Question about Samsung HT-DB120 System
Shema de dvd ht db 120
Probleme protection
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: my DVD HT-Q9
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Mi HOME THEATER WITH DVD HT-X1 dice protect y se apaga
Mi HOME THEATER WITH DVD HT-X1 dice protect y se apaga. q debo hacer
Jan 04, 2012 | Sharp HT-X1 System
How do I shut of the Protection on the Samsumg HT TP-33 in order to play a DVD
If you mean the unit is self protecting due to a short or overload, disconenct all the speakers and see if that helps, then troubleshoot the cause. Otherwise, it needs service.
http://www.retrevo.com/support/Samsung-HT-TP33-Home-Theater-Systems-manual/id/357dj788/t/2/
Then there's this....
Copy Protection
Many DVD discs are encoded with copy protection. Because of this, you should only connect
your DVD player directly to your TV, not to a VCR. Connecting to a VCR results in a distorted picture
from copy-protected DVD discs.
• This product incorporates copyright protection technology that is protected by methods claims of certain
U.S. patents and other intellectual property rights owned by Macrovision Corporation and other rights
owners. Use of this copyright protection technology must be authorized by Macrovision Corporation, and
is intended for home and other limited viewing uses only unless otherwise authorized by Macrovision
Corporation. Reverse engineering or disassembly is prohibited.
Dec 26, 2010 | Samsung HT-TP33 Theater System
Samsung HT-C550 The DSP/EQ or the Dolby Pro Logic II Mode buttons won't work. No change on faceplate display. Any help would be appreciated.
I had the problem and after pressing the DVD Receiver\DVD button to no avail went back to setup and turned the ASC Setting to off. Apparently I had forgotten to turn it off after doing the Auto Calibration.
Hope this helps.
Dec 06, 2010 | Samsung HTC550 Theater System
Samsung httz322 unlock dvd codes region free
Como hago para liberar la zona de un reproductor Samsung ht-tz322 es de zona 4 original, pero ahora no me lee nada. Gracias!
Jun 01, 2010 | Samsung Televison & Video
Samsung ht-x30 sutting down protection error
My samsung shuts down with "PROTECTION".Help me to solve the problem.David ilomo.
Dec 05, 2009 | Samsung Audio Players & Recorders
My DVD HT-Q9
Bad speaker wiring.
Internal fault.
Regards.
Sep 23, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Problem "protect"
Hey guys, just had the same problem and found out it was because I had disconnected the central speaker. This it was creating a back impedance or something and reonnecting did the trick! i.e. check your speaker connections and check that they work... duff speakers could cause the problem too!
Sep 20, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Digix Ht-1056A Chapter Pause Problem
Tu home theater tiene karaoke integrado? Si es as?, ve al menu del aparato, dirigete al submenu audio y apaga (off) la opci?n "Semi Karaoke".
Eso deber?a de resolver tu problema ya que es com?n en algunos modelos LG con karaoke integrado.
Sep 14, 2006 | Digix HT1056A 5.1 Channel DVD-Home Theater...
Samsung HT-DB120 System Logo
27 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
