Question about Amana ABB1927DE Bottom Freezer Refrigerator
Indesit fridge/freezer starting & stoping
Indesit fridge freezer compressor stopped
    Champion:
    Habit-Forming:
  • 279 Answers
The compressor is supposed to start & stop, it wont run all the time.
Posted on Dec 02, 2013
davidpsr
  • 222 Answers
SOURCE: Working fridge, warm freezer.
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Posted on Aug 29, 2009
  • 358 Answers
SOURCE: my compressor stoped working and it got hot and
If the fan was the problem and the compressor is now running , it should start getting cold.
Posted on Oct 17, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have amana bottem freezer,1 month ago i
Hello, Unfortunately the compressor likely is seized now. There are a couple of reasons that the original start device failed, 1) faulty connection. 2) poor quality part. 3) compressor was running non-stop due to other deficiencies in the unit or 4) the compressor was failing to begin with. The compressor may indeed check out ok as far as electrically ( windings ) but the mechanical component ( rotor ) has locked/seized up. You can determine whether it is the windings by checking the ohm value between common to start, common to run and run to start ( c-s, c-r, r-s ) and look for values similar to 6ohms, 3ohms, & 9ohms. Then check the start and run & common windings against the compressor casing to see if windings are shorted. In order to double check the mechanical component you'd need another hard start, ( or a test cord direct to 120vac, but that should only be done by an experienced tech ). nothing else will start it at this point obviously or you wouldn't be using a hard start already. The other unfortunate issue is this, many of these compressor's have a 10yr. parts only warranty but that was voided as soon as the 3in1 hard start was installed. In the end I'm likely not telling you anything you didn't already suspect or know in fact, but it is likely the compressor. I sympathsize, seized compressors **** ! Hope this answers your question and moves you forward. good luck macmarkus :)
Posted on May 08, 2010
heatman101
  • 43501 Answers
SOURCE: fridge & freezer warm , temp control panel
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Feb 25, 2011
  • 3 Answers
SOURCE: compressor or fan runs constantly. Fridge & freezer are (too) cold.
thermostat faulty, or maybe defrost timer/heater not working
Posted on Sep 25, 2012
Why freezer not working on indesit fridge freezer
is your fridge working or is the compressor running.
May 27, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
My indesit frige freezer has just stoped working come hope and the freezer has defrosted and the fridge isnt cold but lights still working
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Apr 24, 2011 | Refrigerators
Admiral SAC224GB Fridge freezer has stoped working
when did this happen... could be your compressor out on overlaod... leave it for an hour or so try them, if not your compressor could be gone.. or fingers crossed its just the start capacitor for the compressor...
Nov 11, 2009 | Refrigerators
My compressor stoped working and it got hot and
Oct 16, 2009 | Amana ARB2217C Bottom Freezer Refrigerator
The fridge side by side door. Freezer & fridge stop working I can hear the motor trying to go but doesn't cool
When you say motor I assume compressor. No start compressors can be an electrical component like the start relay or the compressor itself. Eric
Jun 14, 2009 | Frigidaire FRS3R5EMB Side by Side...
Fridge is running but won't get cold
if it have one compressor the gas in the system are low . but if it have 2 compressors the thermostat can be the problem
Jun 01, 2009 | Refrigerators
Refrigerator and freezer not cooling
the relay on your compressor is more then likely the problem it is on the left of the compressor
Jan 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Indesit fridge/freezer model ban 12nf the fridge has stopped getting cold but the freezer is cold and the compressor is working its frost free but suspect it might be frozen and stopping the air flow to...
numerous faults can cause this - faulty defrost timer or module, open circuit defrost heater, open circuit thermal cutout, internal wiring, faulty defrost sensor etc
Nov 28, 2008 | Refrigerators
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Amana ABB1927DE Bottom Freezer Refrigerator Logo
137 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
