Question about Gateway Computers & Internet
Scroll not working
The side scroll does not work
The scrolling on my msi netbook's trackpad isn't working, I keep sliding up and down the right side of the trackpad but nothing happens?
On the msi netbooks to scroll it doesn't work like most of the other netbook trackpads. The scrolling feature works like arrow buttons, you have to tap the top right corner to scroll up, or the bottom right corner to scroll down. It takes getting used to.
Sep 30, 2013 | Computers & Internet
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
Scroll pad not working on hp laptop mouse still works though
Need to enable Scroll function on the notebook.
Scrolling function is not working:
  1. The scroll function may stop working if the scrolling feature is disabled in Mouse Properties. To enable the scroll function, follow the steps below.
  1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
  1. Double-click Mouse in Control Panel, and then select the Device Settings tab in the Mouse Properties window.
  1. Click Settings , Virtual Scrolling . Select the boxes labeled Enable vertical scrolling and Enable horizontal scrolling .
  1. Click OK to save and exit the Mouse Properties window.
  1. After changing these settings, the scroll function on the touchpad will be enabled.
Jul 24, 2010 | HP Pavilion dv5000t Notebook
I have a Compaq Presario CQ60 scroll touchpad stop working
The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
2. Under Mouse properties Window click the Device Settings tab
3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
4. Follow the steps below to enable the Tapping Feature :
Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
5. Follow the steps below to enable Scroll feature:
Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
6. Click OK .
Alternatively you can anble scrolling by reinstalling touchpad driver.
Touchpad driver for Vista:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
Touchpad driver for Windows 7:
ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44940.exe
Mar 09, 2010 | Compaq Presario CQ60-220US PC Laptop
The scroll wheel stopped working and doesn't click anymore
open it up and clean the ball and from the in side
Oct 21, 2009 | Microsoft ARC Mouse
Hi, my laptop mouse pad works fine but at the side and bottom where i can use it to scroll down the page wont work, can sum one tell me how to get it back again, thank you
go to the control panel > mouse and pointing devices > go to device settings tab > highlight the touchpad listed and click on settings > look half way down the list where it say "scrolling" click on that and make sure both vertical and horizontal scrolling is checked. If it is and the scrolling still doesn't work,
go to control panel > device manager > scroll down to mouse and pointing devices > highlight the touchpad and disable it > wait 45 seconds, then re-enable it > hit apply and ok. Reboot
Oct 01, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
My Scroll botton will not work on my Evo N800v
You dont need to use the scroll on the touchpad just use the up and down arrows on the right hand side of your touchpad, you will find this easier to use and operate too
Feb 21, 2009 | HP Compaq Evo N800v Notebook
The scroller does not scroll horizontally - side to side
I do not know the model number of your cordless mouse or if it has a drive ball. If it has a ball , rumove the boottom to drop out the ball then remove tjhe lent and dirt from the two rod that the ball drives. If it is the non ball type , I don't know, sorry.
Dec 29, 2008 | Logitech Cordless Mouse
Mighty Mouse won't scroll down
I have had the same problem on occasion.  I found that if I turn the mouse over and tickle it...  It works!  Only kidding...
Turn the mouse over, push down hard so the ball is depressed, and move it vigorously in all directions.  That usually dislodges whatever is trapped inside.
Dec 19, 2007 | Apple Mighty MA086LL/A Mouse
Computers & Internet Logo
16 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
