17PW16-2 overheating Power supply 17PW16-2 overheating zepto TV LCD 42 " full HD power supply overheating 24v shootdown whit backlight
faheemsafdar
  • 68 Answers
SOURCE: Philips Magnavox 17MD255/17 LCD TV had AC voltage applied.
It seems your "power regulator" a small unit inside tv device has damaged due to wrong power supply. In this case usually the power capacitor burns and few other electronic components like triodes. Get the help of a electronic chip technician to replace the damaged components.
Hope it works.
Posted on Mar 28, 2008
  • 848 Answers
SOURCE: I have a Protron 32"
for tv purpose we need only AC better you consult near by dealer to check it because if you give wrong supply the tv set will get damaged
Posted on Jun 20, 2008
  • 2318 Answers
SOURCE: i have an akai 27
I would suggest to start by measuring the voltages from the power supply to the main/back light circuitry. If the voltages are low or jumping up and down, that means a defective power supply.
If the red light is blinking, the power supply has a shorted component.
Let me know if you need further assistance.
Posted on Sep 05, 2008
localwonder
  • 6784 Answers
SOURCE: We had a power outage and the next day all I could get on my TV was the blinking power light. Can you hellp me? I have a Samsung 42" LCD Flat Panel HDTV Model No. LN T4042N edit
Hi, the power surge has destroyed the power supply board that is located inside your lcd cabinet. this board works in conjunction with an inverter board that regulates the raw ac current that is used for many different functions in your set. Normally, this type of damage will be isolated within the power supply but, it could have spread to the main control board as well, depending on how well the surge protector preformed during the surge.
The good news is that, this is a repairable situation. you can replace the power supply circuit board and inverter board as well. these replacements will fix this issue.
please rate and god bless:)
Posted on Apr 18, 2009
rulds2008
  • 3866 Answers
SOURCE: Polaroid LCD TV Symptom dead
The ware to buy information will be hard to come by hence that manufacture for this product does not use a part number on every single part when servicing the unit. Thus I can recommend where to take it and whom to call for more information since this is a unit that i personally do not repair for my clients anymore due to the aftermarket of their parts and how expensive it is getting them ETC. Here is one solution find someone on Ebay.com that is saling this TV dirt cheap and take the parts from it at your own risk! or you can go the manufacture route by calling this number 1-866-289-5168
I know you came here looking for part numbers and more help then this we understand as experts but to tell you to do something that can harm you or go beyond our scope to get these part numbers, because the part in this unit don't go by that would not help you and us and the cost of the assistance would thus go up surpassing the $9.99. I only can diagnose and check on a solution based on your problem, Yes Fixya does have solutions that do Fix but in the case we can only recommend and I would encourage you to rate my assistance based only on recommendations to solve a solution only,
Thank You
Rulds2008
Posted on Apr 28, 2009
My 42" hd Sanyo flat
chances are your backlight inverter circuit has failed, repaired one a few months back with the same problem. To verify this, take the tv in a dark room. plug it in and take a bright\ flash light and shine it on the screen. turn the set on, you should see either the screen saver or video from your source. If this is the case, your inverter is at fault. Depending on your model, your backlight inverter is built onto your power supply board so you will have to replace the power supply/inverter board. Not hard to do, you can do it yourself with care.
Sep 23, 2011 | Sanyo 42 in. LCD TV
Hello, I have an LG LCD TV Model : 37LC2RR-2L, I can get sound on th tv, the screen is on but no image appears.
You're backlight inverter is faulty.
You first need to check your power supply and ensure you have 24v output to the backlight inverter.
If you lack the 24v you will need to replace capacitors in-line to the 24v rail to get power back to your backlight inverter.
Look for these:
If your 24v is OK then you will need a replacement inverter to restore your picture to your tv.
Best of luck!
Apr 18, 2011 | LG 37LC2RR 37 in. LCD TV
I have a 42" Visio
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the BN_on (on) the backlight inverter and you still have no picture...you will need a new backlight inverter.
Hope this helps! Please rate!
Mar 08, 2011 | Vizio VW42LF 42 in. LCD HDTV
My 42 lcd LG tv has sound but no picture...i tried unplugging everything to reset, but did not work.....what can i do?
If you repair the 24v line and check the 5v feed also going to the ps_on (on) the backlight inverter and you still have no picture...you will need a new inverter.
Hope this helps! Please rate if this did :)
Mar 07, 2011 | LG 42LC2D 42 in. LCD HDTV
Hello my tv don"t have
You have a blacklight inverter issue...or the power (24v) going to the backlight inverter is faulty. You need to open the tv (if you are comfortable with that) and look for popped capacitors...these are usually on the power supply and need replacement for the proper 24v to the backlight inverter.
Mar 04, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
42" LG lcd tv has sound but no picture
Hello, If there is a complete darkness on the screen, it is likely that the problem is on the card that responsible for providing backlight to the screen. Known as invertor. Sometimes the causes are: 1 loose contacts across the card. 2 the main ic that is number begins with OZ .3 More rarely missing of the 24V voltage that provided to the invertor, in this case you should check the power supply. I hope it was helpful!
Let me know if more help is needed.
Feb 20, 2011 | LG 42LC2D 42 in. LCD HDTV
Polaroid 26inch lcd tvred standby light on but power wont turn on. I've unplugged the tv, changed the batteries in the remote. The tv stays with the red standby light only.
You need to open it up and checking the voltages in the power supply sections, you should have 5v (for logic circuits), 12v for sound, 24v for backlight inverter circuits. Look for bad caps with bulging tops in power supply also.
Jan 12, 2010 | Polaroid FXM-2611C 26 in. LCD Television
Sound is good but no picture
If there is no backlight (check it in a dark room - if there's a backlight the display will be emitting light, albiet still all dark) then you're looking to replace backlight inverter (or two of them, if it's master/slave) OR the power board. To know which of the two, measure the voltage on the cable that comes from the power supply to the LCD backlight inverter board - it has lots of cables but most of them are split in 2 groups - ground and positive usually 24V. It's fairly easy to see which are which, especially on the power board.
So if there's 24V there then it's the inverter(s) and if there's nothing then it's likely the power board; it's a little tricky, though, because the main board may turn off the backlight power - so make sure you check the voltage when turning the TV on from off and watching the read.
If there *is* backlight then you;re looking at replacing the tcon board or, less likely, the main board or, least likely, the cable between them.
Please rate my response if it helps.
Nov 06, 2009 | Vizio VO42L 42 in. LCD TV
No picture, sound only
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Oct 20, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
VIZIO LCD 26 INCH model# VW26L HDTV10F NOT TURNING ON
unplug ur backlight inverter plug &power on to see ,if it doesnt on , change ur mainboard
Nov 10, 2008 | Vizio L6 20.1 in. HD-Ready LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
