Question about LG (DAD-8020B) DVD-RAM Burner
Driver 4m-hl-dt-st - LG (DAD-8020B) DVD-RAM Burner
SOURCE: HL-DT-ST DVDRAM GSA-4163B
*Tangent* After scouring the web looking for a solution to this problem, and I bet you this must be the case and problem for many an optical drive owner, regardless of brand or function (CD-ROM, DVD ROM, CD Writer, DVD Writer, Combo CD Writer / DVD ROM) but after busting my head trying to find the solution, some clever thinking solved the problem, where published articles on the web did not:
LG DVD Writer (HL-DT-ST DVDRAM GSA-4163B) no longer recognizes discs and no longer burns DVDs or CDs
So you have a DVD burner that, for the longest time, properly burnt discs and aided you in archiving absolutely everything that has ever been important in your life, and now, all of a sudden on a whim, the drive no longer recognizes discs (when placing a disc with data on the tray and closing it, Windows Explorer changes the label of the drive from a DVD-RAM Drive to a CD Drive and any efforts to view the contents of the disc produce the mocking-error message "Please insert a disc into drive X:" Furthermore, in Nero Xpress, Nero Burning Rom or Nero SmartStart, the screen inviting you to set burn speed, set a disc volume label, toggle MultiSession Disc or toggle Finalize Disc has a nice bright lit illuminated "Burn" label button inviting you to proceed, but any attempts to place a blank CD-R / DVD-R, DVD+R, DVD+R DL, whatever, into the disc tray and closing it fades out the "Burn" button and never illuminates it again unless the disc in the drive is ejected. This, of course, is irregardless of the disc access light blinking its friendly green accessing-goodness-message and coming to a stop as if everything was peachy upon first closing the disc tray.)
*Tangent* The few times this had occurred to me in the past (with completely different computers and computer configurations save the same DVD Burner drive) I would often start disabling and enabling drives in Windows Device Manager, and if that didn't work, deleting drive drivers in Windows Device Manager followed by rebooting and auto-reinstalling, and if that didn't work, disabling drives in the system's BIOS, and if that didn't work, fiddling with the power supply power leads and IDE interface ribbon cables and jumper settings (from master to slave to cable select) until finally the damn thing would kick in and start operating again. This time around though, nothing was working out. It had been two days of fiddling and the damn drive would not come back to me. I had even undone all the bindings of my drives in my PC case and tried the unit in other machines with the same result, and also tried it in a true MS-DOS environment using a CD ROM driver and MSCDEX with the same result. What this indicated to me was that, contrary to what many of the articles say online, that the problem is not software based like many would lead you to believe, but rather hardware based.
I read so many suggestions and not one of them sounded reasonable, considering that the drive had given me years and volumes of successful burns prior and I had already miraculously brought it back to life before: I was suggested everything from flashing the drive's CMOS to deleting lines in the system registry (regedit) to deleting and installing new ATAPI drivers to installing VERY suspect and dodgy executables that would miraculously fix things, to using different burn programs, to changing IDE Interface Ribbon Cables to changing entire power supplies, and my most hated suggestion of all, "the drive must be broken, but drive's are cheap these days anyway, just buy a new one." FOOLS! After careful elimination of possible causes, I ruled out anything that was software, operating system, or BIOS-slash-motherboard based. Sadly, unlike my pop, I know next to nothing about electronics, so my last hope was that it was a mechanical problem. Since the drive not being able to access standard discs with data on it was a clear indication of the problem, I booted in a MS-DOS environment using a Windows 98 Boot Disk, complete with CD-ROM support (these little f'ers are trusty when you get into trouble.) I called up the drive letter for my quote-unquote defective DVD Writer, placed the data disc in the drive, closed the tray, ran a simple DIR command and waited for the "device not ready" message. Once that came up (as expected), I ejected the disc tray, walked to my Grand Mother's sewing room, got a good ol sewing pin (no doubt created before the concept of home computers were even fathomable) closed the disc tray once again, ran the DIR command again, but this time, while the disc was trying to be accessed, I pushed the pin into the little emergency tray release hole, forcing the tray to eject just enough to grab onto with my fingernails. I then simply pressed the standard electronic disc eject button again, invoking a close of the tray, and low and behold, the directory contents of the disc came up. I didn't even have to run additional tests, I knew right then and there that the problem was a mechanical one with the closing of the drive (perhaps the gears were no longer coming into the proper position to place the motor hub onto the hole of the disc or the laser eye became stuck in a position that did not favour starting on the first track of the disc...who knows) Bottom line is, the thing now works as it always did, as intended.
