Question about Zanussi FLE1416W Front Load Washer
Zanussi zwf1621s aqua cycle start/pause button flashing no other response
beltronic205
  • 1467 Answers
SOURCE: unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Posted on Oct 02, 2009
Testimonial: "this is very helpful, Allthough I am not capable of carrying out this work I do at least know what the repair guy may say. thanks."
SOURCE: hi my zanussi zwf1432s stopped halfway through
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
Posted on May 05, 2010
SOURCE: Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Posted on May 09, 2010
tunde007
  • 2382 Answers
SOURCE: i have a zanussi 1200 6kg washing machine.
Hi, the flashing red light is an indication that you have a problem with your machine not spinning and draining.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Nov 20, 2010
  • 480 Answers
SOURCE: error e51 on zanussi iz12
E51 does mean "triac which powers the motor short-circuited".
(TRIAC short-circuit cut-out activated or motor speed more than maximum speed)
Possible causes:
Loss of insulation on motor winding/wiring; main PCB
Dado
Posted on Jul 06, 2015
Zanussi zwf1621s washing machine not working.
IT SOUNDS AS THOUGH THE MOTHER BOARD HAS SHORTED OUT OR YOUR DRUM HAS COME AWAY FROM ITS MOUNT
Dec 27, 2013 | Washing Machines
I have a Zanussi zwf1621s washing machine which is approx 6 yrs old. When spinning today it made a strange noise so i turned the machine off. When I went to restart the machine all the lights came on but...
it really depends on the sound it made, if it was a rumble or a screech it could be the motor, or grinding it could be the bearing or something is in the drum, if it was on a drain cycle it could be the pump or something in the pump blocking/catching on the fins in the pump ( hair can affect the pump). coins can sometimes get to the drum housing and cause damage, ie catch the heating element, this can make the washer not start as the washer has a earthing sensor on the element resistance. hope this helps.
Nov 06, 2017 | Zanussi ZWF1420W Front Load Washer
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Hi! I have a Zanussi IZ12 washing machine. After I turn it on, the door will not open and start/pause button just flashes. (I can select program and press start/pause, it just beeps, but the machine do...
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Jul 14, 2010 | Zanussi IZ12 Front Load Washer
Zanussi washer machine zwf1621s does a washeing
3 things you need to check : DRAIN MOTOR PUMP ,
LID SAFETY SWITCH & THE MAIN TIMER , hope it helps , AJ
Dec 27, 2009 | Washing Machines
Unable to use ZJ1217, start/pause flashing
Oct 02, 2009 | Zanussi ZJ1217 Front Load Washer
Zanussi 1000XC Washing Machine - Pause Light Flashing
The ECU is failed. unplug for 40 minutes to try to reset it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Zanussi washer
Press "end of cycle" button to clear.........................
Jan 04, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi FLE1416W Front Load Washer Logo
46 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
