Question about Pantech flex p8010 at&t unlocked gsm phone
What does s/w/ upgrade mean
Saw it when I turned on my phone there is a download arrow
How to create a boot option
When you start your laptop and see the "Asus" logo, press ESC, then navigate with your arrow keys to select the correct boot device and hit Enter to boot.
Hope this helps.
May 28, 2013 | ASUS K55vd-ds71 15.6"i7-3610qm 750gb 6gb...
How do i get mu uniden cordless phone off silent mode
If you mean muting/unmuting the microphone, press the mute button (above and right of the cursor pad. If you mean the ring volume,press up-arrow while the phone is idle.
If you need a manual you may download a copy here.
Aug 10, 2012 | Uniden DECT 2080-5 Quint Phone
Xerox printer 8560n won't print
First download and install printer's driver ..click here Select your operating system and language. Next try to print the configuration page ..--> Press the [Up] or [Down] arrow button on the Control Panelto select [Printer Setup] on the Display Screen, and then press the [OK]button. Press the [Up] or [Down] arrow button to select[Configuration Page], and then press the [OK] button to print. Press the [Up] or [Down] arrow button to select [Exit], andthen press the [OK] button to return to the Main Menu.
Apr 05, 2011 | Xerox Upgrade Phaser 8560N to Phaser...
On top of the piston there is an arrow with the letters AB what does this keen?
just looked at a couple of pistons not sure what the letters mean ,,,but when installing the piston make sure the arrow always points to the exhaust port of the cylinder
Mar 29, 2011 | Husqvarna Chainsaw Piston Kit for 61...
Hello k_akima Im tarek boot how are you are you fine I wish you are fine I have casio fx-82es version B I was try to upgrade it I tried this way ......[...the same until...
I'm sorry, but I have no idea what you're trying to do. If you're following instructions given on some web page, then I suggest you refer any questions to the author of that page.
Feb 19, 2011 | Office Equipment & Supplies
I installed the FM transmitter module which came with my samsung LCD TV model LA40C530F 1R. I tried accessing the FM transmitter menu in order to turn the transmitter On and to set the frequency but that...
1. Press the menu button(green)
2. down arrow once - (a picture of a speaker should appear with sound written vertically next to it)
3. Right arrow once (selects the sound menu)
4. Down arrow till you see FM transmitter (down arrow 4 times on my TV. If you don't see the FM transmitter option in the menu then upgrade your TV to the latest software (details at the end of this help file)
5. Right arrow to get into the FM transmitter menu
6. select the "FM transmitter: off" line and turn it on (FM transmitter : on)
7. Change the frequency to to one that is not used by a radio station or has interference noise (get a radio and tune it till you hear the choosh sound with no beeping or clicking from lightning - then set the tv fm transmitter to that frequency using the up and down arrow keys and enter.
8. You should here your tv sound comming through the radio even if the tv sound is off.
If you need to upgrade your tv software then:
1. format a usb stick
2. download firmware.exe from"
http://www.samsung.com/za/consumer/tv-audio-video/television/lcd-tv/LA32C530F1RXXA/index.idx?pagetype=prd_detail&tab=support
3. click on firmware
4. click on "Upgrade File(USB type)" and download it to your usb stick
5. when the download is complete double click on the file and extract it to the usb stick.
6. eject the usb stick.
7. plug it into your TV and slelect software upgrade when prompted - I didn't loose any settings even though it warns you that you will (samsung are just covering themselves)
Sep 03, 2010 | Televison & Video
Need to download manual fo mag 77 saw
Manuals can be downloaded from Skil here. Click the down arrow next to "New Products", then choose "Corded Circular Saws" and you'll find several model 77s listed. Pick your specific model and there you go.
Hope this helps! Thanks for using Fixya.
Jan 31, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
How do you unlock the quikrelease when it is stuck open on the bosch recripcating saw
when you look at the front of the quick release, you should see 2 arrows, the arrow on the right faces up, the arrow on the left faces down. that is the open position, now all you need to do is insert a blade and it will lock closed by itself. then just turn it back to release the blade.
Jan 22, 2010 | Bosch 1646B 18V Cordless Reciprocating Saw...
What does the cell phone symbol with a broken arrow mean on my nokia 2605 mean?
I know Nokia Uses 2 icons with arrows:
There's a icon that shows a crooked arrow up to the right, that means you have call forwarding on...
There's an bracket with an arrow pointing straight up, it means one of your sent messages - did not go through..
Jan 06, 2010 | Nokia 6070 Cellular Phone
Can anyone explain this icon that has appeared on my phone after my grandson was playing with it it has a letter G then a bar with sides and an upward arrow
do not worry. your grandson has caused no problems. this refers to the type of signal you are currently recieving. This icon means "GPRS" signal which, for lack of a better term, means you have a stronger signal than if you saw the letter "E" in its place. the timing was most likely coincidental.
Mar 19, 2009 | Nokia 6030 Cellular Phone
Pantech flex p8010 at&t unlocked gsm phone Logo
26 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
