Question about Toshiba e-studio 5520c Digital Copier
Fax status 0050 - Toshiba e-studio 5520c Digital Copier
Fax receipt code shows a status code of 0050, What does that mean ?
It means there is no dial tone on the fax line, is the rj11 plugged in properly [ (Line) on the copier, not he one labeled as (TEL) ], is the telephone patch defective, or you have an active phone on the wall jack, (test it it with an ordinary phone), or the receiving party is busy, try later, or try a different nunber.
May 05, 2014 | Toshiba E-Studio 206L Copy Machine
FAX NOT SENDING
make sure your connected in the right plug one is for a hand set also see if your getting a dial tone could be bad line if that checks ok then replace lcu pcb
Jan 09, 2013 | Toshiba E Studio 2330C
How to clear the job status memory on the Toshiba eSTUDIO 305 Machine
if there is a username and passowrd you log in. then at the bottom right of the screen you will see a job status button. if you press it it usally opens up to the jobs list .. if not after you press it look on the top of the display and select job status or print status. the select the job you want to delete and press delete.
NOTE: if your machine has a fax you cannot delete fax jobs without doing an all reset!
Sep 07, 2011 | Toshiba estudio 305 Copier
How do you find fax log for sent faxes on Dell 962 All-in-One
Only faxes sent and received by Fax Console can be seen by Fax Console. View the Status of a Fax Using Fax Console or Fax Service Management
  1. Click Start All Programs (or Programs) Accessories Communications Fax.
  2. Click Fax Console or Fax Management Services.
  3. The following folders appear:
    • Incoming - faxes currently being received
    • Inbox - faxes that have been received
    • Outbox - faxes scheduled to be sent
    • Sent Items - faxes successfully sent
  4. Click the folder of your choice.
  5. Click the fax in the right pane for which you want to view the status, and then click Preferences or Properties.
  6. Click the General tab and view the Status line.
  7. Click Close when you are finished
Mar 05, 2011 | Dell 962 Photo All-In-One InkJet Printer
No FAX status confirmation printed.
go into the fax settings (or setup) on the printer and make sure it is set to give a printed report after each fax reguardless of wether it goes through or not..
May 19, 2010 | Dell 962 Photo All-In-One InkJet Printer
Need tv library codes to connect universal media so xbox media re
Aiko 0047
Aiwa 0433, 0247, 0247, 0433, 0446
Akai 0044
Amtron 0038
Anam 0248, 0038, 0071, 0116, 0122
AOC 0005, 0022, 0050, 0062, 0126
Apex 0119, 0141, 0155, 0438
Audiovox 0038
Bell & Howell 0008, 0043
Benq 0227, 0198
Broksonic 0133, 0134, 0248
Celebrity 0044
Citizen 0005, 0038, 0047, 0055, 0062, 0085, 0156
Colortyme 0005, 0013, 0062
Contec/Cony 0248, 0016, 0019, 0038
Craig 0038, 0248
Crown 0038, 0063
Curtis Mathes 0005, 0664, 0043, 0053, 0062, 0085, 0152, 0156
Daewoo 0005, 0017, 0047, 0050, 0062, 0103, 0146, 0156, 0486, 0237
Daytron 0005, 0062, 0156
Dimensia 0664, 0152
Dumont 0001, 0005
Durabrand 0439
Electroband 0044
Electrohome 0005, 0037, 0044, 0062, 0066, 0071
Emerson 0005, 0011, 0012, 0014, 0015, 0016, 0020, 0021, 0035, 0038, 0043, 0052, 0056, 0062, 0069, 0124, 0129, 0137, 0156, 0248, 0486
Envision 0005, 0062
Fisher 0025, 0040, 0043, 0115, 0245
Fujitsu 0015, 0199, 0200, 0201, 0202, 0203, 0669
Funai 0015, 0038, 0248
Gateway 0207
GE 0664, 0005, 0018, 0032, 0037, 0059, 0062, 0071, 0074, 0104, 0147, 0152, 0248, 0469, 0488, 0489
Goldstar 0005, 0016, 0023, 0045, 0050, 0062, 0066, 0077, 0096, 0143, 0156, 0249
Hallmark 0005, 0062
Hisense 0125
