Question about Federal Signal Smart Siren Light Controller, 100/200w-SS2000SM-SD
My keypad from the federal signal smart siren ss2000sm not working
I have a Yale Easy Fit Standard Alarm (EF-BX) Sometimes when I enter my house and enter my code in the keypad, the siren doesn't bleep twice to turn it off, I re-enter the code and sometimes this works and...
If you are sure you are pressing the buttons firmly.....does it register on the keypad? If so then could be faulty....return it to manufacturer, they will test it before replacing!
Jan 31, 2015 | Cars & Trucks
I want to know what is needed
There is a control unit that is apart from the keypad. There should be terminals that allow you to connect lights and alarm devices. It would be a big help if we knew the model of the system that you have.
Jun 14, 2014 | Siren Wireless Security System House...
What is needed to put a self contained siren in a wireless honeywell lynx plus keypad
5100 or 5200 is here http://www.security.honeywell.com/hsc/products/intruder-detection-systems/control-panel/wireless-burglary/
Sga federal timer
Question is incomplete.
add a comment and identify what product type you have, and what voltage and application product is used for.
Also include what you are wanting to know, for possible solution, if available.
Federal Signal does not show a timer:
Do you need a timer for one of the federal signal products?
http://www.federalsignal-indust.com/default.asp?pageID=17&lookup=2
Sep 27, 2012 | Hardware & Accessories
How to install radio shack siren on 2007 harley road glide
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
Motorcycle Security Installing Harley Davidson Security System Smart Siren...
Feb 29, 2012 | 2007 Harley Davidson FLTR Road Glide
How do i disable the siren alarm long enough to be able to drive 100 miles to dallas to my nearest smart car dealer for repairs? The alarm keeps going off when i try to drive it and ive done everything...
I don't know if pulling the fuse is in the Guide or not, but I would try that first. Worst case if you can get to the siren cut the wires running to it.
May 10, 2011 | 2008 Smart fortwo
Just installed smart siren kit, worked ok for 1
Harley alarms, while a decent alarm system, are notoriously hard to set up. On a new installation I have sometimes had to run the set-up routine 4-5 times. I hope you have an owner's manual and/or good instructions. Keep trying to set the alarm up from the beginning. If you miss a key or time limit it's not unusual to have the set-up fail and you have to start all over. Disconnecting the battery will screw things up, so be careful.
Oct 02, 2009 | 2002 Harley Davidson FLHTCUI Electra Glide...
Keypad reads siren trouble
Piezo siren connections to
terminal 10 require a 2k
resistor that can be located
at the panel, across term 4 and 10
Jan 06, 2009 | Home Security
Federal Signal Smart Siren Light Controller, 100/200w-SS2000SM-SD Logo
113 people viewed this question
Top Federal Signal Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Federal Signal Health and Beauty Expert? Answer questions, earn points and help others
