Question about Invacare Mk6 Mpj Ts1136885 Joystick Controller
Mk6 mpj joystick got went and wont turn on - Invacare Mk6 Mpj Ts1136885 Joystick Controller
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
Hello,please visit:www.Invacare.com & where better to be (the Manufactures).I hope this helped,Colin
Posted on Jul 10, 2014
Ford transit 20. td mk6, engine just cutout, turns over fine but wont start any ideas and yes plenty of diesel in the tank.
If it is cranking, starter and egnition are fine, it could be fuel pump, If you can get someone to turn egnition ON, while you put your ear as close as you can to the fuel pump maybe the back seat or in the trunk, you should hear it humming, means its working,
Feb 26, 2017 | Ford Transit Cars & Trucks
What do i do..mk6-mpj invacare joystick got wet and wont turn on
Hi, you can send it to me for testing , free , you only pay for the postage back...(UK only)
Regards
Rob
www.gewizrepairs.co.uk
Nov 22, 2013 | Invacare Mk6 Mpj Ts1136885 Joystick...
Joy stick malfunction, error messages
hi, it could be that there is a small amount of water still in there, Please remove the unit and place where you dry your cloths etc? somewhere warm but not hot, warm and dry only, now leave for 24 hours. Also check the cable connections making sure they are clean and fit well.
RegardsGeWiz.
Feb 12, 2013 | Invacare Mk6 Mpj Ts1136885 Joystick...
Fisher plow gets power to lights but wont lift or turn, Any ideas?
Fisher needs a good contact loose contact start from the battery and work your way around everywhere theirs a connection
Dec 28, 2012 | Fisher Minute Mount Plow Joystick...
My chair wont stay powered on .you turn it on it goes off
If it just started to do this it could be no more than a losse connection from your joystick cable . Go ahead and follow that cable from your joystick all the way down to the back of your chair make sure everything is connected.
If that checks out ok it could be your on off button .Thats on your joystick it may be ''sticking'' if you have to press down really hard to turn on the chair .Than yes this is the problem .you can go to Pridemobility.com I do think they are selling just the "Three key pad '' for your joystick. so you dont have to buy a new joystick.
If that checks out ok ,It could be your batterys are not fully charged or charging ,whens the last time you charged it,did it charge fully .That could cause your problem too
well hope i was helpful ,good luck
Jan 19, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Have a Pronto m91 power chair. Suddenly stopped operating. At power up - two red LED's flash seven times then repeat. Have visually inspected inside electronics of Joy stick with no visible problem -...
Sounds like you are on the right track with your problem solving. Unfortunately you cannot determine an electronic fault by visual inspection of the components. You can see cuts, nicks, broken wires and burnt components, but this only works sometimes.
I look at the current fault code with a hand held programmer (HHP). With a HHP you can read the fault log and check out all the stored codes to get an overall idea of the history of chair problems. The 7 flash code is definitely a remote fault. You can also get this fault with a bad connecting cable between the joystick (remote) and the controller (in the base). Check this connecting cable for breaks, cuts, loose pins or connections and check the connections at both ends. You can do continuity and component checks of the remote with a digital voltmeter, but this is out of the realm of most end users.
I am assuming you have MK5 or MK6 electronics in this discussion.
The easiest test is to swap out the joystick with a known good one that either a tech has brought to your home or you have brought the joystick in to a service center for testing. The better test is with a HHP that will give you the current problem and stored information of past problems.
Weak batteries or loose battery connections can also give a myriad of electronic faults. For this reason I always check the batteries and battery connections first.
The joystick can be rebuilt, but I recommend replacement as a more cost effective solution. I always replace the joystick to controller cable too. Labor charge for this work is under 1 hour.
I can provide further information if needed. Hope this helps.
Dec 02, 2010 | Invacare Supply Group Invacare Pronto M91...
Both my joystick are not working
Try Other Games... If That Still Doesn't Work Loan An Additional Joystick Just To Check If It's Joysticks Fault, If The Additional Joystick Doesn't Work Then It Must Be A Broken Port Or Something...
Nov 21, 2009 | Sony PlayStation 2 (PS2) Console
I tried 2 plug it in 2 my pc went through the installation still wont work HELP ME
go to control panel>game controller>properties
test the joystick if it does not register or the device is not present in the game controller window. try on second pc if it repeats the issue call logitech for out of warranty discount.
Jul 13, 2009 | Logitech Attack 3 Joystick
ST220 Joystick calibration problem
Your joystick contacts make that +cursor to make a crazy movement. You should replace that rubber contact on your joystick.
Aug 07, 2007 | Saitek ST220 (J-30U) Joystick
Invacare Mk6 Mpj Ts1136885 Joystick Controller Logo
100 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
