Question about Philips AZ2555 CD Boombox
PHILLIPS AZ2555 CD STOPS READING AT 2MIN. THEN STARTS READING AGAIN .
ALSO CANNOT READ DISCS DISCERROR NF
  • 63 Answers
Hi
The Cd lens moves along a threaded wind you may find this has been damaged or some build up of dust is interfering
just take a look with a torch just into the gap in the guide tracks and see if anything is stuck, failing this, try f/f and rew many times this may clear anything in the way into and back into the 2 min zone
but if you are getting discs that load very slowly it may well be the lens failing too
cheers
Posted on Nov 22, 2013
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
DVr randomly stops
The alignment head is set to read/burn disks that are true and in line with the laser beam. Some Disks, especially ones burned on other equipment may not line up correctly. Tracks may at times burn incorrectly and thus they tend to skip, very much like a phono record. Commercial discs generally are true and correct, and rarely have that problem.
Dec 29, 2013 | Philips Phillips Lite-On Replacement DVD...
HOW TO CLEAN A LASER ON A PHILLIPS AZ2555
Open the CD tray and use a dry soft cloth, the type of cloth you usually get with spectacles, to clean the lens gently. Don't apply pressure, just brush off the dust, if any, from the lens. And if the set is pretty old, chances are that the lens is defective.
Nov 22, 2013 | Computers & Internet
RCA 5 disc Changer RS2600 stop reading the cd and and shows "no disc"
The reading eye is most likely dirty and doesn't see the disc clearly. If you can clean it with alcohol on a long QTip, you might get it work again for a while. Dirt & dust are the worst on the opticals. If you can clean it yourself great. Many can't be done without taking the case cover off.
Nov 24, 2012 | Audio Players & Recorders
5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Dec 06, 2009 | Marantz CC-4000 5-Disc CD Changer
My laptop will not read any discs it sounds like it is but stops
your problem is very clear... your cd-rom is corrupted...im very sure of that... install your windows again...
please vote for me...im sure this will solve your problem...
Sep 22, 2009 | Computers & Internet
DVP5140 only reads DVDs
The DVD player have two lenses.;cd and dvd lense,the cd lense needs a little adjusment so can read again..
Jun 19, 2008 | Philips DVP5140 DVD Player
Wrong disc
Some audio cd's work better than others. I have experienced some problems with the Maxell brand so I switched brands. It can be quirky. Sometimes you get a bad lot of discs. I have had no problems since that bad lot of discs.
Mar 05, 2008 | Philips CDR770 CD Recorder
Error 5
Your CD player thinks the CD is in Upside down. Basically it cannot read the disc. You need to run a CD laser Lens cleaner disc to hopefully get it back reading the Discs good again. Otherwise you will nee to take it apart and clean it all yourself manually.
Nov 04, 2007 | Kenwood KDC-MP628 CD Player
Philips AZ2555 CD Boombox Logo
51 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
