Question about Philips WACS700 Shelf System
I have tikking noise from both spekers,
Plug both spekers in,tikking noise from both,carnt here music,but when I disconnect,put headphones in,great.allso,small unit wont boot.....jim
    New Friend:
Hi how can i get amanual for a micro component system UX-P5R
Posted on Nov 22, 2013
  • kakima Nov 22, 2013
    Jackie, you may download a copy of the manual athttp://www.jvc.cz/files/installation_man... In the future, please ask your question as a question and not as a solution to someone else's unrelated question.
Cuts of when walking
The headphone cable maybe faulty.
To locate the fault along the headphone wire, while you are listening to music slowly flex along he cable from the headphone to the plug in your player, When the music stops then you have located the broken wire in the cable. This can be repaired by fixing the break. You may need a friend to help you repair the cable.
Apr 11, 2013 | Bose QuietComfort® 15 Acoustic Noise...
When I turn amp on there is a loud humming that does not stop.
try plugging into a different socket if that doesnt solve problem you may need to replace cord. sounds like a loose neutral in socket though.
Dec 01, 2012 | Fender Frontman 212R 100W 2x12 Guitar...
I can not turn the tv spekers
suspect a issue with the socket where the headphones connect to the set---when inserted it should cut speaker sound off---often a loose connection.
Jul 17, 2012 | Mitsubishi Televison & Video
My stearo is makeing a buzzing noise and its not the spekers
The printed circuit board inside might ahve damaged. Check it for any break.
May 22, 2012 | RCA Audio Players & Recorders
When i plug it in it makes a strange tikking noise and does not connect
The ticking noise is not a good sign at all! Try plugging it into a different computer and hope that it works. You need to get the files off of it ASAP.
The tikking sound you speak of is the disks inside your hard drive hitting each other, also known as a hard drive crash. This is BAD news if it is. Your data will not be able to be recovered if it has crashed due to physical damage. Try to get your data off of it as soon as you can, that is, if you still can
Sorry for your loss
Jun 14, 2011 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have a casio wk-200 piano. I bought headphones
The keyboard has a mic jack that is the same size as the headphones. You probably put the headphone plug into the wrong jack is all.
Jan 10, 2010 | Casio Music
CONNECT PHONE TO COMPUTER SPEAKERS
Hii Bro,
No it is not advisable to do that. U wud harm ur phone's hardware. How ever if u wish to play it on a external speakers, there are many external speakers available in the market, approx for around 200Rs.
Good Day
Sep 11, 2009 | Nokia N72 Cellular Phone
Conection of headphones
Go to control Panel >> Sounds and Audio Device >> In volume TAB >> Speaker Settings >> Advanced.. >> Speaker Setup >> select “No speakers”then under the Audio TAB >> select “Use only default devices”
Dec 05, 2008 | Computers & Internet
My psp speakers dont work the head phone jack came loose and only plays out of one head phone and the up joystick doest go up all the way in a game so i walk slow, can i fix these problems and how ???
You have either what is called a dry joint on the headphone socket or the headphone socket is broken.
When you plug the headphones in it switches off the speakers, so if the socket gets damaged or becomes disconnected from the board the speakers will also not work.
you need someone with VERY good soldering skills and a spare headphone socket to repair or replace the socket
Couldnt say whats happening with the joystick, maybe a bit of the headphone socket has got jammed in it, you probably wont find out untill the psp is opened up
May 25, 2008 | RIM BlackBerry Pearl 8100
Philips WACS700 Shelf System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
