Question about Marvel 30WCM Wine Cooler
Condensor clean alarm will not shut off
I have cleaned condenser and tried to reset alarm per the manual however it still does not reset
  • Gail Herman
    Gail Herman Mar 09, 2014
    Did you ever get this fixed? I am having same problem
To clear the alarm:
1) Press and release the "SET button four times. "cnd" will be displayed on the screen.
2) While "cnd" is displayed, press and hold the "SET" button. The display will show the number of weeks the refrigerator has been running.
3) While holding the "SET" button, press and release the ON/OFF button. The number shown on the display will reset to 0.
4) Release the "SET" key.
Posted on Feb 11, 2015
How do i shut off and reset sub=zero 690 fridge?
Its not necessary when "Vacuum Condenser" light is blinking means That condenser is dirty. That light will come on if compressor running too long. Most common problem is that Evaporator coil in fresh food section is leaking freon. It still might keep temps ok, but compressor need to run much more to keep temperature you set. check back wall in fresh food section on left side at the middle, behind drawers. if you see moisture in one spot or a little bit of ice build up, then You will need to call people who can replace evaporator. It is pretty expensive fix. I made video how it looks to repair this problem. Thanks.
Feb 21, 2015 | Sub-Zero 690 Side by Side Refrigerator
My ice machine manitowoc q 132a starts up stops after few seconds while water pump start
There is a high pressure switch that stops the unit running if a fan fails or the condenser is clogged. Next time you start the ice machine, watch the bottom led on the pcb. It will tell you if there is a fault. Meantime, reset the hp switch and clean the condenser thoroughly.
Sep 06, 2012 | Refrigerators
Model 685 Manufactured 02/04. EC 08 20 40 50. For a few months power off/on resolved the issue for a week but recently fridge side not keeping its cool. Freezer seems good. No condensation in fridge. ...
More than likely the control board in the refrigerator section has failed. The only thing that would cause this issue it a control. The breaker reset was only resetting the software in the control board.
Replace the board on the side and it will fix this issue.
Apr 13, 2011 | Sub-Zero 690 Side by Side Refrigerator
Compressor for freezer is not shutting off
Dirty condenser, condenser fan motor is not running. Clean condenser and check condenser fan motor.
Mar 07, 2010 | Refrigerators
Rudd Heat pump shuts down. Compressor is on and goes out on
Is your condensor coil clean?Needs air to breath.
Feb 12, 2010 | Ruud UBHC Air Conditioner
Condenser shuts down after a couple of hours.
check capacitors, make sure the condensor coil is clean. sounds like the compressor is overheating. is the condensor fan motor still turning when it stops cooling. if not check low voltage wires to condensor, furnace and t-stat
Aug 19, 2009 | Amana Haier AP125HD Air Conditioner
The tempature is set for 38 degrees, but the refrigerator is only at 47 degrees. Any ideas?
Chartigan - had this problem with my 1998 642 about 5 years ago, and had to have the condenser coils replaced twice- because the refrigerant was leaking. warning signs are: temp is more than 37 degrees [ get a fridge thermometer to monitor], food seemed to spoil quickly, and frequent notices from the display bar to clean condenser . after cleaning it 3 times in a month, when i called the service center they said that warning actually means"call service center" - arrrggghh the manual sure doesnt say that! anyhow - just something to consider, and hope your problem is not this serious.
Aug 01, 2009 | Sub-Zero 642
Clean the condensor
You can clean the condenser while it is running or you can unplug unit . most of the time you can use a nylon brush to brush off the condenser. If it has not been cleaned in a while you may need some sort of compressed air to blow through it. If units are in restaurant and by fryers or have greasy buildup on them you will need to unplug unit and spray some degreaser on it then rinse with water. It is important to clean the condenser, the part with fins and is located by compressor, because a dirty condenser will shorten the life of the compressor.
Dec 19, 2008 | Delfield 'New 6000XL 6051 Side by Side...
Subzero 630 hot door jamb
If the door jambs are hot, that is either a dirty condensor or a dead condensor fan motor. Make sure the condensor is vacuumed and check to see if the condensor fan is spinning. It should be running anytime either compressor is on. You can clear the service light by holdint the "alarm: button for 15 seconds or turning the unit off and then on again.
Jun 21, 2008 | Sub-Zero 650 / O Bottom Freezer...
Marvel 30WCM Wine Cooler Logo
80 people viewed this question
Top Marvel Refrigerators Experts
richie46
ray gallant
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
