Question about Electric Health & Beauty
My wheeltech mobility scooter running slow on top speed
2 new baterys fited its ok on low speed but slow on top speed of 8mph
  • Electric Master
  • 1,263 Answers
Hi, sounds like it's due a service , that should involve the brushes being inspected and replaced if required and making sure the brake is releasing okay...
Need more info then contact via my website...
Regards
Rob
www.gewizrepairs.co.uk
Posted on Jan 19, 2014
  • 346 Answers
SOURCE: my strider scooter is failing the speed goes up
Hello,please rate my answer as in thumbs up 1 to 4.
Visit:WWW,ALLDATASHEET.COM Download as a PDF File to save to an Adobe Reader.Try this 1 :troubleshooting_2007 SHOPRIDER.pdf.its 36 pages long,but 18 pages are what im almost sure you will need,it starts with batteries & then onto scooters.pages 19 to 36 are all about the wheelchair.im sure you will be happy with the info in it.& as i did for my scooter print & save it in a polythene sleeve folder for future.Have a nice day,Colin.
Posted on Oct 08, 2010
  • 177 Answers
SOURCE: I HAVE A CELEBRITY DX SCOOTER,
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
Posted on Jul 07, 2010
  • 16 Answers
SOURCE: PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
Posted on Aug 01, 2010
wcdoc1953
  • 280 Answers
SOURCE: hi do you need to turn on key to charge up battery
No, you don't need to turn on the key to charge. Just plug in the charger and turn on the charger if there is an on/off switch on it. The charger indicator and the scooter meter will read full when the scooter is fully charged. Hope this helps.
Posted on Mar 05, 2011
SOURCE: problems with my evolution 8 mobility scooter
i have never personally worked on a mobility scooter myself but i do know that my grandfathers had the same problem and his gear sprocket had worn down so when he was on flat ground it was fine but when he would go up inclines and it needed more power it would just spin and barely make it but this was also ten years ago so idk if there even close to anything the same anymore
Posted on Jun 12, 2012
Testimonial: "will ckeck for this,many thanks "
I HAVE A CRAFTMATIC COMMANDER MOBILITY SCOOTER I NEED A MANUAL PLEASE, ALSO DOES ANYONE KNOW IF IT 8MPH CLASS 3 OR NOT..THX
hi, it 's actually made by pride and yes it is a rated class 3 mobility scooter capable of 8 mph...
  • Pride Craftmatic Commander (CRM2700)
Regards
Rob
Apr 27, 2016 | Health & Beauty
I have a pride classic xl8 i will be go along at top speed and then for no apparent reason it starts to go slow then quick then slow
This could be something to do with the HI-LOW speed switch or the connections on it or back to the control unit. Check for loose connections first. If you have a meter, check the resistance across the Hi-LOW switch.
Nov 13, 2014 | Health & Beauty
My kymco midi goes ok for about 1 mile then slows and then stops the battery ok can it be the motor
Hi there i would get it fully serviced before it breaks down completely a full service would cost you 50 pounds
Pete
Oct 09, 2014 | Kymco Midi XL 8mph Mobility Scooter with...
Problems with my evolution 8 mobility scooter
Jun 12, 2012 | Health & Beauty
Hi
Good Luck, Gerry.
Jul 19, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
I HAVE A CELEBRITY DX SCOOTER, IT IS 4 YEARS OLD. I HAVE HAD NEW BATTERIES FITTED, BUT THIS LAST 3 MONTHS THE SCOOTER RUNS FROM NORMAL SPEED TO SLOW AND SLUGGISH THEN BACK TO NORMAL EVERY FEW MINUTES.CAN...
Hi John.
Good luck. Neil.
Jul 05, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
I have a 2002four wheel Legend Mobility scooter.
Hi. A lot of scooters have a seperate switch to select a high or low speed setting.
This switch is sometimes labeled indoor/ outdoor.
I have had a few scooters with a similar fault, and the wires that connect to the high/low switch have broken of the terminals on the rear of the switch.
It could also be a faulty speed control pot.
Check these and good luck. Neil.
Mar 08, 2010 | Pride Mobility Products Legend 4-Wheel...
The scooter runs but super slow, I purchased two brand new batteries but it continues with the same problem.
hi,
Is there any change speed when you change from 4mph to 8mph ?
if not first check the controller under the seat, normally a black box, make sure that all connection onto the controller are clean and tight,
Check the motor brushes, undo the screw caps carefully,these can be brittle , remove the brushes clean , make sure the brushes move freely within the motor,
Check the brake on the side the motor, this normally has a freewheel attached to it,
Remove the brake unit but do not disconnect the two wires, and test again is the brake clicking when you power away, if not it's not releasing hence the slow speed, check the brake for open or shorted connection.
Regards
GeWiz.
Feb 05, 2010 | Hurricane Pride PMV Mobility Scooter -...
Very slow go go scooter
hi, Sorry but those scooters are not stable at higher speeds,
the controller and battery fitted to those scooters cannot be made to give more power hence more speed, there is a number of reasons, the motor draws power from the controller and the controller gets what it requires from the battery, if you put on higher amps batteries , the scooter will go further not faster,
you would need to upgrade the motor to make it go faster, now the controllers are norrmally overrated so it could handle the extra power required, I would say it's impossible to upgrade the motor.
So another mobility scooter would be required,.
Don't get me wrong, there are lite scooters that go 8mph , I think TGA do one.
Regards
GeWiz.
Jan 16, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Mar 23, 2009 | Golden Technologies Companion II Travel...
Health & Beauty Logo
181 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
