Question about Home
Blower Fan runs after power outage
Napoleon Direct Vent Millivolt System, Model GD36NTR, Serial No Gd/CDV36-12407. After a power outage the Blower Fan runs until it is disconected from electrical outlet located inside the fireplace. The Remot Model Acumen TX-H will not reset the Blower Fan only disconnecting and reconnectiong the electrical plug resets the Blower. Consequently Blower Fan will run for weeks if we are away from home. Have previously installed surge protection of fireplace circuit but problem still exists. Could a thermal switch be missing or defective / missing. How can I identify this component on this fireplace? Thanks
  • Ian Paterson
    Ian Paterson Nov 24, 2013
    This is a problem related to a Natural Gas Fireplace manufactured by Napoleon. It is not Computer or Dryer related.
3 Suggested Answers
SOURCE: Casablanca fan is not working!!
The controler board has gone out due to either a power surge, overheating or too much wattage in the lamps. There are two types of of controlers and both are subject to this kind of failure. Here's a troubleshooting link
http://www.lampdepot.com/service/intellitouch.htm
Posted on Jul 09, 2008
  • 4234 Answers
SOURCE: Onkyo TX-NR905 Protection Circuit Activated
The problem is not with the inputs. This unit is in protect because a problem has been detected in the output section. Try disconnecting the speaker wires and turning it on. If the unit remains on, there is a short in one of the speaker wires. If the unit still shuts down, there is an internal problem that will require repair. It sounds like this is a new piece. If so, it should be covered under warranty.
Keep us posted,
Dan
Posted on Jul 28, 2008
Blower don't work
did you check for proper voltage at motor itself??? if none work your way back from motor till find voltage and what component is not allowing voltage to pass
Nov 12, 2013 | Empire Direct Vent Wall Furnace Millivolt...
Rudd silhouette ii blower
Send direct power to the blower by bypassing relay . See if motor runs
Jul 19, 2017 | Ruud UBHC Air Conditioner
Need a blower
My guess is that you will need a GZ550 found HERE.
Alternatively, you could use a universal fan kit like THIS ONE.
The universal fireplace fan kit will be an easier installation and utilizes an electronic speed control.
Nov 25, 2012 | Napoleon 36" Zero Clearance Top/Rear Vent...
Toyostove Laser 73 has EE8 code after we had an electrical outage. The blower fan is not stuck. Could the loss of power damage the fan motorr? Where do we purchase a new fan motor?
Probably wasn't so much the loss of electric power, as it was perhaps, a surge when it came back on that could have damaged the fan motor
You should be able purchase a new fan motor from the dealer your bought the heater from. Or if that's not an option, go to http://www.rinnai.us/ and search for a authorized dealer close to you. That way, you can be sure you're getting an OEM part.
Hope this helps resolve your problem.
Feb 26, 2011 | Rinnai Toyostove Direct Vent Heater:...
Have a Duo Therm 59516.531 15000 BTU blower motor does not run checked cap 5mf ok tried direct power still nothing any thought. thanks
if you tried direct power and still nothing then your fan needs to be replaced . there should be a a/c supply store near you . get the model - serial number on the fan or the unit itself to get the right fan for your unit . hope that helped
Jul 01, 2010 | Dometic 57915531 Air Conditioner
Empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
Derect vent
no its not possible because the direct vent piping is a special inner/outer variety
Oct 03, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Toyostove Laser 73
There are 2 fuses on the mother board. You can go to the Toyotomi website download the Owners Manual and look at 49 and 50 in the parts list and picture.
Mar 05, 2008 | Rinnai Toyostove Direct Vent Heater:...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
