Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Pressure washer will run for a little while the it just dies
Have cleaned the carb ,check oil put new oil pump air filter looks good
    Problem Solver:
  • 16 Answers
Under the carb, bowl is there an electric fuel shut off. sometimes they stick shut or hardly open so sounds like it is open enough to fill bowl with gas but not enough to keep it running
Posted on Dec 05, 2013
SOURCE: 21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Posted on Nov 07, 2009
  • 48 Answers
SOURCE: oil in air cleaner
Run it minus an air filter until all the oil is off your piston head, you can also try keeping the plug out and ejecting the oil via that access by pulling the cord. It seems like you've already solved the problem, now you're just cleaning up.
Posted on Apr 22, 2010
SOURCE: Briggs and Stratton 20 hp intek runs great idles
Check the vent on the gas tank if it is blocked it will cause a vacuum in the tank thus starving it for fuel
Posted on Aug 02, 2010
SOURCE: briggs and stratton v-twin engine, when you put
my vtwin starts but runs fast and slow like it is running out of gas whatcauses this
Posted on Aug 21, 2010
jdhnmi
  • 143 Answers
SOURCE: MY BRIGGS &STATTON 18.5HP STARTS BUT
you need to service your carb. it has a bowl on the bottom of the carb. it should have a screw or a nut holding the bowl in place some of the new ones have a spring clip. anyhow take it loose and there is some holes in the bolt that need to be cleaned out if tou dont have anything small enough homedepot and lowes sell a tip cleaning kit for cutting torches and it has some tiny wies that will work . some carbs have a screw in the middle of the hole after you take off the bolt look in the center and if it looks like a flat head brass screw then you can un screw that peice to and clean it thos tiny holes get cloged real fast get som carb cleaner and clean everything and the bowl it only takes gas 30 days to oxyzadize and it will leave behind a yellow scale like plaque on your teeth and will foul up the whole thing . keep note when removing the bowl one side is lower so keep it the same direction when removing it will allow the float to settle down right to allow the gas to flow into the bowl. the float has a little valve that has a rubber tip on it and it can get stuck and not work right if things seem clean and still runs funny get a carb kit from truvalue o a lawn epair shop get all info off side of motor . when installing bowl if you have a screw with a spring out the bottom of bowl screw all the way inn then turn back out 2 1/2 turns to adjust proper flow if screw is on side of carb turn same amount if too much gas is idling rough turn screw in some hope this helps
Posted on Apr 10, 2011
Craftsman 2200PSI pressure washer, part #580.752700 dies when trigger off.
NEVER start an engine on a power washer with pump attached. You will damage pump and get no or very little pressure. Replacing pump only fix. Pump for this washer about $49. Check spring on carb for throttle open/close
Jun 10, 2016 | Craftsman Garden
I am completely stumped....Pressure Washer will not start I feel like I have tried everything. Please help
buy a new carburator on ebay for 20.00,the diaghram and all the rubber hoses are shot,that is what ethanol does,eiher try a rebuild kit or wait 2 days for a new one
May 07, 2015 | Cars & Trucks
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Motor will start on choke setting and then it immediately dies when moving the choke lever to the run position. Cleaned carb, new plug new air cleaner and checked all linkages. the motor has new oil and...
You say you cleaned the carb. If you did that by spraying cleaner in through the choke, that's good, but it doesn't get to the root of the problem. The problem is getting the gas into the carb. Try this. drain the gas. Put a small amount of carb cleaner and gas in the tank (about 1:1) Start it up, but don't run it dry. Let it sit for an hour. Then start it up and run the tank dry. Then try just a little gas to see if that fixed it. If not, repeat. Good luck Al K
Dec 23, 2010 | Honda Garden
Starts but won't stay running, i clean carburator and still have same problem, unit has been used very little, still look new, Thanks,
Have you checked your oil? You need pump oil half way up in reservoir. Open plug on top of pump and check oil. Pump takes SAE 20 or 30
Next, open oil plug below engine and check your oil level. It should come up 1/2 way on dip stick. Engine takes 10W30. Don't turn washer on its side or upside down to drain oil or oil will run into carburetor.
Is the water turned on? Are you holding gun trigger open while starting? Pump needs water flow. DO NOT tie gun trigger open with wire and then start engine. That gun will flip around and shoot a hole in your leg.
If the engine starts, then you have gas, spark and compression
If engine won't stay running, the exhaust port might be clogged, or the carburetor is not letting in enough gas, or gas is not flowing to carburetor.
Check the screen over exhaust port > is it dirty or clogged? Clean with WD-40 or break it out with a screwdriver.
Remove gas filter below gas tank >>> it has a hex bolt >> loosen bolt >> the gas should come flowing out >> put it back if gas comes out
Next remove rubber gas line feeding gas to carburetor >> gas should flow out this line too >> if flows then put it back.
What about your air filter? Take it off. See if engine fires and runs without air filter. Air filter may be clogged.
While air filter is out, you can see open port to carburetor. Spray some WD-40 into carburetor. Fire up the engine. It should spark real healthy on the WD-40. Keep spraying WD-40 into carburetor to see if you can keep engine going. Don't forget to keep gun trigger open so water is flowing and pressure is not building in pump.
If engine keeps going with WD-40 but dies without it, then your carburetor is very suspect. You might need a new one.
If engine will not keep going with WD-40, then the spark is very suspect.
Change spark plug. Try again. If it doesn't fire up after that, you need to take it to the shop for repair.
Oct 09, 2010 | Honda 2500 PSI Gas Pressure Washer
My pressure washer will start, but when I pull the trigger it dies.
hi , first thing to do is a full service on it , clean the air filter , clean the spark plug, check the oil , clean the inline guaze filter on the water inlet side , open the small screw on the bottom of the carb bowl and drain out any water that may be in it , then try it with a water supply but without a hose and lance connected , this will let you know the engine and pump are working , some washers are fitted with a small piston/cylinder comming from the pump with a linkage leading to the carb this may be sticking/jammed , if you post more details we should be able to help
Mar 07, 2010 | Honda Pressure Washer PSI 3000
Pressure washer with 5hp Honda will ONLY run with choke on
It sounds like it has been tipped or too much oil has been put in. This would explain the oil in the air filter. First check the oil level. Then you need to clean the oil out of the carburetor. It is dirty or plugged and that is why it only runs when choked. You can try a spray-in carb cleaner but the best thing is to remove it (if you are handy enough) and soak it in varsol for 24 hours. Good luck
Aug 10, 2009 | Karcher 2500 PSI Pressure Washer
My pressure washer works 4 a while then starts to sputter & dies?
I am going to suggest a tune of of the engine. Change the oil and oil filter. Check the air filter is clean and replace it if it isn't. A new spark plug.
Jul 05, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer stalls
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Nov 15, 2008 | Honda Pressure Washer PSI 3000
Won't run with air filter on
I have a fairly new pressure washer with the same problem and discovered that because it was temporarily stored on its back (rather than upright), oil seeped into the air filter housing. If you look at the air filter it may not look like it has oil on it - especially if the oil is new. Mine runs fine without the air filter, but as soon as I put it in, it does the same as yours. I came across this site since I am looking to order a new filter. Hope this helps.
Jul 09, 2008 | Karcher 2500 PSI Pressure Washer
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
63 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
