Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
Telnet will show its loading splash screen, but will close out and go back to the AppCenter. What do?
AppCenter is on startup. When I double-click telnet, it shows its splash screen but then closes out and goes back to AppCenter.
  • Thomas Ngo Feb 10, 2014
    It turns out it was just one of AppCenter's allowed application title settings. I found the titles I wanted in the debug menu.
  • Thomas Ngo Jan 26, 2015
    Turns out, AppCenter has a debug mode to see the window details. What was happening is that AppCenter blocks everything it doesn't know. AppCenter was blocking Telnet.
    I think deleting the program and adding it back in works.
    There's a specific field to not block certain window details and for Telnet, I think it was "ActiveBridgeTelnet'Telnet" without the quotes.
Keypad not work
Posted on Dec 13, 2013
MC75A after reboots shows the appcenter but freezes the screen not able to click on anything.
Can You use the buttons? Press the right button with a white bar, just below the screen. This should open the Tools menu. If it does, use Exit and leave AppCenter. If this works, You can test if the touch screen is defect or if AppCenter installation is corrupted. If the screen is ok, reinstall AppCenter.
Mar 17, 2014 | Motorola MC75
Tip
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Loads splash screen only
Have you tried the pinhole reset?
Feb 28, 2014 | Proscan 8 4GB Android 4.1 Tablet
Downloaded drver for my printer. the add new printer wizard can't
Hi ...
If you have the driver CD that you recieved with your printer, follow the below steps to install the saftware:
  1. Turn on your computer.
  2. On your computer quit any open applications, including virus checkers.
  3. Insert the MultiPASS MP730/700 Setup CD-ROM into your CD drive. The [MP Setup] splash screen will appear automatically.
    1. If MP Setup does not start automatically, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    2. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  4. In the MP Setup splash screen, click 'Install MP Drivers'.
    Note: For Windows 2000 users, if Service Pack 1 or later is not installed, MP Setup will display a message and installation will be aborted.
  5. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  6. MP Setup will install some system files and may prompt you to restart your computer. If you are not prompted to restart, click 'Finish' in the MP Drivers Setup window and then proceed to step 7.
    1. If you are prompted, make sure radio button 'Yes, I want to restart my computer now.' is selected in the MP Drivers Setup window and then click 'Finish'. DO NOT remove the CD-ROM at this stage. MP Setup splash screen will open after Windows has restarted.
    2. If you had to restart your computer and the MP Setup screen is not displayed or you closed it, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    3. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  7. In the MP Setup splash screen, click 'Install MP Toolbox.'
  8. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  9. At the MP Toolbox Setup dialog box, click 'Finish'.
  10. Confirm the MultiPASS is turned on.
  11. Connect the USB cable to the MP730 and computer USB ports. Windows will detect the printer and proceed to install the driver files.
  12. Your MultiPASS includes additional software applications that you can install now or at a later date. To install the software, click 'Install Utility Software' and then proceed through each installation.
You can also download the drivers by visiting the below link and selecting your operating system.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9035#DownloadDetailAct
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Loopback failed - 127.0.0.1 blocked - web page test not possible
Please explain:
Does it work if you use http://localhost?
Does it work if you use http://127.0.0.1?
If the first one does not, but the second does, it is possible that the issue can fixed simply by selecting.
IE-->Tools-->Options--> Connection --> LAN Settings Check Bypass Proxy for local addresses
If you can't telnet into your computer, make sure you have the Telnet service running :
  1. Click Start, then Run, and type "services.msc" (without quotes) and click OK.
  2. Find the "Telnet" service, right-click and select Properties, select "Automatic" instead of "Disabled" in the startup type box.
  3. Click Apply.
  4. Right-click the "Telnet" service and select Start.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
May 19, 2009 | Zyxel Prestige 600WH Wireless Router...
It takes my PC a very long time to boot up, what can i do?
If you have installed any softwares recently it might slow down the pc as many softwares will install a startup file in order to start faster. You can shut these programs from starting up when the pc starts.
I put 2 steps to resolve this in order of simplicity.
Remove icons from the Startup folder
Some programs open with a shortcut icon in the startup folder (Startup icons). Use the following steps to show any startup icons that might be hidden and remove startup icons from the startup folder:
NOTE: Removing items from the Startup folder does not uninstall the software program.
1. Right-click the Start button, and click Explore . The Windows Explorer window displays with Start Menu already selected.
2. Click the plus sign ( + ) next to Programs .
3. Click Startup . The shortcut icons are listed in the right pane of the window.
4. To show any hidden icons, click Tools , click Folder Options , and click the View tab.
5. Click Show hidden files and folders (Windows XP/ME) or Show all files (Windows 98), and click OK .
6. Click an unwanted startup item in the right pane of the window and drag it to a blank area on the Windows desktop. Release the mouse button to drop the icon onto the desktop.
7. Continue dragging unwanted icons until all unwanted startup icons are on the desktop. Click Yes to any window that display asking to confirm the removal of a read-only file.
8. Close Windows Explorer and restart the computer for the changes to take effect. Delete the startup icons that were moved to the desktop after you are satisfied with the way the software programs are working.
If you find that a particular software program should not have been removed from the Startup folder, double-click the startup menu item to open the Startup window. Then drag the icon from the desktop back into the Startup window.
