Reset nad t762 - Audio Players & Recorders
2 Suggested Answers
SOURCE: NAD T762 - no sound
Try reseating the prologic/output board. Second one from the right (from the front of the reciever), that fixed my no sound problems on many channels. You will have to take out a few screws to remove and reseat it, and while you are at it clean the connections.
Posted on Feb 03, 2008
Factory reset
I have the same question.
Dec 07, 2013 | NAD Audio Players & Recorders
All speakers work on sound level test but i have no music coming from rear, center and sub when playing 5.1 dvd. also i am unable to use any of the surrond sound modes. richard
What cable did you hook up your dvd? The 5.1 sound works only with optical cable or HDMI. Check in the input settings wich one is selected. With the analog cable ( Stereo RCA) is not working. Good luck!
Jan 29, 2011 | NAD T762 Receiver
Why does it shut off at a certain volume?
this is an internal protection feature, so that your speakers are not overloaded and blown out
Jun 08, 2010 | NAD T762 Receiver
Power is on(green light) but nothing in display screen and cant get it to work. please help. thanks
hello my cuestion is that mij power is green ,and i haven nothing on my display?
greetz
paul pols
Mar 14, 2010 | NAD T762 Receiver
The front display is blank.
If you can solder, examine the pins for the display itself. In particular, look at the pins at either end. These are the power and ground pins. These often develop poor solder connections. Try resoldering these pins and update this with the results.
Dan
Mar 18, 2009 | NAD T762 Receiver
Gp280bvk x3
I have the same headphones. I went to Batteries Plus and purchased a similar battery, NUON, NU67, 3.6v 320mAh. The original battery is 3.6v 280mAh. The 320mAh holds the charge longer. You must swap the connector from the old battery to the new battery in order tomake it work. This can be done two ways, carefully removing the connector or cut, splice, solder and insulate the battery leads. Removing the connectors is tricky because the leads lock into place when inserted into the connectors. Good Luck.
Jan 16, 2009 | NAD T762 Receiver
NAD T762 stuck in standby
Remove the power plug first, try to find the Battery inside the unit,Remove it, just for a minute, or two, and put it Back, hope it work again.if you don,t find in the users manual ,how to reset !
Oct 17, 2017 | NAD T762 Receiver
Intermittend no audio from digital inputs, flicker video monitor out, volume goes up but not down
Since the problem appears only after the unit has been run for a while, I'd be looking for any part close to a heat source. The odd behavior suggests that there is noise on the data lines for the volume control chip and the digital processing areas. Look for a bad 5V regulator +/or bad caps on the 5V line. Also check for poor solder connections in the power supply and final output stages.
Keep us posted.
Dan
May 13, 2008 | NAD T762 Receiver
Delayed Sound from Center Speaker
Go to this website, make an account, go to support, help center. Thenfollow the instructions and you might get your answer.
Hope this helps. :)
Jan 21, 2008 | NAD T762 Receiver
NAD T762 - no sound
Sep 08, 2007 | NAD T762 Receiver
12 people viewed this question
 Grubhead
Grubhead
