Question about Campbell Hausfeld Air Tools & Compressors
I need the assembly diagram for a pressure control switch Mod LF10-4H
I took a Lefod Mod LF10-1H Pressure Control switch apart and I'm now looking for a diagram on how to put it back together.
You silly person you should not have taken it apart if you are not capable of doing the job
Dec 18, 2015 | Washing Machines
Unit has developed a continuous leak
need to replace pressure switch as the leak is a worn needle valve assembly. it usually unloads from there when the machine stops
Sep 06, 2012 | Clarke Power Products Inc AC2001 2HP 4...
06 srx sunroof doesnt work
Sorry Bill but you don't the tool's or knowledge to take on this job . Control module's involved.
Which one does your vehicle have ?
Power Sunroof System Components -- CF5
The power sunroof system consists of the following components:
• Front glass control module and motor assembly
• Front sunshade control module and motor assembly
• Sunroof switch
• Front glass panel
• Front sunshade
• Power supply for the front glass control module and motor assembly logic: RAP relay
• Power supply for the power sunroof system: SUNROOF MOD fuse 40 A
Power Sunroof System Components -- C3B
• Sunroof switch
• Front glass panel
• Front sunshade
• Rear sunshade control module and motor assembly
• Rear sunshade switch
• Rear sunshade
• Rear fixed glass panel
Aug 30, 2017 | 2006 Cadillac SRX
I need a wiring diagram for a 1998 Chevy Blazer fuel pump
The fuel pump assembly consists of fuel pump relay,fuel sensor,the fuel pump controlling fuse,its ECM B fuse. The fuel pump and oil pressure switch. ----------- For its wiring diagram, click the link below and refer the diagram:--- http://technoanswers.blogspot.com/2011/10/fuel-pump-wiring-diagram-for-1998-chevy.html ----------- This should help.Thanks.Helpmech.
Oct 06, 2011 | 1998 Chevrolet Blazer
I have a Kenmore Mod 23932200. It will not stop filling and then begin agitating. I took the top off to check the rubber tube that is supposed to l control the filling and then agitating. It is...
you have a bad pressure switch,,,that pressure hose that you followed up to the switch replace the switch its connected to...one side of the hose goes to pressure switch and the other side goe to a nib on the outter tub...
Aug 29, 2011 | Kenmore Washing Machines
How to install presure switch
Hi.
The pressure switch is located behind the control panel. Its unction is determining the level of water in the washer.The switch looks like a round shaped plastic switch connected to wires and to a long thin rubber hose. To replace the switch disconnect power. Undo the screws holding the control assembly. Remove control assembly cover. Disconnect wires from switch and undo the screw holding the switch. Pull out the rubber hose from the tub and perform operations in reverse order to install the new part.
The switch is part nr.4 in diagram below. Click on the picture to enlarge:
Jul 07, 2011 | Maytag MTW5700TQ Top Load Washer
I have a Kenmore top loader washer Mod. 110.23032102 Ser. CP2326922 The problem with this one is that when the end cycle is finished the clothes are still wet. I actually watch the whole cycle all the...
Hi.
As first thing you should have checked the pressure switch. Test jumping the pressure switch. The switch determines when the drain part of the cycle is complete and turns off the pump to proceed to spinning phase. When the pressure switch is bad it will cause this problem.
If problem is the switch, before replacing the part you can try checking the hose attached to the switch and blowing into the pressure switch to remove eventual blockage.
If that is not the problem , then check gearbox, clutch and finally timer assembly, but those would be less common faults causing no spin.
Here parts and diagrams.
Here pressure switch: Water level switch.
Regards.
Mar 21, 2010 | Washing Machines
Whirlpool Mod # LSB6200KQC continues to fill with
The water level is controlled by the pressure switch which is located behind the load level selector knob on the control panel. There is a small clear plastic hose that attaches to the pressure switch that senses the pressure change from the wash tub as the washer fills. This change in pressure is what will determine when the pressure switch turns off.
Commonly, what happens is the hose becomes detached inside the console causing the pressure switch to not work. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
Before assuming the pressure switch to be faulty, follow the advice in the link provided. What appears to be a significant problem, may just be something as simple as a loose hose. Make sure you check the entire length of the hose for cracks or leaks.
Check the electrical connections on the switch as well to make sure they are not corroded, causing no contact.
If all else fails, replace the pressure switch. Replacements can be found at appliancepartspros.com for about $21. Locate item 12 under Section 4 (Controls and Rear Panel Parts).
If you have questions, please let me know. I hope you find this information helpful.
Aug 10, 2009 | Washing Machines
Water will not shut off to begin cycle
Does the washer leak water into the tub even when it is not on. If so, your fill valve is leaking or sticking.
I would also check the following components for problems:
-Air pressure switch. This is usually located inside the control area and likely is attached to the water level control. Try attaching a small piece of tubing to the pressure switch and gently blow into it. If it turns off, the problem likely lies elsewhere.
-Air tube. This clear tube can get crimped or worn from the vibration of the washer's normal operation. Any holes, cracks or crimps will prevent the air pressure created by the water in the tub from getting to the pressure switch.
-Soap residue in the air dome. The airdome is the piece attached to the side of the washtub that allows water in the tub to exert air pressure into the tube and the pressure switch. Soap residue can create an obstruction that prevents the pressure from being transmitted up the tube. Try cleaning with vinegar or ammonia. (Remember: Clean the tub and tubing thoroughly with water after cleaning. Ammonia and Vinegar are both corrosive to electrical parts.)
Hope this helps!
May 28, 2009 | Kenmore 23822 Top Load Washer
Air Tools & Compressors Logo
51 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
