Question about Kyocera FS4020DN (A4) Workgroup Mono Laser (Duplex+Networked) 128MB 1200dpi 45ppm 600 Sheet Printer
Code 6000 kyocera fs-4020 replaced fuser but code still remains
  • 40 Answers
SOURCE: 6000 error on a Kyocera
a fuse it is blown within the FUSER UNIT - replace that fuse or call a technician to do it for you.
Posted on Jan 10, 2009
acdr
  • 1913 Answers
SOURCE: I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Posted on Mar 21, 2009
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
SOURCE: kyocera fs-4020dn; Error code 6000
Be sure to power down and disconnect the power first.
A fuse it is blown within the fuser unit - replace that fuse or call a technician to do it for you.
Posted on Nov 25, 2013
Testimonial: "I have turned off, unplugged, left it over night. Nothing. If it was the fuse inside the Fuser unit, wouldnt replacing the Fuser have solved the issue?"
karthi29
where is the fuser themistor located.. if the replace the new fuser from maintenance kit, is the termistor been replaced as well?
thanks
Posted on Jan 09, 2014
Kyocera fs-4020dn; Error code 6000
Nov 25, 2013 | Kyocera FS Office Equipment & Supplies
Kyocera FS-2000D error 6000:0087166
This Code relates o the fuser unit, needs to be replace but if this code keep coming constantly from time to time than you need to check this:
There is a two wire power connector from the switching regulator ( by the interlock switch ) that goes to the fuser connector. This is one of the areas we check for the 6000 error code.
You could also check for a small piece of paper lodged in the fuser connector, both on the fuser and the one at the engine board.
also Check the power at the wall outket. Low power will cause 6000 errors.
Nov 10, 2011 | Kyocera FS-2000D Laser Printer
I have a kyocera FS-2000D and an error 6000:0087166 what can I do...???
Error Code 6000 is fuser code, you need to replace the fuser unit, make sure there is no paper stucking there first!
Kyocera 1750 error 6000: 0002930
6000 error is a fuser error. Check connections; make sure the back door/cover where the fuser is located is closed. Turn the machine off, unplug, plug back in, and turn printer back in; if you are still getting the error the fuser will need to be replaced.
Jun 09, 2011 | Kyocera FS-3900 DTN MONO LASER PRINTER
Kyocera fs4000dn error code 6000:00064
Jun 08, 2011 | Kyocera FS-4000DN Laser Printer
Hi, I have an ecosys fs 2000d, with a call service message 6000:0026965, somebody help me please
Call service message 6000 in Kyocera is a fuser error code. The fuser must have gone bad.
Regards,
Shrey
May 31, 2011 | Kyocera FS-2000D Laser Printer
Hi have an error call service 6000:0085594 My printer is Kyocera Fs-2000D If you can help me pls
Code: 6000
Contents: Broken fuser heater lamp wire
30 ppm model:
The temperature does not rise 1×C after
the fuser heater lamp has been turned
on continuously 5 s.
35/45 ppm models:
The temperature does not rise 1°C after
on continuously 10 s during waming-up
or at standby.
Causes:
- Poor contact in the fuser thermistor M connector terminals.
Check procedures/corrective measures:
- Reinsert the connector
Causes:
- Fuser thermistor M installed incorrectly.
- Check and reinstall if necessary
Causes:
- Thermal cutout triggered.
- Check for continuity. If none, replace the thermal cutout
Causes:
- Fuser heater lamp installed incorrectly
Causes:
- Broken fuser heater lamp wire.
Check procedures/corrective measures::
- Check for continuity. If none, replace the fuser heater lamp
Jan 31, 2011 | Kyocera FS-2000D Laser Printer
Error code 6000:0106504
This seems to be a fuser error. You need to take it to your local sevice agent for repairs.
Aug 13, 2009 | Kyocera FS-2000D Laser Printer
CALL SERVICE 6000:0115785
Error 6000: is a fuser error 0115785 is your page count. You require a replacement fuser
Apr 14, 2009 | Kyocera FS-2000D Laser Printer
Kyocera FS4020DN (A4) Workgroup Mono Laser (Duplex+Networked) 128MB 1200dpi 45ppm 600 Sheet Printer Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
