Question about Samsung 206BW Monitor
Volume sound control
I cannot hear sound with this monitor.
Monitor Channel Making static sounds
Without hearing it it is difficult to be sure what is going on. What happens if you plug the main PA into the monitor channels, do you get the same? Are you trying to get too much into the monitors? static and popping are not the same to my ears, popping sounds more like you are hearing something that's there through the monitors that you're not hearing through the main mix as it may be masked. What frequency is the popping? Does it only happen when levels are high or when the singers are doing 'p' and 'b's etc? do you get it if you put the monitors on the main mix? Are you running the monitors into clipping (although I wouldn't expect this to create a popping? It sounds like a mix issue rather than a fault with hardware.
Aug 09, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
The monitor shows the sound is on but I don't hear
On what, your oven or is this a laptop or PC, a laptop adjust the sound settings, on a monitor, you need a HDMI cable to get sound from a monitor. And a PC that has onboard HDMI or a graph card that has HDMI.
Mar 29, 2013 | Computers & Internet
Monitor makes a cracking frying sound as it booted up the screen would flicker and then it went black. never come on again
The bulb in those older Monitors dont last too long. Many times whenever you hear that sound its like the tungsten filament burning out or breaking. That's the crackling sound you hear as it boots up. My suggestion would be to get another monitor at this point in time.
Nov 19, 2009 | Proview Computers & Internet
Hi my philips monitor keeps flickering on and off. I hear a clicking sound but the monitor will not stay on.
You are hearing mini-sized lightning bolts.
Turn the monitor off, before it burns your house down.
Disconnect it.
Find a Recycling Station that will responsibly recycle your monitor.
Buy a new monitor.
Nov 01, 2009 | Philips Computers & Internet
When I start my CPU, I hear a sound that shows me that the equipment is on (that it's working), but the screen stays completely black, no light, no image on it. It happened all of a sudden. I switched it...
that iis not clear from wheryou heare sound.. monitor or cpu. if u hear sound from cpu your cpu fan is not working properly.. that cause processar may be damage,2/ some time damage ram shown same type symtom.change it to find outfault.
Jun 15, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Not able to hear sound out of my monitors speakers
Not Necessarily Sounds Like The Speakers Are Hooked Into The Wrong Jack.
Dec 30, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
No sound from the monitor or playback
check out where your monitors are receiving their audio from.is it from the tascam or the onboard or audio another interface.first choose an output for your sound,if you using the tascam as an output for your sound connect your monitors to the phones input in front and use the mono mix knob to swap between audio coming from your usb or computer.if you want to hear from your mic or guitar move knob to usb if you want to hear from computer as in playbck move it to computer.
Nov 21, 2008 | Tascam US-144 Sound Card
No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Sep 26, 2008 | Tascam US-144 Sound Card
Monitor says it doesnt reconize my computer and has locked me out
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem
Apr 01, 2008 | Gateway FPD1975 19" LCD Monitor
Samsung 206BW Monitor Logo
12 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
