HOW TO CLEAN A LASER ON A PHILLIPS AZ2555
CANNOT READ DISCS DISC ERROR NF
  • 281 Answers
Open the CD tray and use a dry soft cloth, the type of cloth you usually get with spectacles, to clean the lens gently. Don't apply pressure, just brush off the dust, if any, from the lens. And if the set is pretty old, chances are that the lens is defective.
Posted on Nov 23, 2013
Ps2 disc read error
often as not, it's the disks, not the console. check the disk condition for fingerprints and deep scratches
Dec 03, 2014 | Sony PlayStation 2 (PS2) Console
PHILLIPS AZ2555 CD STOPS READING AT 2MIN. THEN STARTS READING AGAIN .
Hi
The Cd lens moves along a threaded wind you may find this has been damaged or some build up of dust is interfering
just take a look with a torch just into the gap in the guide tracks and see if anything is stuck, failing this, try f/f and rew many times this may clear anything in the way into and back into the 2 min zone
but if you are getting discs that load very slowly it may well be the lens failing too
cheers
Nov 22, 2013 | Philips AZ2555 CD Boombox
Unable to read the disc despite cleaning (brand new disc) and putting in correct way still unable to read
You need to replace your laser. Pretty easy and cheap lasers on ebay are around $10. Youll need a tri wing screw driver and small phillips head screwdriver.
Dec 26, 2010 | Nintendo Wii Console
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    My phillips HTS3090 system keeps saying BAD DISC
    for some reason the unit is not happy with the disc have you tried running a lazer cleaner through it? although i wonder if that will work as the words bad disc does seem to mean a lazer read problem but then it can only be either a dirty lazer or the lazer is miss aligned withch means it need s a pro service .... try cleaning the laser
    Jul 03, 2010 | Televison & Video
    I have an ilo dvd ro4 and when I put a disc in it says invalid disc
    Laser is either dirty or starting to wear out.It may also not be a compatible disc,not all brands of discs work in this model.The unit records on R+Rw+ discs 4x speed or slower.Variable speed discs1x-16x will also work.
    Most of the time it is just a dirty laser that can read the disc,to clean laser use a commercial laser cleaning disc,Phillips and Maxell work well in this model.Put a drop of rubbing alcohol on cleaning brushes.
    Jul 06, 2009 | iLO DVDR05 DVD Recorder
    Cannot read disc
    If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide...
    Mar 29, 2009 | Nintendo Wii Console
    Disc error when reading dvd
    try to clean dvd plaer lens with a lens cleaner...
    Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
    Wii won't read disc?
    you might have to clean the laser gat a laser cleaning kit from somewhere (should work if not take 2 a shop)
    Jan 10, 2009 | Nintendo Wii Console
    Computers & Internet Logo
    49 people viewed this question
    David Payne
    David Payne
