Question about Generac Electrical Supplies
Oil going into muffler,smoking
Generac 5500
    Prodigy:
    An expert who has answered 500 questions.
  • Generac Expert
  • 573 Answers
If you have oil in muffler, do a comression check test for ring issues, better yet do a leakdown test, (small engine shop can do this) if air pressure is coming out fo crank case then you have a bad ring, also check the reed valve under the valce cover, this allows crankcase oil / vapor to be drawn back in the intake. A leakdown test will reveal more. Also possibly an intake valve seal.
Posted on Nov 25, 2013
Portable generator won't spark.
replace the low oil level sensor pack
it controls spark
Jul 20, 2016 | Generac Electrical Supplies
Oil leak on r. v. generac power, guardian gen. mo.#4704 55
I would suggest giving Generac a call. If it is not very old, you could be covered under warranty.
Jan 22, 2016 | Cars & Trucks
Oil going into muffler on 5500 generac generator
Do a leakdown test and check ring status first, check for pressure on this test in the crankcase dipstick, that will help identify an internal ring issue/ Also check the intake valve seal
Nov 22, 2013 | Generac Electrical Supplies
Coil smoked on start up
THIS SOUNDS LIKE OIL IS LAYING ON TOP OF THE PISTON.
Apr 08, 2013 | Generac Guardian 200 Amp Transfer Switch...
I am trying to find the exhaust manifold or whatever the pipe is that comes out of the generator and connects to the muffler tube, I have a generac np50g, any ideas where i can find it?
WHEN THE ENGINE IS COLD put your hand on the muffler. Where the exhaust comes out is the rear of the muffler. Now go to the front of the muffler. The pipe that goes in is the one you are looking for. Keep following that pipe along until it joins the body of the motor, and you have found what you are looking for. Please rate this answer.
Sep 17, 2011 | Generac Guardian Ultra Source 15,000 Watt...
I changed the oil and white smoke poured out of the exhaust. Also there was oil spewing all over.
Depending on if you laid the engine over on its' side, there could have been oil in the muffler. It may take some time to "burn" this off. It will also come from the muffler. Given enough time the oil will get hot and smoke off of the muffler. Then it will no longer smoke.
I hope this answers your question.
Apr 03, 2011 | Garden
Oil is leaking from the muffler and white smoke is coming out.
this is more severe.if you are not a small engine person 3 things get a book on mower or take to shop or get a new mower.
not trying to be funny but if you dont know its going to be hard for you to fix the valve guides are bad need to replace will take speical tools to fix.sorry
Jul 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
86 kawasaki kx250 rich mix problem
"Learn to like smoke for awhile. Smell the aroma". Pardon the humor. I couldn't resist. Chances are there is oil built up in the crankcase. It is going to take some time for the oil to dissipate. How long? I don't know. It all depends on how much is in there. Cleaning the muffler is no help since the oil burning is coming from the crank not the muffler. If you are careful, and keep a vigilant eye, you could cut the gas/oil mix in half to 64 to 1 instead of the normal 32 to 1. That would mean only 2 ounces of oil per gallon instead of the normal 4 ounces. Let the crank add the rest. This will help burn the crank oil excess, but BE CAREFUL. When the crank drys up you had best not ride until more oil is added to the gas.
A “very helpful” rating for this answer? Thanks!
Jun 15, 2009 | 2003 kawasaki KX 250
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Electrical Supplies Logo
110 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
