Question about Dyson Bagless Upright Vacuum DC41 Animal
Does not suck when upright
Just changed the filters & i'm not sure if this is the reason. The hoover will not **** from the base just the nozzle part. There doesn't seem to be a blockage and it seems to be something to do with the round part near the base as its feeling too hot.
  • 28 Answers
If it\'s in the full upright position then it is designed to change the airflow from the base to the nozzle. Likewise if it is only slightly out of the full upright lock position it will suck through the base and not the nozzle.
Hope this helps.
Posted on Nov 22, 2013
How do I fix my hoover that is not sucking up anything?
With your model tempo, the hose needs to be connected to the tube in the back (should have a door cover that flips open). Also check the suction path and change the bags or filters if needed
Aug 31, 2014 | Hoover Tempo Widepath Upright Vacuum -...
Just seems to blow bits around rather than suck
Hi, it's Allie from Crucial Vacuum.
There are a few things that may be causing your vacuum to lose suction. When filters need to be washed or changed, this may cause a loss in suction. Depending on the use of your vacuum, filters need to be changed every 3 to 6 months. If your unit has washable filters, these should be cleaned every 2 to 4 weeks, to maintain the highest filtration and suction in your unit.
If the filters have been properly changed and/or washed, the problem may be caused by a clog in your floor nozzle hose. Most upright units have short hose that connect the floor base to the motor, this hose can easily get clogged and cause loss of suction. You may check the hose by un-clipping it from your unit and cleaning the inside with a damp cloth.
If the problem still persists, you may need to check your unit's brushroll, also known as roller brush or agitator. Check to see if your brushroll is spinning properly, if it has any hair strands tangled or any debris remains that is preventing it from running properly.
You can purchase direct your replacement Hoover vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Aug 13, 2014 | Dyson Dc50 Ball Multi-Floor 2-Tier...
Vacuum not clogged but has low suction
Check all the pipes, there could be something stuck in them which hasn't come out.
Also check the base of the vacuum if there is something stuck in the base.
Lastly check if there are any leaks in the pipes.
Also check the suction without using the handle, by pulling the pipe in your hand and see if it has more suction.
Apr 28, 2014 | Hoover U6630-900 WindTunnel Bagless...
Belt is strech doese not pick up diert
Hi! The brushes are needed to spin on carpet to agitate the carpet fibers and assist the motor with maximum pick up. If the belt is stretched you will need to replace it. This unit takes belt 562633001. Below are step-by-step instructions for replacing the belt on your Nano.
1. Lay the cleaner flat and flip it to expose the
nozzle base. The base should lay flat and face up.
Remove the five (5) screws.
2. Pull and lift the nozzle guard off.
3. Lift and remove the brushroll. Dispose of the
old belt.
4. Slide belt onto motorshaft.
5. Place new belt in area of brushroll without
bristles.
6. With new belt in place, pull and slide brushroll
into nozzle making sure that the brushroll end caps
are in the correct orientation. Rotate brushroll
manually to make sure belt is properly aligned.
7. Reattach nozzle guard.
8. Secure by aligning the three tabs in the
base slots.
9. Replace all five screws to secure nozzle guard.
Follow the link to order a replacement belt for your vacuum. Flat Belt Nano Upright
Hope this helps!
Mar 04, 2014 | Hoover Nano Cyclonic Compact Bagless...
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Its blowing instead of sucking
Make sure the removable panel in front of the recovery tank is pushed down tight. I had the same problem and that's all it took.
Aug 01, 2009 | Hoover F5906-900 Upright Steam Vacuum
Hoover Upright Steam Vac, 12 amp
  • Check to make sure that the lower dirty water lid is installed and secure and not cracked.
  • Check to make sure the front duct panel is installed on the dirty water tank (this will transition the water from the front nozzle into the tank)
  • Check the filter in the dirty tank lid, clean if necessary
  • Remove the lower tank and look at the motor cover, locate a round hole, you should see a black ring (gasket).
  • with the lower tank removed, turn the machine on to check suction at the round hole, if OK then your problem will be with one of the above reasons
Jan 12, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dirty water is leaking back out
After shut off all steamvacs will leak dirty water that was sucked up back out. There is always some left in the nozzle. If it is a large amount there is clogged filter that isnt allowing the proper suction. Refer to your manual or go to hoover.com to download one for cleaning directions.
Jan 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Low Suction
Empty the recovery tank; it may be full
and the automatic shut-off engaged.
Make sure filter and filter lid are properly
positioned.
Make sure tanks are locked in place.
Check the filter and clean if dirty.
Make sure nozzle is replaced properly
and locked
Apr 30, 2007 | Hoover H3030 FloorMate SpinScrub 500...
Won't suck up water from floor
1. Check all the tubes from the nozzle to the collection tank and make sure they are not clogged up. I've had tht happen pretty bad before. 2. Check the squeegee. If it is damaged or torn, replace it.
Aug 27, 2006 | Hoover Floormate H3000 Upright Wet/Dry...
Dyson Bagless Upright Vacuum DC41 Animal Logo
55 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
