Question about Grundig Xephia 42 in. EDTV-Ready Plasma TV
Grundig Xephia 42 in.stuck on stand by
When switched on TV clicks and blue LED flashes on then off and red LED illuminates, after a few seconds there is a second click. when TV was working the blue LED would illuminate and if the channel button was pressed screen would tyrn on but now after second click it just stays on red LED.
    Top Expert:
  • Grundig Master
  • 36,401 Answers
Probably the internal power supply has failed.
Posted on Nov 22, 2013
5 Suggested Answers
SOURCE: stand wont come off grundig tv model gu19wdvd3 to mount it
Remove the three screws from the back of the stand.
Remove the four screws from the bottom of the stand.
Looking down at the bottom of the stand, push the four protuding clips inwards (not easy - you may need to gently ease them with a small screwdriver)
This unclips the oval base and allows you to unscrew the remaining screw inside the stem of the base
Posted on Dec 26, 2009
Kuwagata
  • 181 Answers
SOURCE: The TV doesn't start, the
The problems starts from the power unit, on this board, the voltages needed to operated TV normally dropped down very low.And one of the power resistor/ Integrated Circuit burned.
To fix this,you need to find someone who capable to repair this board or took it to service center.
Posted on Aug 23, 2011
  • 159 Answers
SOURCE: i have grundig lenaro 32"tv
Sounds like you're only viewing analogue channels.
Go into Menu and find Inputs and select & choose DTV. This will restore reception of Freeview (Digital TV) channels.
Posted on Sep 26, 2011
SOURCE: lost stand for grundig elegance
I've lost my stand as well, did you find a solution?
Posted on Oct 29, 2011
Panasonic TX-L42S10B has power but won't turn on
ok, this may be a silly question but when you turn it on and it starts flashing red, have you tried pressing the stand-by button on the remote. if a tv has been put on stand-by by the remote, and is then switched off by the set, when the set is turned back on it is still in stand-by mode and you need to press the stand-by button on the remote.
other than that I don't know.
Nov 08, 2013 | Panasonic TXL42S10B 42 in HDTVReady TV
Grunding TV not starting
Problems start from the power board.For easy fix, replace the board with the same type.Or if you didn't know what to do, call the Grundig Service Center for further assistant
Aug 23, 2011 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
The TV doesn't start, the RED led flashes a click sound is heard and then LED switches off. This goes on and on and on
Hi, We have a 42" hslc10668phz
generally when you get a constant green light all is ok. these different lights indicate different problems within the tv. so the pattern of lights you mention suggests there is a fault of some kind (is there a troubleshooting section in your manual)? either way it needs to be looked at.
Nov 28, 2010 | Hisense Televison & Video
I want the address for grundig uk
Grundig UK Ltd, Elstree Business Centre, Elstree Way, Borehamwood, Hertfordshire, WD6 1RX
hope the helps
Nov 09, 2009 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
Sounded like fuse blown up, replaced fuse in power plug, power on but no service?
i think it might have damaged the internal parts. but sometimes, certain devices drop down as a safe measure when fuse gos out. reseting it might help. good luck!
Oct 14, 2009 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
42PF9956/37 SHUTSDOWN...
Ok. I got my tv back on.
I pulled off the back cover and found the relay that was clicking.
I have two blue relays next to each other that click when the power is pushed.
I placed a hair dryer over the relays for about a minute.
Once heated up, it only took 4 tries to get the TV to stay on.
Jan 03, 2008 | Philips 42PF9956 42 in. HD-Ready Plasma...
Grundig Xephia 42 in. EDTV-Ready Plasma TV Logo
149 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