Jan 11, 2009 | Compaq Presario 5000 PC Desktop
Error unabling access to printshop pro 20
TPS Window Appears on Print Shop® Splash Screen Description Solution When attempting to open Print Shop® 20, a TPS window opens on the Print Shop® splash screen. The only option available in the small TPS window is to click OK. This issue occurs when Microsoft® .NET Framework 1.1 has been uninstalled. Reinstalling Microsoft® .NET Framework 1.1 will resolve this issue. View the remainder of this technical note for the instructions. Complete these steps:
  1. Close all windows and programs and return to the desktop.
    NOTE: If the TPS window is still open on the desktop, click OK. The Print Shop® splash screen will close.
  2. Insert the Print Shop® 20 DVD or Install CD into the proper drive.
  3. Double-click the My Computer icon. For Windows® XP, click Start and click My Computer.
  4. Right-click the CD/DVD icon that represents the drive where the disc was placed and click Open. The contents of the disc will display.
  5. Double-click the Setup folder.
  6. Double-click 1033dotnetfx.exe. The installation of Microsoft® .NET Framework 1.1 will begin.
  7. Review the License Agreement, click to place a dot by "I Accept" if the agreement is accepted and click Next.
  8. Click Install to install the Microsoft .NET Framework 1.1.
  9. When the "Installation of Microsoft .NET Framework 1.1 is complete" message appears on screen, click OK.
  10. Launch and use Print Shop® 20.
Dec 03, 2008 | Broderbund PrintShop Pro Publisher Deluxe...
Acer welcom window frozen in centre of screen.
need to boot up in safe mode or if you have your systems disk load it in and boot up and do a repair or just start it up and close out and reboot with out the disk
Jan 10, 2008 | Acer Aspire 3050-1733 Notebook
Startup
here try this ok?
richard from chicago and let me know if it works for you ?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00273968&cc=us&lc=en&dlc=en&product=311255
Issue After installing the all-in-one and restarting the computer, the following Generic Host Process for Win32 Services error message displays: Windows has shut down a process for Win32 services: Data Execution Prevention - Microsoft Windows To help protect your computer, Windows has closed this program. Solutions The following solutions should be tried in the order they are presented. If the first solution does not correct the issue, proceed to the next solution; if that solution does not correct the issue, proceed to the last solution. Solution one Uninstall and then reinstall the software using the following procedure:
  1. Uninstall the software by inserting the software CD that came with unit into the CD-ROM drive on the computer. NOTE: If the startup screen does not appear, double-click the My Computer icon, then double-click the CD-ROM icon where the all-in-one disc is inserted. Choose the Uninstall option. If the Uninstall option does not display, the software is not completely installed. Proceed to step 2.
  2. Install the software by inserting the software CD that came with unit into the CD-ROM drive on the computer. NOTE: If the startup screen does not appear, double-click the My Computer icon, and then double-click the CD-ROM icon, where the all-in-one disc is inserted. Choose the Install option.
  3. Run the Software Update from the HP Director and apply all patches.
Solution two
  1. Uninstall the all-in-one software using the CD that came with the unit, by following the steps in Solution one above.
  2. After the software is uninstalled, restart the computer.
  3. Install the all-in-one software by following the steps in Solution 1 above. After installation is complete, verify that the unit works correctly.
  4. Change the Windows Image Acquisition (WIA) service from Automatic to Manual by performing the following steps:
    1. Right-click My Computer , then select Manage . The Computer Management window opens.
    2. in the Computer Management window, click the plus ( + ) sign next to Services and Applications .
    3. In the list below Services and Applications , select Services .
    4. In the right-hand side of the window, right-click Windows Image Acquisition .
    5. Select Properties .
    6. Change Startup Type to Manual .
    7. Click OK .
    8. Close the Computer Management window.
  5. Add hpqtra08.exe to the Windows Firewall Exception list by performing the following steps:
    1. Click Start , then Control Panel . (Click Start , Settings , then Control Panel if you are in Classic Start menu mode).
    2. Click Security Center .
    3. Scroll to the bottom of the new window.
    4. Click Windows Firewall .
    5. Click the Exceptions tab.
    6. Click Add Program .
    7. Click Browse .
    8. Select C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe .
    9. Click OK .
    10. Click OK .
    11. Close all open windows.
    12. Restart the computer and verify that the unit works correctly.
Jun 12, 2007 | HP Officejet 5510 All-In-One Thermal...
Change hotsync
Changing back to Palm Desktop Software from Outlook with Tungsten E 1 Place the Installation CD that came along with your handheld onto your cd-rom. Wait for it to load after which you’ll see a splash screen with different menus. Note: If the cd does not automatically load, double click on my computer then click on the cd-rom drive icon and finally click on the first icon (looks like a cd) labeled ‘autorun’ 2. Select ‘Install Microsoft Outlook Conduits’ 3. Click on ‘Install’ 4. Click on ‘Yes’ 5. Click on ‘Yes” 6. Click on ‘Ok’ 7. Click on ‘Back’ 8. Click on ‘Exit’
Sep 11, 2005 | Palm Tungsten E Handheld
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
126 people viewed this question
Top Zebra Computers & Internet Experts
pkwc
Mike
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
