Question about Electric Kid Trax C6 Corvette Ride On
Bad Circuit boards on the Dorel pink corvette?
Replaced the battery and ran fine for a few weeks, but no power to any controls now. Battery is still fine, and checked to insure the fuse link on battery was not blown. Appears I have a problem in the circuit board. Where can I buy a replacement circuit board, or what else do you recommend?
3 Suggested Answers
SOURCE: Where can I find a
Hello Arey,
http://www.kidtraxtoys.com/skin/frontend/kidtrax/default/pdf/Chevrolet_Corvette_English.pdf
http://www.kidtraxtoys.com/spare-parts
Posted on Apr 22, 2011
adamfjeld
  • 1508 Answers
SOURCE: pink corvette 12 volt will not make sounds or move battery and fuse is good
have you tested the battery and the charger with a multimeter to make sure that they are showing at least 12 volts
Posted on Jun 12, 2012
What needs to be done after cangingm the battery on the circuit board ?
Possibly a loose connection, or dirt/foreign object on circuit board causing electric connections. clean board and connections, look for foreign object on electronics.
Jan 02, 2015 | Cars & Trucks
Check Charging system light illuminates, all electrical shuts down and engine still runs on 2004 Ford Expedition 5.4l until battery dies. The opposite has also happened with the engine shutting down and...
Try replacing the "convinence control module" and bad board can cause all elec issues explained and also cause engine to cut out and other things but that is where I would start, hope this helps-
Nov 29, 2013 | 2004 Ford Expedition
I just replaced battery and alternater but the battery died hile driving and once i jump the car it ill run for thirty seconds then die.
you've had the misfortune of getting a bad rebuilt alternator-sorry-they should give you another one -I hope its not hard to replace-Denny
Nov 05, 2013 | 2004 Chevrolet Impala
Kid Trax KT1021 Corvette does not start or even make a noise but meter shows battery & charger are both good and that the board is getting juice. We have followed every wire multiple times, looked at...
Safety 1st, KidTrax Battery-Powered Ride-On Vehicles Recalled Dorel is recalling about 141,000 Safety 1st and Kid Trax battery-powered ride-on toy vehicles. An electronic malfunction can occur in the circuit board and/or battery connector, resulting in smoking and melting of components.
This poses a vehicle fire hazard and a burn hazard to consumers if components are touched while malfunctioning.
The firm has received 49 reports of overheating or melting components on the ride-on vehicles. No injuries have been reported.
The recalled battery-powered ride-on vehicles include the Pink Corvette, Torch Red Corvette, Yellow Race Car Corvette, Red Electroplate Corvette, Fire Engine, and Batmobile with the model numbers listed in the chart below. They were sold under the brands Safety 1st and Kid Trax by Safety 1st.
The ride-on vehicles were manufactured between January 2004 and August 2005. The manufacture date is located on the underside of the unit and is molded into the plastic body as shown. The circle on left displays the month of manufacture, the circle on the right displays the year of manufacture. The model numbers are located on the underside of the vehicles near the date code.
Ride-On Vehicle Name Model Safety 1st Pink Corvette 50503/50503A Safety 1st Torch Red Corvette 50504/50504A Safety 1st Yellow Race Car Corvette 50505/50505A Safety 1st Red Electroplate Corvette 50521/50521A Kid Trax Fire Engine 50506/50506A Safety 1st Batmobile 50527
The units were sold at major toy stores and mass merchandise outlets nationwide under the brands Safety 1st and Kid Trax by Safety 1st from January 2004 through August 2005 for about $300.
Consumers should take the recalled ride-on vehicles away from children immediately and contact the company for a free repair.
For additional information, contact Dorel Juvenile Groups Ride-On hotline toll-free at (866) 611-3022 between 8 a.m. and 4:30 p.m. ET Monday through Friday, or visit www.djgusa.com.
The recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission (CPSC).
Sep 23, 2017 | Peg Perego 12 Volt Rechargeable Battery
2008 Chevy Equinox would not start, turn key and nothing happened, replaced battery, ran just fine for a week. Tried to start one week later it acted like it wanted to start but wouldn't. Had ju
Usually a sign of something draining the battery.
The machine test probably showed the battery could hold a charge and the alternator was charging the battery.
You may need to have someone check for a power drain.
When the key switch is off, there may be a weak short to ground or a relay or component that is using power.
Jan 22, 2013 | 2008 Chevrolet Equinox
I have 2009 Corvette, with battery problems as follows: IT seems when it sits for a week or so the battery goes dead. The dealer could not find anything wrong except for a bad battery, so they replaced it....
it has a draw, and they will be best equipped to find it. There are more modules on that car than the shuttle. it may take them a while, its warranty right?? its just a process of elimination, removing modules/ components from the "LOOP" until the draw goes away. good luck
Sep 28, 2009 | Chevrolet Chevette Cars & Trucks
After a drive my 1988 Corvette would not restart. Cranked weakly
sounds like the starter is pulling too many amps any local auto store should have equipment to check starter good luck
Jun 14, 2009 | 1988 Chevrolet Corvette
1995 cadillac eldorado battery volts low
i know you dont want to hear this, ck alternator output, if it is above 13.25 your are in business any lower replace it be sure alternator is wired correct on back
shack
Apr 14, 2009 | 1995 Cadillac Eldorado
The battery doesn't stay charged in Guardian 10K
I think that is the problem as well. Temporarily, you could just buy a tricke charger from the parts house and hook that up until your other one is changed. Rick
Apr 11, 2009 | Guardian Electrical Supplies
Electric Kid Trax C6 Corvette  Ride On Logo
106 people viewed this question
Top Electric Toys Experts
ray gallant
Robert A. Watson
Robert A. Watson
Tom Chichester
Are you an Electric Toy Expert? Answer questions, earn points and help others
