Question about MyNetDeals Bluetooth Handsfree Car Kit Rearview Mirror with Caller ID Display/ FM Transmitte/ Recording for ZTE : C78/ C79/ C88 (Retail )
Instruction Could you send me the instructions of the bluetooth mirror????
I have a cheap samsung by verison flip phone i dont know how to use the bluetooth with another phone to send me music
Hi Cathy,
Make sure bothphones are switched on and Bluetooth is enabled. Then select a file to be sent to your phone, then select options, send, send by Bluetooth, search. This should get the first phone searching for your phone. Then follow the instructions.
Aug 08, 2015 | Samsung Convoy U640 for Verizon Wireless,...
Need Bluetooth Mirror T56VITEBO01 manual
HI, I NEED NEW PASSCODE ? WHAT I NEED TO DO? MANY THANKS, IF YOU CAN SEND ME TO E-MAILL ZZEMAITIS@YAHOO.COM
Jan 19, 2013 | MyNetDeals Bluetooth Handsfree Car Kit...
Cant pair phone with jabra bt2050 needs a passcode
How to pair and Send Music to a Phone Via Bluetooth
Bluetooth is a type of technology found in electronics that allows you to send and receive signals and files wirelessly. Most commonly used in cell phone headsets, many people also use Bluetooth to transfer data. There is no set protocol for all devices, so instructions for use vary from one device to another. Check out the following loose guidelines for sending music from one Bluetooth phone to another, or from a Bluetooth-enabled computer to phone.
Instructions
Verify that Bluetooth is turned on or enabled in both your devices. Most cell phones will have a Bluetooth menu in their Settings or Tools. For computers, you may see a Bluetooth icon in your system tray. If unsure, check your product manual for specific instructions.
Follow the instructions to pair (connect) your two devices. If you are asked for a passkey, try entering 0000 which is usually the default for any device.
When prompted on the other device, give permission for the original device to access it.
If transferring from phone to phone
Navigate to the song you want to send and hit the button that takes you to the options menu. Choose the option to send your song; depending on the brand of phone it may say "Send" or "Move."
The next menu should ask if you want to use a text message or Bluetooth to move or send the file. Choose Bluetooth.
When prompted on the phone receiving the file, accept it.
If transferring from computer to phone
Look for an option to browse the contents of the phone. Navigate to the Music or Multimedia folder on your phone.
Navigate to the place on your computer where your music file is kept in a separate window.
Drag the file from its original location to the correct folder on your phone.
Accept the file when prompted by your phone.
Tips & Warnings
Pairing is usually the most difficult part of the process. Make sure you read your manual on both devices if it isn't working for you. If you don't see the menu to move or send your music, your phone manufacturer may not allow it. Check your manual or with your carrier's tech support website. This process usually applies to MP3s and not ringtones.
Feb 17, 2011 | Jabra BT2050 Bluetooth Headset
How to transfer music contacts videos etc from LG cookie phone into I phone
Hi, there are different ways you can send data on phone, you can use a blue tooth device
Below is a step of how you an send Data like video, music etc from LG to iphone.
How to Send Data to a Phone Via Bluetooth
Instructions
Look for an option to browse the contents of the phone. Navigate to the data file or Multimedia folder on your phone.
Navigate to the place on your computer where your Data file is kept in a separate window.
Tips & Warnings
Pairing is usually the most difficult part of the process. Make sure you read your manual on both devices if it isn't working for you. If you don't see the menu to move or send your videos, your phone manufacturer may not allow it. Check your manual or with your carrier's tech support website. This process usually applies to MP3s and not ringtones.
Hope that helped.
Good luck.
Feb 08, 2011 | Apple Cell Phones
How do you send Music on Bluetooth from Samsung phone to Alcatel and What's the password ?
To send music from You phone using bluetooth from Your samsung to a alcatel phone is very simple. Please follow the steps below to be able to send songs from samsung bluetooth to the alcatel:
  1. Turn on the bluetooth on the samsung,
  2. Turn on the bluetooth on the alcatel,
  3. Select the song You want on the samsung,
  4. Go to the option and select send through bluetooth,
  5. It will search for the available bluetooth device that is turned on,
  6. Then it will see the alcatels bluetooth, it will pair the device first before it sends the song,
  7. Once it asks for a passkey, press 1111 on both phones,
  8. Then the song will be sent to the alcatel phone.
Hope this helped. Thank You for using FixYa!!!
Jan 18, 2011 | Cell Phones
Driver side mirror needs replacement.
take off blk panel cover inside where mirror attach and u see three screws if cant get to them pull off door panel
Jul 01, 2009 | 1998 Toyota Sienna
Sending phone book from sony ericsson w580i to bluetooth mirror
Not 100% on this, but your Sony may only work with Sony bluetooth for this. I know they do such things to promote their sales. Since the actual Bluetooth communications protocol is the same for all phones, you'll be able to pair, but you may not be able to transfer your contacts.
Nov 13, 2008 | Sony Ericsson w580i Cellular Phone
Bluetooth 5500
Hi. Theres no way to send any messages via bluetooth - formally.
You can send messages by writing it first on notebook and send it forward with bluetooth.
If you recieve any messages from another bluetooth handset they will go to same place as your SMS. In your inbox.
You can send pictures, music etc. by going in the gallery, selecting file what you want to send, and click send. It may ask do you want to send it by MMS, IR, bluetooth or something like that.
This is my favourite. Search super bluetooth hacker from Google and send it to your phone. It may came to your inbox. Install it, turn bluetooth on, cheat your friend that you will send him some cool clips and songs. Then your phone will ask password. You both enter same password (example 1111) and you may have access to his/her phone. >:)
If you want to any more help, connect me and I will help you.
Oh! By the way, I think you can download online instructions from Nokias website. Have a nice day - with bluetooth.
Sep 07, 2008 | Nokia 5500 Sport Cellular Phone
MyNetDeals Bluetooth Handsfree Car Kit Rearview Mirror with Caller ID Display/ FM Transmitte/ Recording for ZTE : C78/ C79/ C88 (Retail ) Logo
14 people viewed this question
Top MyNetDeals Cell Phones Experts
Computer Repairing
Computer Repairing
Hank Schouten
Level 1 Expert
Are you a MyNetDeals Cell Phone Expert? Answer questions, earn points and help others
