Question about Bissell PowerForce Compact Vacuum
Loud noise and burning rubber
Nothing stuck or clogged and belt is one and in good condition and the suction sucks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
Remove belt cover and roller ... check bushes/bearings on roller for any wear and dirt pick up .Replace belt anyways
Posted on Dec 05, 2013
04 aviator there was a loud squealing noise smelling burnt rubber ,belt broke. Belt good conditions. Replaced belt and started. loud squealing noise, same burnt rubber. What's causing this to happen
with car off and keys in pocket open hood and check all pulleys and components something not turning possible seized such as idler pulley alternator noise is belt being dragged over something not turning
Aug 06, 2015 | Cars & Trucks
Upright Vax vacuum has no suction or hadly none from the base. Belt, motor, hose all working fine
yes turn it upside down and look real close at the area where dirt goes .they do plug up when too much big stuff gets in there .
Jun 15, 2015 | Vax Vacuums
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Loud rattling noise and no suction
You have something that's been sucked up into the floor cleaning part of the machine... then clogged it off. Be persistent and you should be able to find it and get it out..
Nov 04, 2013 | Hoover Vacuums
Electrolux cylinder vacuum No suction and loud noise and smell of buring rubber
rollers are probably stuck the belt is burning check for restrictions in you hoses as well as in the vacuum as well if nothing else works a repairman
Jul 13, 2012 | Vacuums
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Vax mach 5 burning smell and revving loud
The revving/burning is because the belt is burning off and the power head motor is running without load...
Flip the carpet power head upside down on the rug and look for visible screws and screwdriver release slots on the bottom plate of the head.
When you remove the burned belt determine the cause. Will the brush roll freely or is it jammed with hair and fiber?. Clean the burned rubber from the motor shaft before replacing the broken belt, available at a vac specialty shop.
Sep 04, 2009 | Vacuums
Loud noise and smell of rubber over heating
sounds like you have something stuck in the beater bar/roller and the belt is slipping. You're probably going to have to take it out and replace the belt. Also check for wads in the passages.
May 07, 2009 | Bissell 9200 Upright Vacuum
No suction, burning smell, expells dust
If by "suction" you mean it's not picking up dirt and debris on carpet, odds are your belt needs replacement, and the belt has burned, causing the burning smell. Ensure that your brushroll spins free, and replace the belt. (Belts should be replaced in any vacuum with a rubber belt every 3-6 months, regardless of use.)
If you mean that you are not having any airflow at the end of the hose, you most likely have a clog in the main hose and the burning smell is caused by your motor overheating. Ensure that there is nothing blocking the hoses.
If you have suction in the hose, and your brushroll is turning, there may be a clog in the head area behind the brushroll. Look in the hose that your wand plugs into, and ensure that it is also clear.
-R
Aug 05, 2008 | Eureka Vacuums
Oreck Vacuum troubleshooting
Hi. If the motor is on its way out the motor noise will be eratic eg slowing down speeding up popping noise & a smell of electrical burning. If you have none of these symptoms then chances are its not the motor. Does the bag inflate or is it easy to collapse when you push the bag ? If bag inflates ok check belt. If bag not fully inflating check for blockages along length of the handle pipe its designed to pull apart by lifting up rubber sleeve at machine end of pipe, push ball latch in & pull pipe out remove any debris stuck in the pipe. Remove bbottom of machine as if replacing belt check to see if there is any debris stuck in the oppening that goes to motor fan, then check the fan blades you can see them through the port is there any missing or snapped off. If blades are missing or have big chunks missing you will need to replace. If fan only has minor bits missing then reassemble it should now worl well.
Sep 07, 2007 | Vacuums
Bissell PowerForce Compact Vacuum Logo
60 people viewed this question
Top Bissell Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Bissell Kitchen Appliances - Other Expert? Answer questions, earn points and help others
