Question about InFocus "IN5534 DLP Projector"
Hot to replace the fan in Infocus IN5534 Projector
How to replace the fan
cammykins
  • 149 Answers
SOURCE: infocus sreenplay projector
Contact the manufacturer for a firm ware upgrade. My two brother in laws/sisters own this same pj and had the same issues you are talking about. Once they installed the update [aka: firmware upgrade]it created a solution to the problem.
Let me know how it goes. They can either mail you a CD, direct you to where on their website, otherwise email you the update to download. You have to connect your pj as well.
Let me know how that goes. I'm fairly confident that will fix it. There was a certain time frame [manufacturer dates], and serial numbers that had these issues.
Posted on Oct 27, 2008
projdoc
  • 2237 Answers
SOURCE: LP70 Infocus Projector light will not start up
if you don't hear a high-pitched whir, the colorwheel needs to be replaced. if you do, it's either the lamp or ballast. if the lamp is new, replace the ballast. you can get the parts if you want to do it yourself, or you'll have to send it in. either way, try av solutions in ny. they are an infocus service center and they're really good. www.avsolutionsny.com
Posted on Nov 25, 2009
projdoc
  • 2237 Answers
SOURCE: InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Posted on Dec 09, 2009
projdoc
  • 2237 Answers
SOURCE: its an Infocus screenplay 5700 projector.it is not powering up
replacing the main board.
Posted on Jan 27, 2010
  • 74 Answers
SOURCE: infocus IN36 projector will not turn off
Try a firmware upgrade.
Posted on Apr 15, 2010
Fan fail in1110
You should check first the fw version. Tha last fw version is v 3.2.4. if the fw is updated it, replace de fan, if fan is ok, replace ECA controller. InFocus IN1100 Projector
Apr 01, 2014 | InFocus Corp. Open Box InFocus IN1110...
InFocus IN5534
how replace lamp in5534
Oct 25, 2011 | InFocus IN5534 Projector
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Projector shows briefly and cutsl off
    are you sure it's the fan? if the lamp cuts out and the fans still run, the problem is the colorwheel. if you are sure the fan is not moving, it will need replacing, but there is no fan sensor that would shut the projector down if the fan does not spin. there is, however, a temperature sensor that'll shut it down if it gets too hot. wheather it's the fan or the colorwheel, clean the dust out of the projector with canned air to help prevent overheating. then get the parts from an infocus service center and replace them yourself, or send it in for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
    Dec 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
    Our Infocus sp5000 is shutting down because it is getting too hot. We had just cleaned the filter.
    you also need to clean out the machine with canned air. also check to see that all of the fans are running. if they are not all running, they need to be replaced. also, the temp sensor near the lamp housing may also need replacing.
    Oct 24, 2009 | InFocus SP5000 Home Theater Projector,...
    The bulb on X1 blew out, I replaced the bulb, the
    it's the fan. if it won't spin full power, it can't cool down the projector and it'll shut down. there are 2: 60mm (part # 526-0153-00) and 80mm (526-0152-00). both can be purchased from infocus or an infocus service center.
    Aug 10, 2009 | InFocus X1 Multimedia Projector
    Bought a replacement lamp for Infocus SP7205. Lamp works fine. But the fan intermittently will come on at high speed for 5 seconds, then turn off, then do it again a minute or two later. Slightly...
    I seen this problem with lamps that are not from infocus. I would recommend to replace it with the old lamp fan. if you still have it. I'm not sure why it does this.
    Apr 25, 2009 | InFocus Lamp Projector Lamp for LP650,...
    Projector getting too hot
    comman to a projector to get hot in front and top center part
    but not at the rear side
    this might be
    fan not working
    filter need to clean
    bulb life getting lower
    open the cover check safety paper
    might be burn out
    replace new one.any hard paper
    Jul 10, 2008 | InFocus Proxima DP6155 Multimedia...
    InFocus LP725 light goes out after 10 minutes
    The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
    Check the projector’s lamp to ensure that it is securely connected
    in the lamp module. Make sure by removing it and reinserting it.
    Check the cables for problems.
    When testing, power up in this order. Projector, Computer monitor, Computer.
    A minor power surge may cause the lamp to shut off. Turn the
    projector off, wait at least 30 seconds, then turn it back on.
    I hope these suggestions help
    Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
    InFocus "IN5534 DLP Projector" Logo
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
