Question about Legacy LMRD15 Roof Mounted Flip Down LCD Monitors
Legacy LMRD15 stuck on pal and the remote doesnt work can access menuu but manual cotrols dont work. is there a way to reset it
How do i reset my lamp timer on my nec v260
go to menue / reset/clear lamp hours,
all the buttons needed are on the box, push menu & with the cross navigate & with enter confirm selection, exit gets you back at any time, on the nec/support website you can get the np-v series manual
good luck
Oct 30, 2014 | NEC Display NP-V260X Dlp Projector - 3D...
Samsung hl-s6767w timer reset. Can I reset using the menu option located on the tv. I have no factory remote
Yes, you just have to toggle manually using the plus and minus key as well as the channel up and down keys to navigate the menu
Nov 17, 2013 | Samsung HL-S6767W DLP TV
My touch screen stopped working on my samsung impression so i put the rest code in and the phone reset then its now stuck on the calibration screen and the touch screen wont respond
Dont kno if "Impression" is similar to "Omnia" but 'REMOTE SCREEN ALIGNMENT' program installed on PC skips 'align screen' on your phone. Also "welcome.not" (made in notepad) & pasted into your root files. A REGISTRY EDITOR will allow you to input the touchscreen configuration numbers manually. Of course, none of these will be much good if you dont have 'Windows" phone or cant access your Registry!!
If all this fails, ASK 'XDA DEVELOPERS', or 'MoDaCo'.
Oct 29, 2010 | Samsung SGH-A877 Impression Cell Phone
MP3 Touch screen is stuck . Can't configure
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
Dec 29, 2009 | Sylvania SMPK8854 Digital Media Player
Aircon/cigerate lighter doesnt work
Owners Manual Should Shor WHERE the FUSE IS And the FUSE MUST be TESTED with a Test light or a DVM to be sure its GOOD this Is common with Lighters Pennies get droped in them and it NORMALY just BLOW the FUSE
Jun 08, 2009 | 1999 Subaru Legacy
No remote cotrol available
Yes.
remotes.com has one.
It's the only place I can find one for TA2050.
Feb 20, 2009 | GoVideo TA2050 20 in. EDTV-Ready LCD...
Remote cotrol does not work except in close range.
Clean both red filter plastic windows, 1 at the remote control end and 1 at the tvs InfraRed receiver end, with window cleaner on a soft cloth. If this doesnt work you need to confirm operation with another working remote. Either the transmitter(remote) or receiver (tv) could be faulty.
Anything obstructing the IR path to the receiver located at the bottom edge of the tv bezel?
May 20, 2008 | Panasonic PV-C2061 20 in. TV/VCR Combo
Lost video output
You might have changed you settings for video type, PAL or NTSC or the letter box or 4:3 or 16:9 etc..
any way if your player contains a battery to retain settings unplug your player and remove the battery
if it doesnt have a battery unplug for 24 hrs,
you shold look at your remote for a button labeled P/N or N/P or ntsc/pal or pal/ntsc, or something close to that,
just press the button
if that dont work you can remove the batter and unplug for 24 hrs or if it dont have a battery just unplug for 24 hrs
IF THOSE DONT WROK POST YOUR PLAYER BRAND and MODEL i can advise you further then
Jan 02, 2008 | Koss KS4110 DVD Player
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Legacy LMRD15 Roof Mounted Flip Down LCD Monitors Logo
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
isaac johny
isaac johny
xxxxxx xxx
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
