Question about Magic Chef Microwave Ovens
Magic chef microwave turns off after about 3 minutes then it just resets again after about 5 minutes
Color white model number MCO160UWF
    Top Expert:
  • Magic Chef Master
  • 12,223 Answers
Make this test and fix it. God bless you
  1. Interlock switch If your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control board If your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Magic chef microwave turns off after about 3 minut - 85b709a0-09d7-4210-be3d-4dec36f83961.gif
Posted on Nov 23, 2013
SOURCE: magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Posted on Sep 17, 2008
SOURCE: microwave shut-off within 2-3 minutes
Why don't you return it? I think this is a common problem. We returned ours to Home Depot with no questions asked.
Posted on Dec 01, 2008
  • 686 Answers
SOURCE: Magic Chef Microwave Shutting Down Problem in RV
your micrwave may run fine at 110 but it draws more power than the generator is putting out when the magnetron kicks on which is the part that creates the microwave causing the food to heat up. In other words the amperage is too low for the microwave. Amperage is what matters not voltage.
Posted on Apr 12, 2009
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
SOURCE: Magic Chef Model #MCO160UW
Call 888-775-0202 Magic chef they will replace the part free of charge even if its not longer under warranty
I've had my Magic Chef microwave for less than a year. If we use it for a long time,it shuts off for exactly 5 min. (I timed it) then it will start up again. Is something wrong with it?
A thermal protector on the magnetron or cavity could totally shut the oven off, but it seems unlikely it would be for exactly 5 minutes each time. I'd check that anyway. Could be a problem with the microprocessor on the main board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Nov 23, 2016 | Magic Chef Microwave Ovens
Magic Chef microwave model#mco165ub cant seem to turn up the power level. when I hit the power level button it cycles through -20, 0 and +20 but nothing happens when I hit enter.
Try unplugging the unit for a few minutes. The microprocessor on the control panel may have locked up. Leave it unplugged for at least 15 minutes to see if it will reset.
Jul 16, 2016 | Magic Chef Microwave Ovens
My magic chef microwaves is lock. how do i unlock it
On many Magic Chef models, press the Help button to bring up the menu. Choose the number for Child Lock (I think it's #1), then choose 2 to turn Child Lock off.
Dec 02, 2010 | Magic Chef MCM660A Microwave Oven
Aug 14, 2009 | Magic Chef CMV1000B Microwave Oven
Magic Chef MCD11E3W Just Dies While Cooking
There is an internal cooling fan. Sounds like your s has failed and its thermal cut out is turning it off. Take it for professional repair. You can't open microwaves as they have special security screws, plus there is high voltage and dangerous compounds plus the radiation itself.
Feb 13, 2018 | Magic Chef CMV1000B Microwave Oven
1992 magic chef (panasonic) microwave. Model M15E-5B. In a RV with very little use. Ran empty. 5 seconds blue flash at top of oven. Panel lights but only time pads work. Seconds, minutes, ect. Fix with new...
Try this site, it has the best advice on almost ANY microwave problem you can have, I know I read something almost identical to your prob. here:
http://www.repairfaq.org/sam/micfaq.htm.
Mar 31, 2009 | Magic Chef CMV1000B Microwave Oven
Shuts down for 5 minutes
I have the same problem with my new magic cheff over the stove microwave oven. I call magic chef and they gave me the 800 number for the service center (1-800-775-0202). When I described the problem they told me to just put a plate under the popper and this wouldn't happen anymore. I haven't tried it yet but here's hoping.
Jan 15, 2009 | Magic Chef MCD1311ST Microwave Oven
My microwave magic chef mco160uw just keeps turning on by itself. The microwave is only about 5 months old
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you have a failed keypad.
This can be dangerous, and you should keep it attended to when in use (as with any microwave) and unplugged when not in use.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Magic Chef / Ewave see here or their contact page.
Aug 06, 2008 | Microwave Ovens
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
97 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
