Question about DeLonghi ESAM6600 Espresso Machine
Hot water button does not work
All things work except the hot water. makes coffee find but when you want hot water the pump runs for one second and stops.
    Habit-Forming:
    New Friend:
  • DeLonghi Expert
  • 123 Answers
Tube water clogget.Try to remove nozzle and hot water with a thin needle dig in the hole of the machine where the water comes
Posted on Nov 28, 2013
3 Suggested Answers
  • 9 Answers
SOURCE: water not pumping
Typically this is caused by the heating/water unit inside the machine drying out. Not being totally familiar with your machine let me offer this suggestion: if you have a "hot water" function that allows you to run hot water out of the machine use it to allow water to get back into the heating unit. Once water flows through without interruption you should be able to brew coffee again. I know this is the case with Jura machines and the problem you described is identical to what happens with those machines when the internal heated water tank runs dry.
Posted on Mar 31, 2010
#1 Taper
  • 1040 Answers
SOURCE: Delonghi Magnifica Rapid Cappuccino machine has
Your problem is the holes in the cappuccino maker and
steam nozzle are clogged. Clean the holes in the cappuccino maker and the steam nozzle.
IMPORTANT: Before cleaning the holes in the steam nozzle, make sure that there that it is not hot and there is no pressure on the machine.
I'm sending you a free pdf manual download of what I believe to be your machine. If this is not it, give me the model # and I will try to find it.
Good Luck!
Jim
Posted on Oct 01, 2010
Problems whith astoria argenta
Hi just a tip from experience, grind the coffee fine and keep the spout ( where the coffee comes out) very near the cup, while making the coffee.
Kolbrun
Mar 06, 2014 | Astoria Coffee Makers & Espresso Machines
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
Only a few months old and when we plug it in it starting making a squealing noise and only got hot water when it finished . Faberware Percolator.
Hi Sharon. ALL Farberware coffee pots make racket. You have a pot that is made in China. When the water is hot the noise stops and it goes into keepwarm mode. As long as your water is hot 175 to 185 it is good. If you were trying to make coffee and you are not perking through the basket is another case.When you want to make coffee you MUST use the cone spring in the pump.That keeps the pump tight so the hot water goes up the pump. With out it the water just boils and does not go through the pump. Good luck. and if you want more info use callahanronald@att.net Ron
Feb 04, 2010 | Faberware FCP412 Coffee Maker
Brand new Gaggia Syncrony Compact will not pump water. Red light no. 27 flashes, and machine makes sounds as if trying to pump.
Open the hot water valve, if it flows for a second and stops, then pusi in on the knob if that works, call up support and ask for a new stainless steel valve for your machine.
Aug 01, 2009 | Gaggia Syncrony Compact Coffee...
My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Jun 06, 2009 | Gaggia Baby Espresso Machine
Water does not come out the frother/hot water spout .
check your solenoid valve and security valve of boiler of the machine. make sure they are clean and work good, than you will have perfect espresso again.
if pump runs without your comand check up the swich of brewing coffee.
Mar 31, 2009 | Jura Capresso C1500 Espresso & Coffee...
Steamer working only intermittendly
Hi
Have you tried to descale your machine. Remember to use the correct descaling powder and make sure that it is totally dissolved before running the descale program. In the menu, make sure that your water hardness is set on 4. descale more often than not enough.
Jan 30, 2009 | Saeco Royal Digital Plus Coffee...
New unit just won't work - keeps saying to insert brewer unit
These machines seem to respond to what their CS dept call "priming the pump." Turn on machine and after it has warmed up, turn the hot water valve or about 30-45 seconds. Shut it off and after a pause 30 seconds, repeat this process 2 additional times. Do the same 3 cycles in the steam mode. ( hit the steam button for frothing) Check openings  where coffee comes out with a small wire, ect., to make sure they are clear. It should work.
Mar 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi ESAM6600 Espresso Machine Logo
175 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