QUICK SET OF STEPS TO REPRODUCE:
Pre-Requisits: Authentically pressed data disc that you do not care if it gets damaged (like an old outdated driver disc, AOL access disc, etc.) and a pin long and thin enough to get significant travel into the emergency release eject hole located below the disc tray (safety pins are a good choice, while thumbtacks and nails are not.)
1 - Boot PC with no disc in the troublesome drive
2 - Within operating system environment, open disc tray, place useless data disc on tray BUT DO NOT CLOSE TRAY
3 - Access a read function of the troublesome drive (in MS-DOS, navigate to the drive letter assigned, close tray with disc and type DIR or in Windows, double click My Computer, double click the troublesome drive's letter until the "please insert disc into drive X:" message comes up, and then close the tray with the disc
4 - While the disc is attempting to be accessed, in a straight manner and with pressure, push the pin into the emergency tray release eject hole until the tray pushes out physically
5 - Close the tray by means of the standard electronic eject button on the drive
-Video Game Junkie
Posted on Sep 22, 2008
SOURCE: hl-dt-st dvd-ram gsa-h55n LG DVD drive not reading DVDs recently
Hl-dt-st dvd-ram gsa-h55n LG DVD drive not reading
Posted on Nov 19, 2008
RALilja
  • 384 Answers
It would appear that the problem you are experiencing could be due to 1 of the 2 following items;
1. Re-install the software driver & software that came with the drive.
2. Set the region /Country that the drive will be working in or the language that you understand (USA=Region 1). It should be noted here that this option has a limitation of being changed up to 5 times but once it hits the fifth time the drive will be permanently set to that region and can not be changed anymore for the rest of the drives lifetime!!! The drive will usually work fine once it has been set (the default from the factory is ZERO (NOT SET)) and that may work fine for a while but it should be set to a region and it will understand all previously burnt /movie dvds that have this option set in the data already.
Good Luck!
Rich Lilja
Posted on Nov 26, 2008
SOURCE: HL-DT-ST DVD-RW GWA-4082N
my HL-DT-ST DVD-RW GWA-4082N has a problem i cant up date the drivers in my computer it is missing so if in incert a cd it cant be found my HL-DT-ST DVD-RW GWA-4082N has a yellow exclamation an status Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Posted on Jan 11, 2009
SOURCE: HL-DT-ST DVD-RW GWA-4082N driver needed
try this: http://support.microsoft.com/kb/314060 is the best solusion for this!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Mar 06, 2009
Cd\dvd is corrupted or missing (driver detectiv)
Download microsoft fixit from http://www.ziddu.com/download/6528022/MicrosoftFixit50027.msi.html and install it in your pc ,once its finished jst restart your pc and see it will work
Jan 19, 2010 | LG 16x Internal Blu-ray Disc/ HD DVD...
HL-DT-ST CD ROM GCR 8523B
that lg dvd doesnot need any driver to be downloaded, drivers for it are provided with windows system
Nov 21, 2009 | LG GCR 8523B Internal 52x CD-ROM Drive
Dvd driver noy found
There is a Microsoft KB article on this subject. Here is the link :
Just follow the instructions and it may solve your problem
Jun 09, 2009 | Computers & Internet
My pc recognises my dvdram as cdrom, after re installing.
try removing it and then switching on computer make sure the icon has gone, restall and recheck icon. this sometimes works most of the time.let me know how you get on.                 mister dj
Jun 01, 2009 | LG (DAD-8020B) DVD-RAM Burner
Feb 29, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
LG (DAD-8020B) DVD-RAM Burner Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