Hitachi 0003, 0005, 0016, 0019, 0030, 0060, 0062, 0064, 0067, 0081, 0095, 0101, 0106, 0124, 0136, 0213, 0238, 0473, 0496, 0173, 0174, 0175, 0412, 0165, 0171, 0205
Infinity 0063
Janeil 0120
JBL 0063
JC Penney 0005, 0018, 0019, 0032, 0037, 0664, 0041, 0045, 0050, 0055, 0062, 0074, 0077, 0085, 0102, 0104, 0143, 0152, 0156, 0249
Jensen 0005, 0062
JVC 217, 0435, 0010, 0016, 0019, 0024, 0033, 0051, 0056, 0060, 0074, 0132, 0142, 0217, 0435, 0470, 0475, 0477, 0497, 0503, 0504, 0505, 0216
Kawasho 0005, 0044, 0062
Kenwood 0005, 0062, 0066
Kloss Novabeam 0036, 0038, 0042, 0120
KTV 0038, 0080, 0137, 0156, 0248
LG 0050
Loewe 0063
Logik 0008
Luxman 0005, 0062
LXI 0664, 0041, 0043, 0062, 0063, 0104, 0117, 0152, 0249
Magnavox 0521, 0005, 0027, 0029, 0034, 0036, 0042, 0055, 0062, 0063, 0066, 0097, 0098, 0222, 0522, 0523, 0524
Majestic 0008
Marantz 0005, 0048, 0062, 0063, 0064, 0249
Megatron 0062, 0064
Memorex 0008, 0043, 0050, 0062, 0249, 0442, 0525
MGA 0005, 0025, 0026, 0037, 0050, 0062, 0066, 0076
Mitsubishi 0005, 0025, 0026, 0037, 0049, 0050, 0062, 0066, 0076, 0223, 0526, 0527, 0666
Montgomery Ward 0008
Motorola 0071, 0110
MTC 0005, 0050, 0062, 0085
Multitech 0038
Multivision 0070
NAD 0041, 0062, 0106
NEC 0005, 0013, 0050, 0062, 0071
NET-TV 0163, 0192
Nikko 0047, 0062
Onwa 0038, 0248
Optimus 0106
Optonica 0054, 0110
Orion 0012, 0129, 0441
Panasonic 0135, 0150, 0215, 0063, 0071, 0074, 0127, 0135, 0150, 0215, 0528, 0530, 0566, 0228, 0228, 0170, 0179, 0180, 0211
Philco 0005, 0016, 0027, 0029, 0036, 0042, 0050, 0055, 0062, 0063, 0066, 0071
Philips 0005, 0016, 0027, 0032, 0036, 0042, 0046, 0055, 0063, 0066, 0071, 0214, 0235, 0299, 0540, 0541, 0543, 0545, 0548, 0550, 0553, 0554, 0522, 0560, 0562
Philips Magnavox 0413, 0299, 0413, 0521, 0540, 0545, 0548, 0550, 0552, 0553, 0554, 0522, 0524, 0523, 0560, 0562
Pioneer 0005, 0062, 0068, 0072, 0075, 0106, 0124, 0408, 0411, 0197, 0158
PlasmaSync 0169
Portland 0005, 0047, 0050, 0062, 0156
Price Club 0085
Prima 0139
Prism 0074
Proscan 0664, 0104, 0152
Proton 0005, 0016, 0062, 0065, 0249
Quasar 0071, 0074, 0080, 0127, 0228, 0565, 0566
Radio Shack 0043, 0152, 0248
Radio Shack/Realistic 005, 0016, 0038, 0664, 0043, 0054, 0062, 0143, 0156
RCA 0436, 0664, 0153, 0664, 0005, 0022, 0050, 0062, 0066, 0071, 0087, 0092, 0094, 0100, 0104, 0107, 0109, 0118, 0124, 0130, 0146, 0152, 0153, 0248, 0436, 0568, 0488, 0486
Runco 0001
Sampo 0005, 0062, 0138, 0143, 0156, 0163
Samsung 0005, 0016, 0050, 0053, 0062, 0066, 0085, 0093, 0102, 0114, 0143, 0156, 0231, 0401, 0184, 0177, 0210, 0159, 0160, 0208, 0406, 0181, 0182, 0183, 0184, 0185, 0193, 0665
Sansui 0131, 0129, 0131, 0441
Jan 09, 2010 | Microsoft Xbox 360 Universal Media Remote
Incoming fax freezes system
Try installing the fax controller again, make sure to turn off fax machine, reboot computer and then after trying turning on your fax and send another document.
Nov 18, 2008 | Symantec WinFax Pro for PC
Creative webcam vf-0050
Lost the cd that install vf-0050
Oct 21, 2008 | Creative Labs WebCam Live!
I have webcam creative N10225 model VF-0050 and I lost the cd instalation for it,and I got a new computer Vista .How can I do this camera working on this computer ?
How can I found free driver that working with my CREATIVEwebcam VF-0050 in my new computer windos wista? I lost original cd intalation for it.
Jun 24, 2008 | Creative Labs WebCam Live!
Fax Mode "Status:Standby"
go to the fax option from the menu and check the status option .
The setting had been changed to standby ib your fax machine
Apr 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Toshiba e-studio 5520c Digital Copier Logo
20 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
