Question about Kitchen Ranges
Kenmore 911 9352192 F 4
Code F 4
Sears kenmore elite has a message display to enter tcp code. kenmore microwave oven
TCP is "True Cook Plus" in Kenmore speak.
Here is a cut/paste of a section of the manual.
*CUSTOMIZING TrueCookPlus' You may find that you prefer TrueCookPlus® to cook your food more or less. TrueCookPlus " can adjust to your tastes - to cook your food hotter or cooler - automatically: Example Clear 1. Press the Clear button. (§H§ 1 2. Press the TrueCookPlus® button twice. 3. If you want less cooking time when you enter a TrueCookPlus code, press 1. This will decrease the time by 6%. 345 4. If you want more cooking time when you enter a TrueCookPlus® code: Press 3 for 3% more cooking time. Press 4 for 6% more cooking time. Press 5 for 9% more cooking time. 2 5. Press 2 to reset TrueCookPlus* to factory setting default time. 6. Press the Start button.
I didn't try to clean up the copy
Hope this makes sense and helps.
Sep 14, 2017 | Kenmore Microwave Ovens
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
What is error code F on kenmore elite oasis model # 110.27072603
push the second rinse button and hold for 4 sec then release for 4 sec. repeat this 4 times. then a all lights will come on and an 88 will appear in your display. then an F and a # will flash what is the nuber either with the F or right after the F
Jan 03, 2012 | Kenmore Metro Washing Machines
Kenmore model 911.95875790 code f5
The Kenmore 911 series ranges are built buy Whirlpool. An F5 error indicates an oven control error (clock or ERC). Sears Parts Direct lists this as part 16 here: http://parts.sears.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-91195875790/0582/0124111/10052061/00001 . The part is listed as in stock for $171.99. If you had a 4 character trouble code, additional diagnostics could be done to locate the problem.
I hope this helps.
Nov 18, 2011 | Kenmore Kitchen Ranges
Kenmore Elite model 42934. Problem washer only
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 26, 2010 | Kenmore 42822 Front Load Washer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
I'm trying to purchase a new Model 29732 kenmore washer
It is no longer available.
Apr 07, 2009 | Kenmore Washing Machines
F 2 error code
Hi KG Oliver,
This is a common complaint on the Whirlpool built Kenmore's. Please follow this link to my solution for it.
Thanks,
SG
Apr 05, 2009 | Kenmore Washing Machines
Error code on kenmore washer
LG washing machines indicating error code CL may have the child lock activated.
Try holding down the temperature and eco/rapid options together to turn off child lock.
Some LG series use "TEMP and OPTION" at the same time.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Error code help
I assume this is the cabrio version not a calypso, (kenmore washers are whirlpools) C-9 is the last step of the diagnostic test. fault codes start with F or are a two letter code like Sd for over suds, dL Door Lock etc. I have noticed a spark also when plugging in some of these machines, but still worked fine. to see if there is a real code stored - use any one key other than power start and cancel while machine is off and press and hold for 4 secs release for 4 press for 4, release for 4, press for 4, release, you should see all lights come on. then after a few seconds if it has a code you should see it. press same key again and it should start diagnostic test- where it uses the C codes for steps. power and cancel should get you out this. for your code list there is a service book inside the machine on the front panel upper left side. (pop top lid up with putty knife). OR for all your whirlpool made products go to www.servicematters.com click technical reference, technical library, tech sheets/wiring diagrams enter model number (kenmore number after the "110.")
hope this helps
Mike
Dec 01, 2008 | Washing Machines
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
