Question about Mitsubishi WD-52531 Television
Tv color wheel
How to change the color wheel
SljThere is a sound like a motor
Ur tv have a colors wheel design into it.The tv colors wheel it is defective and it is worn out,it is not spinning inside it motor mount axis motor baring anymore.The tv colors wheel is it defective that where the motor noises came from.The tv colors wheel it have to be replace to solve this making motor noises problems.The tv colors wheel it is sit way back of the tv.If u don't have any mechanical skills like take many mechanical parts aparts and putting it back together again.Don't atemp to change the tv colors wheel ur self.Hire a tv tech. to change the tv colors wheel.
Sep 22, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
I replaced my Samsung hln567wx color weheel about a year ago due to the tv making an odd sound. Changing the color wheel did fix the sound but after a year has past the picture is replacing all red with...
Tv have colors flashes back and forth some time u get a normal pictures again?Yes,u must take the tv aparts than check the colors wheel again.Check it out it condition only don't touch the colors wheel itself.U have compression air machine blow some light compression air into tv colors wheel it self might have acumalate dust on the wheel,don't solved the problems.Might have to change the colors wheel again.
Aug 27, 2011 | Samsung DLP HL-P5663W 56" TV
The pictur freezes to balck and white.
Tv have a colors wheel design into it.Tv make alots of noises like grinding,humming,buzzing or pictures freezes or lost colors or flashes black&white flashes within the pictures.The tv colors wheel it is dying and the colors disc is it warping and not spinning correctly inside it motor walls axis anymore.The tv colors wheel must be replaced.The tv colors wheel sit way back of the tv and have to take out alot mechanical parts out before even can come to it and change it.If u have no mechanical skills.Don't attemp change the tv colors wheel by ur self.Hire a tv tech.person to change it.
Jun 30, 2011 | Samsung HLN617W 61" Rear Projection HDTV
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
The picture works but there is a loud roaring noise when you tourn set on
The tv have a colors wheel design into it.The tv colors wheel is dying and spinning off it motor axis.The noises u are hearing are the colors wheel is grinding and hitting it steel hall of it frame box.U have no mechanical skills don't tries to replaced the colors wheel by ur self,because the colors wheel sit way back of many mechanical parts of the tv must take out before even can come to the colors wheel itself to replaced the colors wheel itself.Hire a tv tech to do the job to change the tv colors wheel.If u have no mechanical skills to take out and putting it back of tv colors wheel itself,because u will regret it,if u do it ur self and putting in the colors wheel in the wrong way to the tv itself.
Apr 14, 2011 | Samsung HLN5065W 50" Rear Projection...
My Smasung projection TV keeps flickering, also every hour or so the screen turns to a green flicker. I have to unplug the power cord and that temporarily fixes the problem. How do I stop the flickering?
The tv colors wheel is dying,replaced the tv colors wheel,will solved this problems.Hire a tv Tech.to change the tv colors wheel,it pretty hard to change the colors wheel in this tv.Because u require take out many machanical parts before u even can come to the tv colors wheel itself to change it.
Nov 08, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Black and wight picture
The tv have a colors wheel.The tv make humming,buzzing motor loud noises or flickering black and white pictures.The colors wheel is dead,require changing,bcause of the colors wheel axsis rubbing on it sides or worn out,than have black & white pictures.Hire a tv tech, to do the job.Because changing the colors wheel is not easy.Require take out many machanicals parts,before even can change the colors wheel it self.
Sep 01, 2010 | Samsung DLP HL-P5663W 56" TV
Color
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
Jul 24, 2010 | Sharp 65DR650 65" Rear Projection...
Color is horrible basically black and white
Ur tv colors wheel is dead,colors wheel is the problems,must be change.When the tv picture are black&white,colors fade in & out,loud squiling and motor noises.All these problems,indicate the colors wheel it dead,require changing.Hire a tv tech.for this job,because the colors wheel replacement require to take out alots of machanical's parts even able to get to the colors wheel to replace it.
May 29, 2010 | Samsung HC-P4752W 47" Rear Projection...
Buzzing noise from back of television
Ur tv colors wheel is going to die soon.U lose colors,tv turn into black and white.It make buzzing,squiling and ratterling noises.The colors wheel is spinning off of it axis,it dead.Require changing the colors wheel.Call the tv repairman to do this job.Must take out many machanical parts even to get to the colors wheel to change it.Never done this before don't atemp this to do this ur self.Tv tech.well charge u more,if he have fix ur blunders.
May 08, 2010 | Samsung DLP HL-P5663W 56" TV
Mitsubishi WD-52531 Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
