Question about Okidata Oki B431Dn Laser Printer by OKI
REPLACE IMAGE DRUM 563: DRUM LIFE - Okidata Oki B431Dn Laser Printer by OKI
Minha Ricoh SPC 430DN deu erro SC 563, podem me ajudar. Sou do Rio de Janeiro - Brazil
  • Code: 563
  • Description: Pressure roller overheat 3 (software error)
    The detected fusing roller temperature stays at 230°C or more for 1 second.
  • Causes: • Defective PSU • Defective BCU
  • Remedy: 1. Replace the pressure roller thermistor (center). 2. Replace the PSU. 3. Replace the BCU.
Ricoh Aficio SPC430DN Error Codes List page 11 from 17
Esto dice que es posible que el Photo Conductor Unit Copier Drum es malo o el Color Copier BCU Engine Control Board es malo.
Jan 26, 2018 | Ricoh Office Equipment & Supplies
Oki C5350 error 563
563 I usually drum code reset, some OKI machine have sensors in the side frames they look like a little round window, clean with Q tip, I will assume you have replaced the drum, right?
May 05, 2014 | OKI C5510 MFP All-In-One Led Printer
Oki b411dn error 563
The image drum cartridge has reached the end of
its life. Replace the image drum cartridge
Jan 12, 2014 | Oki Electric Industry B411d Printer
Message saying drum unit life on OKI PRINTER C510dn
This model OKI printer is not an inkjet printer, it is a color laser printer. and uses color toner cartridges.
The printer image drum unit has reached the end of its service life and this drum unit needs to be replaced.
I suggest you Google the Internet for an OKI image drum unit for your model printer, You will get various suppliers and their prices.
The image drum unit will cost approx. A$200
Feb 07, 2013 | OKI C5100n Laser Printer
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
What is the Drum?
The drum is a selenium coated sort of roller that has the image of your copy document tranfered onto it. As it rotates this image is tranfered to your new copy paper. It then is demagnetised and the toner returns to the toner catcher. The drum coating has a finite life and the mesaage is telling you that its life is near its end and a new drum or new machine will be required soon.
Mar 22, 2010 | Brother MFC-9440CN Laser Printer
OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
  • Power on printer while holding both the + & - buttons simultaneously; release when “OKIUSER” is displayed.
  • Press either the + or – button until “ENGINE DIAG MODE” is displayed; press the Enter button and “DIAGNOSTIC MODE xx.xx.xx” will be displayed.
  • Press and hold both the - & On-line buttons simultaneously until “ENG DIAG LEVEL2” is displayed.
  • Press either the + or – button until “CONSUMABLE COUNTER SET” is displayed, press the Enter button; you are now in the menu to set various consumables.
  • Press either the + or – buttons to scroll through the various consumables, at the desired consumable press the Enter button and the last digit of the count will start flashing.
  • Press the Cancel button to decrease the digit amount or press the On-line button to increase the digit amount; press the + or – buttons to move along individual digits in the count.
  • Once the count is at the level you desire, press and hold the On-line, Cancel, & Back buttons simultaneously until the “*” reappears next to the count; consumable’s count are reseted to the number you specified.
  • Press the + or – buttons to move to the next consumable and repeat at step 5.
  • Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, you can use the Back, +, & - buttons to exit through the menus
  • until “INITIALIZING” is displayed.
Oct 14, 2009 | Oki Electric Industry C8600n Led Printer
Cyan drum life
Below is from the Oki web-site, here:
http://www.c5250.co.uk/index.asp?menumode=3&content=42126672
Cyan Image Drum with an expected life of around 17,000 pages. This is based on printing A4 sheets in a typical office environment. The image drum is attached to the bottom of the toner cartridge, and is one of the easiest consumables to replace.
May 18, 2009 | OKI C5250n Printer
Okidata Oki B431Dn Laser Printer by OKI Logo
63 people viewed this question
Top Okidata Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Okidata Office Equipment and Supply Expert? Answer questions, earn points and help others
