Tv not working after entering service menu and accidently pressing a button, is there a way to fix this? Its a Samsung LE46B530
Service menu, tv screen black, not working
SOURCE: Samsung LCD TV LN40A650 - Service Mode
1. Turn off the TV
2. Press "info" then "Menu" then "mute" and then "Power" on your remote (As fast as possible).
The TV will now start up in Service Mode
Breinholm / Denmark
Posted on May 24, 2008
  • 1153 Answers
SOURCE: Accessing the service menu
This is the right way, what is wrong with set?
Posted on Oct 06, 2007
SOURCE: Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Posted on Jan 28, 2008
SOURCE: TV Has No Picture - Samsung BE40PSNB
check c1853, c1854, and cb850
Posted on Jun 26, 2008
SOURCE: No Picture - Samsung LN-S4692D 46in HDTV LCD
I had the same problem and I replaced the t-con board. My t.v. is fixed!!!! I just couldn't see spending another 700.00 dollars for a repair shop to fix it. The t-con board is located at the top of the t.v. once you remove the back cover. Be very careful removing the two plugs at the top of the board which was easy once I figured out how the clips worked. there is a black lever like connection which flips up, then grip with your fingers the tab and slide the tape like wires straight out. The bottom plug is very simple. Also to expose the t-con board you will have to remove a heat shield cover. Once removed there is foil looking tape that needs to be peeled back to expose the board. The board is very sensitive to static electricity so if you have a grounding strap that you can strap to your wrist and ground to the frame while performing your repair. Its best to lay the t.v. face down on the kitchen table with a blanket to protect the screen. Good luck!
Posted on Sep 07, 2008
How can I open the service menu?
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons.
PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Hidden Secret Service Menu Codes for Sony Samsung LG and Philips TV
TV Service Menus Hidden features you didn know about
Jan 31, 2016 | Televison & Video
Our replacement samsung dlp tv lamp doesn't give us a full screen picture on any stations other than the High Definition stations, how do we fix this?
The high def stations are full screen as they are transmitted in a 16:9 ratio which is full screen. However the non HD channels are transmitted in a 4:3 ratio which is square and not full screen. Usually this can be rectifyed by putting your tv in 16:9 mode through it's menu's. You can also adjust this setting through your cable box if you are using one.
Hope this helps
Jun 27, 2008 | Samsung Televison & Video
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
Just replaced the lamp in my Samsung DLP and still no picture just audio. Heard something about a code to reset timer / hours counter. Any Ideas/
counter. Resetting the counter is a very simple procedure. Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterward!).
Apr 16, 2010 | Samsung DLP HL-P5663W 56" TV
Can`t retune samsung le 37 r88.
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Oct 01, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Samsung le26r74bd won't retune digital channels
Sep 30, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Samsung LE32R7 will not retune since switchover
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Just baught a new lamp and all that is happening is lamp light...
You will need to reset the lamp counter.
Press:
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can subsitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
Jul 09, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
How do you get into the service menu on Samsung hcp4752w
I dont remember it exactly but ..if your TV is on then Press Standby and then press Info + Enter + Menu + Standby to turn on..you will get the service menu on screen.
Just alter the sequence of info + enter + menu to info + menu + enter or something.
hope it works
regards
bhavin
Apr 06, 2009 | Samsung HC-P4752W 47" Rear Projection...
Dec 21, 2007 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
