your Video card, sound card, Modem and other hardwares. You need to install drivers for each and every hardware in your computer. Windows has inbuilt drivers for most of the common hardwares like mouse keyboard modem etc. but for some specific hardwares like Sound card Graphic card, Network card etc. for which Windows cannot load the drivers on its own, we have to install them.
Driver is a set of program which helps your hardware to communicate with the Operating system (e.g: Windows).
For your Dell Monitor E153FP you can download the required drivers from the following site:
http://support.dell.com/support/downloads/download.aspx?releaseid=R76072&formatcnt=1&libid=0&fileid=99367
Hope this information is helpful to you.
Please do not forget to leave your comments and ratings.
Thank you for choosing Fixya
Dec 03, 2009 | Dell E153FPc 15" TFT LCD Flat Panel...
I'm trying to hook up the e153fp to a dell latitude lap top. What are the settings that I should use for this configuration? the e153fp doesn't like the display settings.
By going to Dell.com I was able to pull up the user guide for the E153FP and read the specs to determine that the monitor has a screen resolution of 1024x768. The previous monitor had a higher resolution and this is why the E153FP would not display correctly.
Thanks for your response to my posting.
jem
Nov 02, 2009 | Dell E153FP 15" LCD Monitor
Monitor not working properly after a windowxp re-instalation
It sounds as though you need to install drivers for the hardware that is not working properly after your re-formatting and re-installation of windows.I have found that although windows xp will provide almost any drivers needed, many drivers for Dell systems are not. Just to check which hardware is not working properly, go to the start button, go to control panel, then performance and maintainance, then system, next hardware, and finally device manager. Any hardware listed that has a yellow question mark to the left is not working properly, most likely because the drivers are not installed. The easiest solution is if you have the original CD's that came with your computer. If you do, and you have one that is labeled " resource CD ", or if it is labeled that it contains the device drivers for the hardware not working your task should be relatively easy. Just insert the disc, it should auto start, if it does not, start it manually from my computer. It will automatically provide the drivers needed. If you do not have the CD needed, you can write down the specifics of the hardware not working from the device manager by clicking on each item and going to properties. After you have that information, go to the following Dell website and manually look for and download the drivers you need. Good Luck. http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_P4_GX260&os=WW1&osl=en&catid=&impid=
Oct 16, 2008 | Dell E153FP 15" LCD Monitor
Dell E153FP monitor
Jul 06, 2008 | Dell E153FP 15" LCD Monitor
No interaction with the Monitor
Do you see anything at all after boot up or does it stay dead Check all the connectors. Check the driver situation. Check graphics card seating if this is a card aopposed of integrated graphics for this machine. Run the recovery disk Go to Dell Tech support.
May 15, 2007 | Dell E153FP 15" LCD Monitor
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
