Question about Motorola CP185 (16 Channels) Two Way Radio
What is the flashing green light on the motorola CP185 for
DECODING MODEL NUMBER/FREQUENCY RANGE
This is the model number for a UHF Motorola CP185. Specifically, 16-Channel, 4W Model 435-480 MHz. The only way to determine the frequencies programmed into the radio is to have the radio read-out by an authorized Motorola dealer or other entity with a subscription to the software, as well as, a radio interface box (RIB) and appropriate cable.
Best regards.
Nov 29, 2013 | Motorola HT1000, MTS2000, MTX8000/9000...
I have a motorola cp185, is this radio capable of doing fleet sync I.d.
No. FleetSync is a feature of Kenwood radios. The CP185 does not have FleetSync capability, nor can we find any documentation saying it has Motorola's MDC1200 signalling. (Also note: FleetSync and MDC1200 are not compatible with one another.)
Best regards.
Oct 13, 2013 | Radio Communications
How do I know if my Motorola CP185 is UHF or VHF without taking it to a dealer for programming?
Hi christo,
Yes the serial No. usually indicates the frequency band the radio works on, but not always, because a lot of radios nowadays can operate on both VHF & UHF, so not being familiar with your model, I can't give you a definitive answer.
I do have the feeling, for what it's worth, that it is in fact a UHF band radio, but don't take that as gospel.
Anyone else reading this post is most welcome to assist in helping a friend out, we would much appreciate your input, thanks.
Hang in there my friend, there will be an answer soon.
Cheers, Peter
I'll look into it further as well....
Jul 11, 2012 | Motorola CP185 (16 Channels) Two Way Radio
How to enable all channels
The CP185 is dealer programmable for up to 16 channels. You would need to see an authorized Motorola dealer to have the radio reprogrammed to your additional FCC assigned frequencies.
Best regards.
Jun 09, 2012 | Motorola CP185 (16 Channels) Two Way Radio
CP185 radio won't stop beeping and is flashing red
Could be a variety of problems. Common issues might include a bad or poorly charged battery, an unprogrammed channel is selected, or you are programmed for busy channel lock out, and their is local traffic on your frequency causing you to be blocked out.
To test your battery, try trading with another radio which has a known good battery.
Check with your local dealer or a repair facility for more help.
Best regards.
Sep 23, 2011 | Motorola CP185 (16 Channels) Two Way Radio
Is the CP185 narrowband capable?
Yes. It is programmable to either wideband or narrowband on each channel. All current model VHF and UHF Motorola radios are narrowband capable.
Best regards.
Nov 09, 2010 | Motorola CP185 (16 Channels) Two Way Radio
Motorola CP185 (16 Channels) Two Way Radio Logo
212 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
