Question about Mitsubishi New Original WS65611 Remote Control
The picture on my mitsubishi ws65611 crt tv is off center and has about a half inch gap between the bottom of the screen and there is about a quarter inch gap on the right side of the screen
I just had the IC replaced because the screen convergence was not fixable with the onscreen adjustment tool.
    Top Expert:
  • Mitsubishi Master
  • 75,311 Answers
After replacing this IC, you have to adjust the convergence adjustments. To do this, you have to enter its service mode option. To get more details, http://electronicshelponline.blogspot.com/
Posted on Nov 23, 2013
32 inch. on each side of the screen there is a darker area shaped like half a basketball. on each side it covers the screen from top to bottom and goes in a rounded figure towards the center. like half a...
your problem is the yoke of your CRT it not fitted to the picture tube its very far so your picture become like a half basketball..you have to do is fitting the yoke into CRT and then fix it
Mar 05, 2011 | Televison & Video
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Mitsubishi ws 55807
Good Day;
It sounds like your TV is experiencing a CONVERGENCE CIRCUIT failure. YES, it is worth repairing, it's a great TV. The cost will be from $450.00 to $650.00; call an Authorized Service Center and have them give you an estimate B4 repair. Good luck, big IRISH. PS: It's Not An Easy repair to do your self.
Sep 08, 2008 | Mitsubishi WS-55807 TV
Toshiba 32 inch tv made1990
yes,you can adjust it by your remote control,find the service menu and from there you can now adjust the vertical from of your tv.
Oct 30, 2007 | Toshiba 32AF43 32" TV
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Horizontal bands
you may have a problem with the vertical output IC.
May 26, 2007 | RCA F27442 27" TV
Sone TV Picture not aligned.
This looks like Pincushion problem. nothing you can do. Only a Trained technecian can do this adjustment to reproduce a perfectly aligned image. It requires a pattern Generator and other tools. call the company tech.
May 10, 2007 | Sony KV-36FS100 36" TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Mitsubishi New Original WS65611 Remote Control Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
