Kodak carousel I'm looking for a cord to a Carousel projector for the 600 or 600H model. Do you know where I could get one of those?
    President:
  • 412 Answers
Sure!! You can order the detatchable power cords from: www.micro-tools.com. Micro-Tools bought the entire inventory of Kodak Projector Parts when Kodak shuttered that business. Good Luck !!! Jim
Posted on Nov 22, 2013
Testimonial: "Thanks, Jim. They did not have any of these cords for the Model 600 Carousel in stock. So, even though that was very helpful and a really quick response, no luck...But THANKS SO MUCH!"
SOURCE: My Kodak Carousel 750H slide projector will not
A common cause for that problem is a broken plastic "link" on the solenoid (Kodak part #217769). There are repair shops who can replace this part. It is very difficult to replace by yourself. http://www.kodak.com/global/en/service/repair/slideProj/index.jhtml
Posted on Nov 11, 2009
projdoc
  • 2237 Answers
SOURCE: My Kodak 760H Carousel projector does not advance
do you hear any sounds when you press the button? if not, the button may be malfunctioning. if it doesn't make a sound or movement in reverse either, there is a bad connection between the controls and the solenoids. if it does try to advance and not move the carousel, it's a mechanical problem in the mechanism. usually due to the grease getting sticky from heat and age. take it in for a good cleaning and an adjustment. there are a few cams in there that wear out after a while, too.
Posted on Nov 13, 2009
  • 412 Answers
SOURCE: Kodak Projector 760H. Carousel won't
Chances are that your projector has a broken solenoid "link". This "Link" connects the slide change solenoid and the slide change mechanism. Over time this part becomes brittle & cracks, rendering the slide change non-functional. A pretty easy fix for an authorized repair dealer.
Posted on Nov 03, 2010
  • 412 Answers
SOURCE: I'm having a problem loading a tray onto my kodak
First, with the tray off the projector, cycle the projector several times in forward and then in reverse. Next, check to make sure the locking ring on the top on the slide tray is LOCKED ON TIGHT. Then turn the tray upside down. On a 140 Slide tray there is an index notch. On the metal plate there is a index hole. Gently release the metal spring of the tray latch and rotate the metal plate until the notch and hole line up. Now the tray should drop on the projector and index properly.
Posted on Dec 03, 2010
  • 412 Answers
SOURCE: I just purchased an older Kodak slide projector
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Posted on Dec 30, 2010
Kodak carousel 750H slide projector power cord missing
Detatchable power cords for KODAK Carousel Slide Projectors can be purchased from: www.micro-tools.com
or: www.vinevalleyimaging.com
Good Luck!! jim
Sep 13, 2013 | Kodak Carousel 4600 Slide Projector
Kodak Carousel 600 Slide Projector manual
The KODAK Carousel 600 Projector has NO forward or reverse controls. To cycle the tray forward, LIGHTLY depress the SELECT bar. Reverse is accomplished by holding the SELECT bar down completely and rotating the tray by hand. Jim
Apr 03, 2013 | Kodak Carousel 600 Slide Projector
I need a power cord for kodak carousel 800.
To purchase a detachable power cord for old KODAK Slide Projectors, contact: www.micro-tools.com
They are the source for Kodak Slide Projector Repair Parts.
Apr 01, 2013 | Kodak 4200 Slide Projector
Require the power cord for an 850H kodak projector
You can order a power cord for a Carousel 850H from: www.micro-tools.com They have purchased Kodak's inventory of spare parts!
Good Luck !!
Jim
Sep 30, 2012 | Kodak Carousel 4600 Slide Projector
I have a slide projector Kodak carousel S. The slide does not want to change! The ventilation & light work. I looked inside and it seem that there is no push from the middle of a cilinder (sorry do...
This projector was manufactured by Kodak in Stuttgart, Germany. You can check with Langie AudioVisual on East Commercial Street in East Rochester, NY. They were the last dealer I know of that still had a technician trained on the Carousel S. I don't have manuals for that model. Sorry I can't be of more help!
Sep 18, 2011 | Kodak Ektapro 7020 Slide Projector
Carousel on my projector does not advance not sure if I have the carousel on right or whats going on.
Please re-post this problem with the specific model name/number of the KODAK projector. The model (and age) of your projector will determine what is wrong.
Nov 08, 2010 | Kodak Office Equipment & Supplies
I just purchased an older Kodak slide projector with a carousel on top. Everything works fine but the carousel won't advance. When you click the next button, the plastic arm that should advance the...
Nov 14, 2009 | Kodak Carousel 5600 Slide Projector
Trying to find a carousel that will fit Navitar model CP-300AF
I am pretty sure that the projectors modified, marketed & sold by Navitar were Kodak projector bodies & slide transports. Assuming this is the case, a Kodak 80 Tray should work just fine!
Aug 03, 2009 | Navitar 750-AF 35mm 80 Slides Rotary...
55 people viewed this question
k24674
jasbo
jasbo
