Question about Maytag Washing Machines
My maytag spins too slowly and does not effectively ring out the closthes
Model sav3655aww
  • Tim Lloyd
    Tim Lloyd Nov 24, 2013
    To clarify: This is a maytag washer (sav3655aww). Once the spin cycle begins, the washer will not spin fast enough to ring the water out of the clothes. Therefore, the clothes are sopping wet and this causes the dryer to work too hard to dry them.
4 Suggested Answers
dr appliance
  • 266 Answers
SOURCE: My Maytag washer was purchased
this coild be easy fix ... remove front cabinet and verify internal hoses or pump... if coming down bottom of tub the its tub seal and bearing and u arent gonna be happy on price very extensive repair and requires a specialty tools...very expensive usually around $300.00 parts and labor
Posted on Feb 03, 2011
Andriod Man
  • 271 Answers
SOURCE: Maytag model sav3655aww will not spin water out
you may need to replace the timer and drive belt.
Posted on Feb 08, 2011
Testimonial: "This is truly an awesome site,"
SOURCE: I have a Maytag washing machine and will not drain unless I reset dial to that setting. the model # sav3655aww
Yes there is a small motor just like in most wall clocks the gears strip or the gear bushing slips and refuses to advance the dial.
you have to replace the whole timer unless you know MacGyver microsurgery
Posted on Nov 27, 2012
Nov 27, 2012 | Maytag SAV3655A Top Load Washer
Need manual for maytag washing machine model As11
probably needs a belt. pull the washer from the wall and tilt it back against the wall, make sure it is stable. then look under and find the belt and replaced from a local vendor.
Jan 02, 2012 | Maytag VRSCDX Night Rod Special Washing...
My maytag atlantis cycles but wont spin out. It spins slowly then shuts off but leaves wet clothes and water in tub.
First determine whether all the water is pumping out before it goes into spin. If not, check the pump and drain. If its not spinning fast enough with an empty tub check that there isnt any article of clothing caught between the inner and outer tubs or tub top ring. If thats ok check the clutch by turning the main drive pulley CCW. Substantial drag should be felt before the basket overcomes momentum and begins to turn. There is no repair for the clutch on this machine. The transmission must be replaced.
Jul 14, 2011 | Maytag Atlantis MAV6451 Top Load Washer
How to remove agitator on Maytag sav3655aww
Hello, All you have to do is remove the softner cap and there is a center bolt, Remove the bolt and lift up on the agitator thats all..Hope this helps. Please Rate My Answer.. Thanks
Jun 09, 2011 | Washing Machines
My Maytag washer was purchased in October 2003. Model No.: SAV3655AWW Problem: My washer is leaking from underneath. The hoses connected on the outside are very tight. Can this easily be repaired?
Feb 03, 2011 | Maytag Washing Machines
Maytag sav3655aww will not drain
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 25, 2010 | Maytag Washing Machines
My Asko W620 washer won't spin the first time through.
Try Googling (asko)(W620)(manual) without parens.
Jul 22, 2017 | Asko W620
Washing Machines Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
