Question about Proform 760 CrossTrainer Treadmill
How do I remove the end cap on my nordictrack 7500 elite treadmill
I can't seem to figure out how to remove the end cap from my treadmill
I need to know where to connect wires to the new control panel on a Nordictrack elite 7500 tread mill
please see the diagram attached and proceed according.However the black wires from motor is in A1 and Red in A2. the rest see the wiring diagram
Mar 04, 2013 | Exercise & Fitness
Service manual nordictrack treadmill
Dear Sir:
I will tell the truth , Nobody from factory give the service manual, only user manual or owner.
i will give the website: www. nordicktrack.com go to customer service and then part & manual give you model, etc and download free. However you will contact them or call toll free and explain your situation.
I will another place but you must pay for the service manual: www.fitnessrepairparts.com
Is there anything that i can help you with your problem:electrical or electronic or mechanical?
sincerely.
E.CUADR
MANAGUA, NICARAGUA. C.A
Nov 29, 2011 | Exercise & Fitness
How do I get my nordic track 7500 down from it's standing up position?
theres a switch available 4 d same.. Right nxt 2 d 1 u used to move up
Sep 24, 2011 | Nordic Track NordicTrack Elite 7500...
The display reads ff and wont start
The 'ff' displayed is an error code. It means the display needs to be replaced.
To get the display replaced contact NordicTrack's customer service.
Their customer service info can be found here http://www.nordictrack.com/webapp/wcs/stores/servlet/Help_-1_10301_12401.
Mar 06, 2011 | Nordic Track NordicTrack Elite 7500...
Our Nordictrack Track Exp100S has problems. The belt rubs on the left hand side (my left as I'm walking) at the back of the treadmill. What should I do?
Inspect the rear plastic end cap. It is the plastic part at the back of the machine. The adjustment screws can be found there. These end caps disintegrate after time and break. You will see the discoloured plastic where the damage has occurred. If this is the case, the end cap must be replaced and belt readjusted.
Jan 04, 2011 | Treadmill Doctor Nordictrack Track...
My Nordictrack treadmill seems to be stuck. The incline goes up and down and I can't seem to end the problem with the programing. What do I do?
it is trying to calibrate itself, let it go the whole way up and then down without interrupting it. Then it should be fine.
Aug 04, 2010 | Nordic Track NordicTrack Treadmill, A2550
Incline goes up and down
I had the SAME problem, several time, with my NordicTrack A2250 Treadmill.
Allow it to go fully up and then fully down several times, without turning it off. IT seems to "cycle" that way 3 times and then "reboots" itself and starts working normally, again.
I had to figure this out myself... none of the suggestions I read worked.
Apr 24, 2010 | Nordic Track NordicTrack Treadmill, A2550
Proform 760 CrossTrainer Treadmill Logo
29 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
