Question about Pioneer Audio Players & Recorders
Aux on Pioneer VSX-1014
How do i conect the aux cable to the pioneer reciver, it dose not stand aux on any places, what should i do?
  • 15 Answers
SOURCE: poor sound
You need to connect most turntables to a PHONO input or buy a PHONO preamp. Many newer receivers do not have a PHONO input. The AUX port you are using would work fine for a device like a CD player, but turntables need to be amplified. You can buy an external Phono pre-amp from Radio Shack. I don't know anything about this site, but something like this device should work for you. http://www.phonopreamps.com/tc400pp.html
Posted on Jun 19, 2007
SOURCE: Pioneer turntable Pl-560 and Pioneer Receiver VSX-D409
Magnetic phono cartridges like the one on your pioneer has an output of about .005 Volts, the standard inputs are looking for 1 to 2 volts for fulol out put, the phono preamp will step up the output voltage to 1 volt so you can play it thru a non phono input like Aux, tape or tuner.
Radio shack sells cheap ones and you will hear what you pay for.
I sell turntables and audio gear, check out www.soundsciencecat.com
Good Luck,
Neal Van Berg
Posted on Sep 16, 2008
  • 4 Answers
SOURCE: I can't select aux when I plug my ipod into my Pioneer stereo.
I think this can be done with the stereo on but you have to hold down either the e button or 1 of the buttons on the right side of face(not audio)maybe and a menu will pop up and you should run into a screen that ask off on or off you will want it on and then you should be able to access ur ipod by pressing the source button.Hope this helps.
Posted on Dec 20, 2008
  • 124 Answers
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
Posted on Dec 27, 2008
SOURCE: aux port
Turn off Radio with car on or key on. Press and hold the big volume button in for 3 seconds, and the radio will say initialise. Than press the FCN button till it says AUX. Than press the SEL button till it says "Aux ON ". Turn on radio and you should be good to go.
Posted on Apr 14, 2009
How do I get aux cord to work on PD-103 to work. Its hooked up to a pioneer vsx-5045. Normally my dad would do it but hes un reachable
you need this
rca red and white goes at the back of your amp or receiver. look for a free slot ( cd, dvd or aux) and there, you have an aux cord.
May 05, 2016 | Pioneer Audio Players & Recorders
Connect an AUX cable
Use the speaker output and plug it into the mic socket. Not ideal but the alternative is to buy a cheap adaptor for the end of the aux cable so that you can plug your speaker output into the aux input.
Nov 22, 2013 | Pioneer VSX-1014 Receiver
How can I connect my itouch to my pioneer VSX-52TX receiver
You can use the RCA jack and an RCA cable to your aux in on your receiver.
Oct 16, 2013 | Pioneer Audio Players & Recorders
Turntable hookup to AUX or CD (no Phono input) only producing very weak sound, even at full volume
You are doing nothing wrong at all. It's just that as you say it has no phono input. Which means the sockets you have will NOT amplify the signal. So you need to buy a magnetic cartridge pre-amp and once connected to the aux the weak signal will be at the normal level.
Jul 11, 2017 | Pioneer VSX-818V-K Receiver
Pluged samsung HT-D6750w speaks into pioneer vsx-520 amp and no sound is coming out
Please check the mode you selected or some call it FUNCTION.There are many jacks in ur amp such as Phono Tuner AUX in and so on.IF you have connected the player out to Aux in ,u must select Aux in the Amp.And check the cables used.
Sep 15, 2011 | Audio Players & Recorders
How do I hook up my ipod to my pioneer vsx d409 ?
The best way is to use a 3,5mm stereo jack to 2 RCA cable like this:
You can easily find one like this at your local audio/electronics shop or buy one on line. You have to connect the RCA at any free stereo input at the back of your Pioneer (like aux or cd). Take a look at this picture:
After this you can use the 3.5mm stereo jack for connecting not only your ipod but every mp3 player or other device has an earphone jack. Just plug the 3.5mm jack at the earphone jack and rise the volume at the portable device up to the middle of the volume range and set your Pioneer input selector at the stereo input that you connect the 2 RCA before (aux or cd)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 13, 2011 | Pioneer VSX-D409
How do i connect a pioneer pl-630 turntable to a pioneer vsx-1919ah receiver
Are you meaning it doesn't have a connection for a turntable, just aux connections etc?
Check if it has a magnetic cartridge pre-amp first, if it doesn't you can get one just put the words: magnetic cartridge pre-amp, into Google to find one. Once you get it that will plug into an aux socket and the turntable into that, so you can hear the sound.
Nov 13, 2010 | Pioneer Audio Players & Recorders
Pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Aug 03, 2007 | Pioneer VSX-D511 Receiver
Poor sound
Jun 19, 2007 | Pioneer VSX-D711 Receiver
24 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
