Question about Frigidaire ATF6000ES Front Load Washer
Broken stabilizer on Frigidaire front loader
What is involved costwise and effort-wise of repairing a broken stabilizer on a fridigaire front loader (about 5 years old)? Is it possible to fix/weld the broken part ? thanks,
  • paul witort Oct 10, 2007
    Thanks
    are there online disassembly instructions for troubleshooting this?
    thanks,
    paul
    are there any online instructions on how to troubleshoot this? Disassembly sequence would be greatly appreciated.
    thanks,
    paul
    Problem Solver:
  • 15 Answers
IF it is the bottom stablizer it can be changed easily. But if it damaged the others or sub frame it could get costly.
Posted on Oct 10, 2007
  • James Crawford Oct 11, 2007
    No repair manuals that i know about. Is it the bottom stablizer? Some stabilizers come with a few parts to repair brackets. Try going to searsparts .com and give model and serial # you can look up your machine and order what you need.
Fridigaire fwb9200es1 washer making rattling noise when spinning
Hello terilym - From what you have described it sounds like you possibly have foreign objects such as coins or safety pins in the tub or pump. I suggest unplugging the washer and carefully check the tub and to verify that the drum is also not damaged. If noise continues after washer is restarted, objects may be in the actual pump. Contact a professional to accurately diagnose and repair the unit.
Sep 30, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a Fridgedaire Gallery front loader, was making a loud banging noise on spin cycle, now the whole drum has dropped! help!
The symptoms that you describe sounds like the spider arms that support the drum are broken. It is a very expensive repair. Get a few estimates, before deciding whether it is worth repairing or replacing. Sorry.
Oct 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Fridigaire over the stove microwave. the handle is broken. We can order a new handle but don't know how to install it. Can you help? thanks, Linda C. e mail ...
You must take the door out by removing a screw then lifting the door off the hinge pin then the door must be laid on it's front and, completely
disassembled to replace the door handle.
Aug 13, 2010 | Frigidaire Microwave Ovens
I have a rip in the bellos or boot of my front loader
severe swearing,and outbursts of violence usually come standard w/this repair @ no charge.the frigidaire boot is definitely the most aggravating of all the manufacturers,to me anyways..if you get the part,it actually comes w/detailed instructions-they have that going for them,but thats about it.the job is do-able,however dont be surprised if you have to throw in the towel and call a tech.
May 11, 2010 | Frigidaire Washing Machines
My Kenmore front loader is making a very loud knocking noise when it is in rinse cycle - do I need to re-stabilize it and how?
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 30, 2009 | Kenmore Washing Machines
Fridigaire washer that won't spin
Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take a piece of water hose with one end cut off and run it down the pump to drain end of the drain and reassemble the unit
Mar 11, 2009 | Frigidaire GLTF1240A Front Load Washer
ACSEES TO THESE FRONT LOADERS MAKE IT HARD TO INSPECT COMPONETS. THERE MAY BE A CLUTCH ADJUSTMENT THAT IS NEEDED AND IS HARD TO ACCESS. POSSIBLY JUST A LOSE MOUNT. I WOULD CALL A "LICENSED FACTORY CERTIFIED REPAIR COMPANY" THAT WORKS ON YOUR "SPECIFIC MAKE AND MODEL". GOOD COMPANIES WILL HAVE A "FLAT-RATE DIAGNOSTIC FEE" TO FIND AND SOMETIMES IF IS A MINOR ADJUSTMENT, CHARGE LITTLE EXTRA OR NO CHARGE AT ALL OTHER THAN THE DIAGNOSTIC FEE. MAKE SURE TO GET A WRITTEN ESTIMATE WITH THE "TOTAL COST" OF REPAIR BEFORE "SIGNING ANYTHING" OR LETTING THEM "START REPAIRS" IF THEY DONT INCLUDE IT IN THAT "DIAGNOSTIC FEE". !!!
May 02, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
376 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
