Question about Invacare Mk6 Mpj Ts1136885 Joystick Controller
What do i do..mk6-mpj invacare joystick got wet and wont turn on
Got wet and wont turn on
  • Invacare Master
  • 1,271 Answers
Hi, you can send it to me for testing , free , you only pay for the postage back...(UK only)
Regards
Rob
www.gewizrepairs.co.uk
Posted on Feb 07, 2014
Invacare TDX SP. how can I be sure it's charging? Should there be lighted indicator on control screen?
Not a specific charge light but the battery level lights should blink. If you have no lights that turn on on the joystick when you turn the joystick on then the chair is not charging, Do any lights turn on when you plug the charger into the chair then into the wall?
Feb 06, 2018 | Invacare Health & Beauty
I had a wrench showing on my wheelchair. Now the wrench is gone and the unit will not turn off..
Hello, If the joystick won't turn off it is a joystick problem. You can unplug the joystick cable from the joystick to save battery if you need to. This kind of problem means your joystick will need to be repaired at Invacare or replaced by a dealer of Invacare chairs.
Jun 01, 2014 | Electric Mobility Invacare Pronto M41...
Mk6 mpj joystick got went and wont turn on
Hello,please visit:www.Invacare.com & where better to be (the Manufactures).I hope this helped,Colin
Nov 22, 2013 | Invacare Mk6 Mpj Ts1136885 Joystick...
Joy stick malfunction, error messages
hi, it could be that there is a small amount of water still in there, Please remove the unit and place where you dry your cloths etc? somewhere warm but not hot, warm and dry only, now leave for 24 hours. Also check the cable connections making sure they are clean and fit well.
RegardsGeWiz.
Feb 12, 2013 | Invacare Mk6 Mpj Ts1136885 Joystick...
Put joystick into lock mode
press and hold on button til beep then push and hold joystick til beep then pull and hold joystick til beep turn off then on should be unlocked now
Oct 04, 2012 | Invacare Supply Group Invacare Pronto M91...
I was riding in the rain and now my Invacare power wheelchair isn't working properly. Is there a way to reset it, dry it out, or get it working properly again?
Sorry the joystick doesn't like rain or coffee or wet conditions and you will have to have it replaced. Next time carry a wally world bag with you and put it over the joystick to keep the moisture out. you can still steer and use the buttons through the bag Hope this helps
Mar 19, 2011 | Invacare Pronto M51 Power Wheelchair
Have a Pronto m91 power chair. Suddenly stopped operating. At power up - two red LED's flash seven times then repeat. Have visually inspected inside electronics of Joy stick with no visible problem -...
Sounds like you are on the right track with your problem solving. Unfortunately you cannot determine an electronic fault by visual inspection of the components. You can see cuts, nicks, broken wires and burnt components, but this only works sometimes.
I look at the current fault code with a hand held programmer (HHP). With a HHP you can read the fault log and check out all the stored codes to get an overall idea of the history of chair problems. The 7 flash code is definitely a remote fault. You can also get this fault with a bad connecting cable between the joystick (remote) and the controller (in the base). Check this connecting cable for breaks, cuts, loose pins or connections and check the connections at both ends. You can do continuity and component checks of the remote with a digital voltmeter, but this is out of the realm of most end users.
I am assuming you have MK5 or MK6 electronics in this discussion.
The easiest test is to swap out the joystick with a known good one that either a tech has brought to your home or you have brought the joystick in to a service center for testing. The better test is with a HHP that will give you the current problem and stored information of past problems.
Weak batteries or loose battery connections can also give a myriad of electronic faults. For this reason I always check the batteries and battery connections first.
The joystick can be rebuilt, but I recommend replacement as a more cost effective solution. I always replace the joystick to controller cable too. Labor charge for this work is under 1 hour.
I can provide further information if needed. Hope this helps.
Dec 02, 2010 | Invacare Supply Group Invacare Pronto M91...
One of my residents has a Pronto M91 Sure Step and it turns on, the horn button works, the speed buttons work, but it WILL NOT turn off. Please help me. Would that mean I need to change the joystick...
just replace the keypad or if you are mechanically inclined remove joystick take the top off and glue a small piece of foil to the bottom of the on/off button reassemble and try that if that doesn't fix it order a new pad from a provider in your area
Jul 30, 2010 | Invacare Supply Group Invacare Pronto M91...
Invacare Mk6 Mpj Ts1136885 Joystick Controller Logo
76 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
