Wireless card not working
Hello, i have a Belkin F5D7011 wireless card, it was working good but i had to format my laptop (I am using Windows XP as OS) and when i tried used back it did not work, i already install the drivers and follow the instructions but when i turn on the lap top it says that there is no wireless networks available, so i run the ipconfig/all command in the command window and it says "media Disconnected" for the wireless card, i have tried everything since turn on and off the wireless zero function to reinstall the drivers, when I look for the device in the device manager it shows the card, so i do not what else to do, also when I connect the card the icon on the tool bar tray does not appear (it appears when i connect a USB flash dive). I really would appreciate any help in this matter.
    Novelist:
  • 69 Answers
This is Vikram Kumar Thumu from India-Hyderabad. I have seen your message on the issue related to the Wireless Card that  seems to not working well. I would like share and provide some suggestions on the issue. I hope that this should work and will resolve the issue.
Well, the message that you receive seems to be typical. To resolve this kind of issue I recommend you to check in with all possible causes that could effect the issue. This is the way where we can find the cause and resolve it.
Starting with, I would like to frame the things of possible causes for the issue.
1. Anti-virus softwares
2. If there is an issue with Wireless card.
3. If you are trying to use " Wired Network and Wireless network congifuration " at the same time then it results in error message " Media State Disconnected"
4. If Wireless Zero Configuration in OS is not running.
5. If there is an issue with software setup of Wireless card.
To isolate the issue.,  I recommend you to perform the steps.
** Note: Make sure that you never put in Wireless card in the Notebook when you Format your Notepad, since it could harm the Wireless Card.
Firstly, Check whether if there is any damage on the Wireless card.
Secondly, Make sure that you Power On Notebook and then insert the Wireless card. Please insert it as per manual instructions of Belkin. and Also make sure that Wireless button is ON in the Notebook before you proceed to further step.
Thirdly, Install the software of Wireless card, that is given along with Card at the time of Purchase. For the instructions of Software installation of Wireless card, please refer to the Manual or User guide of Belkin wireless card.
   *** Make sure that Notebook is using or active under any one standard configuration that could be either wired or wireless . If you are using two standards at the same time, then you will receive a error message " Media Disconnected".
once if you are done with installation of software, please check the wireless configuration. If you are using the Router  or Access Point in the network, then Router or Access point should be ON while installation of software for Wireless card.
If the issue still persists then it check the Wireless Zero Configuration. If it is disabled, then wireless feature in the Notebook will also be disabled.
   Please perform below steps to check the wireless Zero Configuration in Windows XP.
  1. Click Start, select Run. This will open a new window.
  2. In the new Run Window, type as services.msc and then click ok. This will open the Services window.
  3. In the services window, please locate to the file Wireless Zero Configuration and double click on the file. This should open the Properties window of Wireless Zero Configuration.
  4. Once the Windows is up, then make sure that Startup type is " Automatic", if it is not Automatic please select it as " Automatic and then click Apply and then click ok.
  5. Close the Serivces window.
Now, if you are done with steps, please check the issue. If the issue still persists then please check the IP address of Notebook.
  ** If you are using Router in the network, then should be 192.168.X.Y series where X could be 0 to 254 and y should be 1 to 254.
 If the issue still persists then please try to uninstall to drivers of Wireless Adapter from Device Manager.
 If the issue still persists then it could be fault with either Wireless card or an issue with Router Wireless configuration settings.
Please let me know the result of the issue,. I'll help you further....
Bye.
Posted on Oct 22, 2007
SOURCE:
Can't connect to the internet
I'm looking at one right now, but mine was plug-and-play in Windows 98. Obviously you're not using that. www.belkin.com/support.
Apr 13, 2014 | Belkin (F5D7011) 802.11g/b Wireless...
We've tried the belkin play wireless usb adapter in 2 laptops with xp pro and it wont connect the signals great it says the card is working properly but it just says it cant connect i've had this same...
Have you got two wireless icons down on the right by the clock. As it may be using the belkin wireless manager to control the device rather than the windows version.
Mar 11, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
Hi, My Wireless adapter -Belkin 802.11b is stopped working all of a sudden. There used to be a green light on the adapter when it is plugged in to my laptop, now there is no light. My Dell Latitude...
First check whether the adapter is working or not?
In the device manager you are able to detect the adapter, that is a good sign.
When you go to the adapters properties, does it say working properly,
If it is , then you just need to connect to the wireless network and the light will lit up
Click Here for more info
Oct 06, 2009 | Belkin (F5D7011) 802.11g/b Wireless...
Belkin note bookcard isnt working
Probably need to install the software that came with the Belkin card first. Make sure the card is NOT plugged in when you install from the CD. After that, restart your computer and make sure the card is now plugged in. Also, you need to set the router and belkin card with the same settings.
Jul 03, 2009 | Belkin (F5D7011) 802.11g/b Wireless...
Installation
if you need the driver for that wireless card, they have different names, it's name is on a label on the wireless card you can search google, you might find the driver for it there
Jan 02, 2009 | Computers & Internet
Belkin wireless G notebook network card problem
disconnect the divice from the computer, unistall the driver, reboot the system, the install the driver beforre connecting the divice
Dec 16, 2008 | Belkin (F5D7011) 802.11g/b Wireless...
I am trying to install the software for the Belkin Wireless G Notebook Card software. Only it reaches 100% its comes up with access denied. how can i get around it?
Make sure credentials are same with the router. Alternately you can reconfigure the router with new network key that you can use for your wireless card as well
Nov 29, 2008 | Belkin (F5D7011) 802.11g/b Wireless...
Computers & Internet Logo
320 people viewed this question
Ekse
Alun Cox
