Question about Generac Electrical Supplies
Oil going into muffler on 5500 generac generator
Runs,but smoking
    Prodigy:
    An expert who has answered 500 questions.
  • Generac Expert
  • 573 Answers
Do a leakdown test and check ring status first, check for pressure on this test in the crankcase dipstick, that will help identify an internal ring issue/ Also check the intake valve seal
Posted on Nov 23, 2013
4 Suggested Answers
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
  • 10 Answers
SOURCE: I have a 17kw generac generator that will run
I have the 18KW model and was told that most alarms relate to a low battery. Make sure the battery charger in the Transfer Switch is properly feeding the battery or hook up a mobil battery charger to the battery and see if the alarm goes away. Good Luck.
Posted on Oct 12, 2009
SOURCE: Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Posted on Jul 13, 2011
Portable generator won't spark.
replace the low oil level sensor pack
it controls spark
Jul 20, 2016 | Generac Electrical Supplies
What kind of oil do you use
Judy, Generac portable generator oil recommendations. Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.generac.com/service-support/faqs/portable-generator-faqs
http://www.generac.com/service-support/faqs/home-backup-faqs
Best oil for Generac generator Lawn Mower and Small Engine Bob Is The Oil...
Generac Generator Oil Change
Apr 18, 2016 | Generac Electrical Supplies
Oil leak on r. v. generac power, guardian gen. mo.#4704 55
I would suggest giving Generac a call. If it is not very old, you could be covered under warranty.
Jan 22, 2016 | Cars & Trucks
Oil going into muffler,smoking
If you have oil in muffler, do a comression check test for ring issues, better yet do a leakdown test, (small engine shop can do this) if air pressure is coming out fo crank case then you have a bad ring, also check the reed valve under the valce cover, this allows crankcase oil / vapor to be drawn back in the intake. A leakdown test will reveal more. Also possibly an intake valve seal.
Nov 22, 2013 | Generac Electrical Supplies
Coil smoked on start up
THIS SOUNDS LIKE OIL IS LAYING ON TOP OF THE PISTON.
Apr 08, 2013 | Generac Guardian 200 Amp Transfer Switch...
Generator is dragging when load is applied
if it drages less or not at all during night that means air fuel mix screw on the carb needs to adjust for proper intake of oxygen in the cumbustion chamber but you have to set it two times on load and no load condition till the engine runs smooth another reason is when the engine is dragging and there is smoke in the exoust that means engine oil is going up in the cylinder head which results in dragging and loss of power for that matter piston rings has to be changed but firstly check the first one
Aug 15, 2012 | Generac Power Systems Generac 0057890 3250...
I am trying to find the exhaust manifold or whatever the pipe is that comes out of the generator and connects to the muffler tube, I have a generac np50g, any ideas where i can find it?
WHEN THE ENGINE IS COLD put your hand on the muffler. Where the exhaust comes out is the rear of the muffler. Now go to the front of the muffler. The pipe that goes in is the one you are looking for. Keep following that pipe along until it joins the body of the motor, and you have found what you are looking for. Please rate this answer.
Sep 17, 2011 | Generac Guardian Ultra Source 15,000 Watt...
Generac generator will start, run for a moment and then shut down,Carb problem or bad low oil switch?
It is rather the oil switch or its level sensor, because the carb should not let it start.
Jul 09, 2010 | Generac Electrical Supplies
I have a Generac MC 5500 portable generator. It
when power tools get old they draw more amperage. 6.8 amps new might be 8 amps. over loading when older.
Apr 16, 2009 | Hammering
Electrical Supplies Logo
91 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
