Question about Kenwood Kdc-Dab4551U CD Mp3 Car Stereo USB with Aux Input and DAB
Cannot load cd into slot
Seems like something is blocking the cd
    Problem Solver:
  • 8 Answers
Silly question but is a cd in there? try pressing the eject button if not anyways to see if the player thinks there is one in there. if not try shutting power off then turning back on
Posted on Jan 08, 2014
Just bought this used car and the CD load is very sensitive and will only let me load 1 out of every 6 I try. Is this normal?
Try a dust cleaner but do not shake the can. Just insert the shaft into the removed cd slot and shoot some air in there, then try a cd cleaner disc to clean the disc lens. If the disc player is just shooting them out also try removing and unplugging the radio assembly and shaking the radio, slot facing down maybe something is lodged in the cd input area...kids love that slot...
Mar 08, 2016 | 2007 Acura MDX
Cd player wont accept cd.s says load error
pull the player out but leave it connected. when you push the eject button,lightly tap on the top of the cd player, if there is one jammed, you may want to consider just getting a new cd player, it may do the same to your cd!
May 23, 2012 | Cars & Trucks
ET1331G-03w Multicard reader problem...
I would check all the slots if that is the only slot giving you problems then that slot may be bad.
Jan 04, 2010 | E-Machines eMachines Desktop PC
Unit will not except cd , radio work's fine, but when you push button to open front to install cd every thing is good to this point.when i place cd in slot it will not except cd, it does display loading,...
It seems something is preventing the disc to spin hence its rejecting it. It has to with the CD player's mechanical system where mostly plastic gears are being used. These when worn out can lead to such problems.........sodeep
Jul 30, 2009 | Car Audio & Video
My bose cd player won't take a cd now and play it but the radio works fine. There doesn't seems to be any disc inside. The display says no disc.
It looks like this is a Wave Music System. (Front, slot-loading CD drive? About 4 inches tall?)You could try a basic reset. Just unplug it from power for about 30-40 seconds. When you plug it back in, it should try to 'force-eject' anything that could be stuck inside. Otherwise, try another CD after the reset to see if it pulls it in and it plays. If that doesn't work, you could try flipping it upside down and pressing eject. (a roller could be stuck on something)
Let me know if this helps.
Jun 10, 2009 | Bose Cinemate Digital Home Theater System...
The rubbing Emerson CD player
hello, is this a carosel type loader? they have other internal parts that rotate it for selecting cd,s i understand what you mean.
the reason i say to open the case is incase there is something obstruction the mechanism from going in to the right return position
if you allready checked for this and theres nothing blocking the return cd holding part. then you may need to check this cage assembly for internal broken loose screws or jammed parts.
some plastic parts sometimes break or wear out and cuase the return cage to not load the cds properly. this is a loader issue
your on the right track, it is something with the returning cage
also at times the rubber shock resistant booties on the cd reader & motor assembly they are missaligned or come apart
if a cd dosent sit properly it pushes the drive motor and thats when the rubber mountings can come apart. reader assembly & motor mounts. check for this also.
good luck with your player.
happy holidays
Dec 19, 2008 | Emerson MS3108 Shelf System
Cannot insert dvd/cd into slot. something is blocking it.
if this is a "slot" based player, perhaps there is a disk already inside / stuck inside..
Sep 30, 2008 | Televison & Video
Cd drive 3inch?
It seems that even though this is a slot-loaded DVD/CD-R drive that you can still eject manually by a button; the manual does not say it can take the smaller CDs but, it would seem odd that it would not.
Nov 08, 2007 | Acer Aspire 9500 Notebook
Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Oct 06, 2006 | Technics SL-MC6 CD Player
Kenwood Kdc-Dab4551U CD Mp3 Car Stereo USB with Aux Input and DAB Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
